  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 325.2k Views 52 Watching
  • petewillP
    petewillP
    petewill
    @BulldogLowell said:
    were you not getting a compile error? on the PushButton variable being undeclared?
    Ok, I still think I have some things to learn about interrupts. I thought PushButton was the method being called when the interrupt was triggered. I didn't think it was the pin. I thought the pin was the first item 1 in this case. But, I thought 1 isn't even the pin. It's the interrupt number which is pin 3 in the case of a Pro Mini. I also thought I needed to declare the pinMode even if it's already in the interrupt. So confusing... Am I totally off?
    • petewillP petewill
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @petewill
      post deleted, my bad! your understanding is 100% correct!
      your PushButton is the ISR, so you are right
      Try the extra pullup or pull-down
      really sorry for confusing you! I'm mega jet lagged
      • petewillP
        petewillP
        petewill
        I'm mega jet lagged
        Totally understandable :)
        Ok, I'll try the other options discussed above and post back. Thanks.
        • petewillP
          petewillP
          petewill
          Well, I had almost no time to work on MySensors stuff this weekend. :( I did do a quick test last night and it seems the external pullup worked! I power cycled the node 3 times and each time it worked flawlessly. I'll continue to test but so far so good. Thank you!
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @petewill
            glad to hear that worked!
            :thumbsup:
              I put together an extension of the multi-Relay controller for use as a controller for your irrigation project if you have more zones than available pins on your Arduino.
              This sketch features the following:
              • Allows you to cycle through All zones or individual zone control.
              • Use the (n+1)th device to activate each zone in numeric sequence (zero to n) using
                Variable1 as the "ON" time in minutes in each of the vera devices created.
              • Use the individual zone controller to activate a single zone. This feature uses
                Variable2 as the "ON" time for each individual device/zone.
              • Connect according to pinout in the sketch and uses an 74HC595 (or equiv) Shift Register as to
                allow the MySensors standard radio configuration and still leave available digital pins
              • Compiles to ~12,000 Bytes, so will run on any Arduino
              • Turning on any zone will stop the current process and begin that particular process.
              • Turning off any zone will stop the current process and turn off all zones.
              • Sketch must collect your desired intervals so it takes several minutes to startup.
              • If you change your desired time intervals for your zones, simply restart your arduino
                and it will self update to reflect those changes.
              Example, I am using with 8 relays:
              This will create 9 devices. Zero through 7 are the individual relays. Eight is the Sequencer, so to speak (refer to attachment).
              Once you create this and add it using the gateway, go to each of zero through 7 and edit Variable1 and Variable2 for what time you want to use for the Sequencer or Zone respectively. Then save the settings. Then, restart your arduino; your arduino will extract these settings and save them to an array.
              When you turn on device 8 (aka the Sequencer) the relays will actuate in order from zero to seven, each one staying on for the period entered in the Variable1 field. There is a 5 second delay at the start of a new zone to allow for the valves to hydraulically reset.
              When you turn on any of devices zero through 7, it will run that zone only for the period of time entered in Variable2.
              Selecting any new zone (0-8) will stop the current process and start as per above.
              Hope you have a use for it. If you see any opportunity to improve, or find a bug, let me know.
              Jim
              modified. Attached wrong file, whoops!
              Sprinkler.ino
              SparkmanS
              SparkmanS
              Sparkman
              wrote on last edited by Sparkman
              #46
              @BulldogLowell Thanks for posting this. A sprinkler controller to replace my Rainbird controller is next on my list of projects.
              For those looking for a good and relatively cheap soil moisture sensor, these ones are pretty good and use a capacitive sensor: http://www.ebay.com/itm/261675851824. They transmit on 433 MHz. I currently use them with RFXCom and HomeSeer, but for those that don't have RFXCom, the protocol should be relatively easy to reverse engineer and then use directly with MySensors and a 433MHz receiver. I've also bought a few from here: https://www.plantcaretools.com/en/webshop/wireless-moisture-sensor-en-detail. Both sellers were good to deal with. The only drawback to them is that the antenna (and therefore range) is not very good, but there is an easy mod to improve that: http://www.domoticz.com/forum/viewtopic.php?f=13&t=2712
              Cheers
              Al
              DrJeffD 1 Reply Last reply
                wrote on last edited by hek
                #47
                Added your project to the main site togeter with @petewill excellent new video.
                http://www.mysensors.org/build/irrigation
                https://youtu.be/l4GPRTsuHkI
                BulldogLowellB C 2 Replies Last reply
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  wrote on last edited by BulldogLowell
                  #48
                  Cool @hek!
                  Well done @petewill So easy for folks to follow along your outstanding video!
                  MySensors Community Rocks!
                  • petewillP
                    petewillP
                    petewill
                    Agreed!!! Thanks to both @BulldogLowell and @hek for making this possible. I love seeing it hanging on my wall every time I go into the basement :)
                    • RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      Great Work Guys!!
                      RJ_Make
                      • SparkmanS Sparkman
                        Cheers
                        Al
                        DrJeffD
                        DrJeffD
                        DrJeff
                        @Sparkman I like the sensors, I just built some and was dbating the way to make smaller, what kind of battery life do those moisture sensors have?
                        @petewill Time to change my current 16 valve arduino sprinklers to a little smarter version like yours! I love this community.
                        You have been coming on with some awesome videos and contributions!
                        petewillP SparkmanS 2 Replies Last reply
                        • DrJeffD DrJeff
                          petewillP
                          petewillP
                          petewill
                          @DrJeff I agree this is a great community! So much fun!
                          Thanks for the kind words! All credit for this project goes to @BulldogLowell though. I just made the video :)
                            Cool @hek!
                            DrJeffD
                            DrJeffD
                            DrJeff
                            @BulldogLowell Sorry For not giving the credit where it is due! Major Props @BulldogLowell !
                            • DrJeffD DrJeff
                              SparkmanS
                              SparkmanS
                              Sparkman
                              They've been running for about 9 months on the first set of batteries (2xAAA) so far and are still going strong.
                              Cheers
                              Al
                              • DrJeffD DrJeff
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                Thanks @DrJeff
                                I just made an irrigation controller... @petewill made it for everyone!
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  just for inspiration, here's another irrigation controller video (no, it's not mine.. but one of my friends that made it)
                                  https://www.youtube.com/watch?v=BRU0xrd8dn0
                                  petewillP DrJeffD 2 Replies Last reply
                                  • DidiD
                                    DidiD
                                    Didi
                                    Wow 48 channels thats awesome
                                    if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
                                    • tbowmoT tbowmo
                                      petewillP
                                      petewillP
                                      petewill
                                      @tbowmo WOW! What did he use that for??
                                      tbowmoT 1 Reply Last reply
                                      • tbowmoT tbowmo
                                        DrJeffD
                                        DrJeffD
                                        DrJeff
                                        @tbowmo Time for a Shower, Can you say body sprays! :)
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @petewill
                                          He recently planted a lot of trees, so instead of walking around and watering each one manually he made this
                                          Its a arduino with a nrf24 module, but not using the mysensors library (yet...)
                                          petewillP 1 Reply Last reply
