  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 325.2k Views 52 Watching
  • BulldogLowellB
    BulldogLowellB
    BulldogLowell
    Yes, since clock no longer needs to call server for time, synchronizing is not necessary.
    You should post serial output or show a video.
    Did you find out if Domoticz supports V_VAR1?
    T 1 Reply Last reply
      treb0r
      @BulldogLowell
      OK, I will post the video. If I will manage I will also post serial output
      treb0r
      • T treb0r
        @BulldogLowell
        treb0r
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @treb0r @BulldogLowel I had a chance to play a little bit with VAR1 this weekend. I verified that if you declare MyMessage var(CHILD_ID, V_VAR1); you can set it with gw.send(var.set("hello")); and request its value from the gateway using gw.request(CHILD_ID, V_VAR1);. you will get the answer in the incoming message handler under the V_VAR1 message
           if (message.type==V_VAR1) {
           	 Serial.println("got var1 answer");
           	 Serial.println(message.getString());
        However I still didn't manage to find how to access or show these values on the domoticz. their site crashed so couldn't ask this in the forum
        • epierreE
          epierreE
          epierre
          @Moshe-Livne Domoticz (as of today) doesn't support V_VARx ...
          z-wave - Vera -> Domoticz
          • epierreE epierre
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @epierre it does but in a strange way. The vars are not display vars. They are stored in the db and can be fetched and set only by the sensor. Tried it, it works....
            • epierreE
              epierreE
              epierre
              @Moshe-Livne this is not what @GizMoCuz said in a post... strange...
              • epierreE epierre
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @epierre can you please link to the post?
                • epierreE
                  epierreE
                  epierre
                  here it is:
                  http://www.domoticz.com/forum/viewtopic.php?f=42&t=7187&p=48366&hilit=v_var#p48366
                  • epierreE epierre
                    here it is:
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @epierre He meant in the sense that it does not display or use it for anything. he said there "it is used to store/retrieve variables". The thread was about the option to show the vars as part of the sensor output. for storing and retrieving, it works.... verified.... I might get annoyed enough to add to the code that the lua script can also retrieve these vars and then it would be sweet.....
                    • epierreE
                      epierreE
                      epierre
                      ok good although it was not explicit... now I'll have to go back to him about water meter that heavily use V_VARs but is recognized.... as a power meter...
                        moffen666
                        Hello
                        And thx for a nice forum, I did build the irrigation controller and tried to connect it to Domoticz. Everything just seems fine, LCD works, push button works and I can turn on the irrigation from Domoticz and it shows in the LCD.
                        But the problem is that it doesn't switch the relays on, it just says "no valve time" and then go watering cycle complete.
                        Any suggestions on what the problem might be...... Domoticz?
                        Regards
                        • M moffen666
                          Hello
                          Regards
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @moffen666
                          I don't have Domoticz but I suspect that the callback isn't functioning.
                          try populating the array with the desired times for each sequence. replace this:
                          int allZoneTime [NUMBER_OF_VALVES + 1];
                          int valveSoloTime [NUMBER_OF_VALVES + 1];
                          with something like this:
                          int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 10, 10, 10, 5,<... how many valves you have with zero in the first position>} ;
                          int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 5, 5, 5, 5,<... how many valves you have with zero in the first position>};
                          This will load in the times that the program uses as your 'default' values. Then, you can check with Domoticz experts on getting the V_VAR variables working.
                          fusion_manF 1 Reply Last reply
                            moffen666
                            Thx Bulldog
                            I will check asap and get back with the result.
                            Regards
                              moffen666
                              Hi
                              I tried the code but it didn't compile, and I'm not good enough to be sure whats wrong.
                              I did try change the code and I did get it to compile, but I don't know if I got it right. You can see the lame attempt below the colored line.
                              upload-956d60c8-6d6d-44b7-abdb-015f701c65dc
                              • M moffen666
                                Hi
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                wrote on last edited by BulldogLowell
                                #95
                                @moffen666
                                Clearly you understand that you are to put the times for each of the valve zones, led by a zero into the array, and not copy my verbatim instructions...
                                How many valves do you have? You need that many (plus one) integer numbers separated by commas...
                                Example 8 valves:
                                ...= {0,5,5,5,5,5,5,5,5};
                                You've commented out the wrong lines.
                                  moffen666
                                  Thx for the quick answer
                                  I use 4 valves atm, I tried your suggestion but it seems it wont work for me.
                                  upload-edb305b1-3dc3-4afd-ae02-e2e779452d18
                                  Regards
                                    moffen666
                                    The inserted values in the array works from start, but it looks like the irrigation controller immediately starts to request valve data from the controller for variable1 and 2. As we cant set variable1 and 2 in Domoticz I guess it returns 0 and overwrite the inserted values in the arrays...or is it anything else happening?
                                    Initialising...
                                    Turning All Valves Off...
                                    Unable to sync with the RTC
                                    Checking EEPROM for stored date:
                                    Retreiving last run time from EEPROM...
                                    send: 7-7-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                                    send: 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                    read: 0-0-7 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                    sensor started, id=7, parent=0, distance=1
                                    send: 7-7-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:MySprinkler
                                    send: 7-7-0-0 s=255,c=3,t=12,pt=0,l=6,sg=0,st=ok:2.0nsr
                                    send: 7-7-0-0 s=0,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    send: 7-7-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    send: 7-7-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    send: 7-7-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    send: 7-7-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    Sensor Presentation Complete
                                    Ready...
                                    Calling for Valve 0 Data...
                                    send: 7-7-0-0 s=0,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=0,c=2,t=24,pt=0,l=0,sg=0:
                                    Recieved variable1 valve:0 = 0
                                    send: 7-7-0-0 s=0,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=0,c=2,t=25,pt=0,l=0,sg=0:
                                    Recieved variable2 valve:0 = 0
                                    send: 7-7-0-0 s=0,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=0,c=2,t=26,pt=0,l=0,sg=0:
                                    No Name Recieved for zone 0
                                    Calling for Valve 1 Data...
                                    send: 7-7-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=1,c=2,t=24,pt=0,l=0,sg=0:
                                    Recieved variable1 valve:1 = 0
                                    New Zone Times Recieved...
                                    Zone 1 individual time: 1 group time: 0
                                    Zone 2 individual time: 1 group time: 1
                                    Zone 3 individual time: 1 group time: 1
                                    Zone 4 individual time: 1 group time: 1
                                    send: 7-7-0-0 s=1,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=1,c=2,t=25,pt=0,l=0,sg=0:
                                    Recieved variable2 valve:1 = 0
                                    Zone 1 individual time: 0 group time: 0
                                    send: 7-7-0-0 s=1,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=1,c=2,t=26,pt=0,l=0,sg=0:
                                    No Name Recieved for zone 1
                                    Calling for Valve 2 Data...
                                    send: 7-7-0-0 s=2,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=2,c=2,t=24,pt=0,l=0,sg=0:
                                    Recieved variable1 valve:2 = 0
                                    Zone 2 individual time: 1 group time: 0
                                    send: 7-7-0-0 s=2,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=2,c=2,t=25,pt=0,l=0,sg=0:
                                    Recieved variable2 valve:2 = 0
                                    Zone 2 individual time: 0 group time: 0
                                    send: 7-7-0-0 s=2,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=2,c=2,t=26,pt=0,l=0,sg=0:
                                    No Name Recieved for zone 2
                                    Calling for Valve 3 Data...
                                    send: 7-7-0-0 s=3,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=3,c=2,t=24,pt=0,l=0,sg=0:
                                    Recieved variable1 valve:3 = 0
                                    Zone 3 individual time: 1 group time: 0
                                    send: 7-7-0-0 s=3,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=3,c=2,t=25,pt=0,l=0,sg=0:
                                    Recieved variable2 valve:3 = 0
                                    Zone 3 individual time: 0 group time: 0
                                    send: 7-7-0-0 s=3,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=3,c=2,t=26,pt=0,l=0,sg=0:
                                    No Name Recieved for zone 3
                                    Calling for Valve 4 Data...
                                    send: 7-7-0-0 s=4,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=4,c=2,t=24,pt=0,l=0,sg=0:
                                    Recieved variable1 valve:4 = 0
                                    Zone 4 individual time: 1 group time: 0
                                    send: 7-7-0-0 s=4,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=4,c=2,t=25,pt=0,l=0,sg=0:
                                    Recieved variable2 valve:4 = 0
                                    Zone 4 individual time: 0 group time: 0
                                    send: 7-7-0-0 s=4,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                                    read: 0-0-7 s=4,c=2,t=26,pt=0,l=0,sg=0:
                                    No Name Recieved for zone 4
                                    • M moffen666
                                      Initialising...
                                      Ready...
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @moffen666
                                      try commenting out this in setup():
                                      for (byte i = 0; i <= NUMBER_OF_VALVES; i++)
                                          pinMode(relayPin[i], OUTPUT);
                                          lcd.print(F(" Updating  "));
                                          lcd.setCursor(0, 1);
                                          lcd.print(F(" Valve Data: "));
                                          lcd.print(i);
                                          boolean flashIcon = false;
                                          DEBUG_PRINT(F("Calling for Valve "));
                                          DEBUG_PRINT(i);
                                          DEBUG_PRINTLN(F(" Data..."));
                                          while (gw.process() == false)
                                            lcd.setCursor(15, 0);
                                            flashIcon = !flashIcon;
                                            flashIcon ? lcd.write(byte(1)) : lcd.print(F(" "));
                                            gw.request(i, V_VAR1);
                                            delay(100);
                                            gw.request(i, V_VAR2);
                                            delay(100);
                                            gw.request(i, V_VAR3);
                                            delay(100);
                                      and this in loop():
                                      //goGetValveTimes();
                                      That will disable those callbacks and you should be OK with a HardCoded time table for the valves and valve names.
                                        moffen666
                                        Thx Bulldog for all the help, everything seems to be working as it should now.
                                        Keep up the good work :+1:
                                        Updated code for Domoticz.
                                        MySprinkler for MySensors
                                        Arduino Multi-Zone Sprinkler Control
                                        May 31, 2015
                                        *** Version 2.0
                                        *** Upgraded to http://MySensors.org version 1.4.1
                                        *** Expanded for up to 16 Valves
                                        *** Setup for active low relay board or comment out #define ACTIVE_LOW to switch to active high
                                        *** Switch to bitshift method vs byte arrays
                                        *** Changed RUN_ALL_ZONES Vera device to 0 (was highest valve)
                                        *** Added optional LCD display featuring remaining time, date last ran & current time
                                        *** Features 'raindrop' and 'clock' icons which indicate sensor is updating valve data and clock respectively
                                        *** Added single pushbutton menu to manually select which program to run (All Zones or a Single Zone)
                                        *** Added option of naming your Zones programmatically or with Vera (V_VAR3 used to store names)
                                        Utilizing your Vera home automation controller and the MySensors.org gateway you can
                                        control up to a sixteen zone irrigation system with only three digital pins.  This sketch
                                        will create NUMBER_OF_VALVES + 1 devices on your Vera controller
                                        This sketch features the following:
                                        * Allows you to cycle through All zones (RUN_ALL_ZONES) or individual zone (RUN_SINGLE_ZONE) control.
                                        * Use the 0th controller to activate RUN_ALL_ZONES (each zone in numeric sequence 1 to n)
                                          using Variable1 as the "ON" time in minutes in each of the vera devices created.
                                        * Use the individual zone controller to activate a single zone.  This feature uses
                                          Variable2 as the "ON" time for each individual device/zone.
                                        * Connect according to pinout below and uses Shift Registers as to allow the MySensors
                                          standard radio configuration and still leave available digital pins
                                        * Turning on any zone will stop the current process and begin that particular process.
                                        * Turning off any zone will stop the current process and turn off all zones.
                                        * To push your new time intervals for your zones, simply change the variable on your Vera and
                                          your arduino will call to Vera once a minute and update accordingly.  Variables will also be
                                          requested when the device is first powered on.
                                        * Pushbutton activation to RUN_ALL_ZONES, RUN_SINGLE_ZONE or halt the current program
                                        * LED status indicator
                                        PARTS LIST:
                                        Available from the MySensors store - http://www.mysensors.org/store/
                                        * Relays (8 channel)
                                        * Female Pin Header Connector Strip
                                        * Prototype Universal Printed Circuit Boards (PCB)
                                        * NRF24L01 Radio
                                        * Arduino (I used a Pro Mini)
                                        * FTDI USB to TTL Serial Adapter
                                        * Capacitors (10uf and .1uf)
                                        * 3.3v voltage regulator
                                        * Resistors (270 & 10K)
                                        * Female Dupont Cables
                                        * 1602 LCD (with I2C Interface)
                                        * LED
                                        * Push button
                                        * Shift Register (SN74HC595)
                                        * 2 Pole 5mm Pitch PCB Mount Screw Terminal Block
                                        * 3 Pole 5mm Pitch PCB Mount Screw Terminal Block
                                        * 22-24 gauge wire or similar (I used Cat5/Cat6 cable)
                                        * 18 gauge wire (for relay)
                                        * Irrigation Power Supply (24-Volt/750 mA Transformer)
                                        INSTRUCTIONS:
                                        * A step-by-step setup video is available here: http://youtu.be/l4GPRTsuHkI
                                        * After assembling your arduino, radio, decoupling capacitors, shift register(s), status LED, pushbutton LCD (I2C connected to
                                          A4 and A5) and relays, and load the sketch.
                                        * Following the instructions at https://MySensors.org include the device to your MySensors Gateway.
                                        * Verify that each new device has a Variable1, Variable2 and Variable3. Populate data accordingly with whole minutes for
                                          the RUN_ALL_ZONES routine (Variable1) and the RUN_SINGLE_ZONE routines (Variable 2).  The values entered for times may be zero and
                                          you may use the defaulet zone names by leaving Variable3 blank.
                                        * Once you have entered values for each zone and each variable, save the settings by pressing the red save button on your Vera.
                                        * Restart your arduino; verify the settings are loaded into your arduino with the serial monitor; the array will be printed
                                          on the serial monitor.
                                        * Your arduino should slow-flash, indicating that it is in ready mode.
                                        * There are multiple debug serial prints that can be monitored to assure that it is operating properly.
                                        * ***THIS SHOULD NO LONGER BE NEEDED*** The standard MySensors library now works. https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
                                        Contributed by Jim (BulldogLowell@gmail.com) with much contribution from Pete (pete.will@mysensors.org) and is released to the public domain
                                        #include <Wire.h>
                                        #include <Time.h>
                                        #include <LiquidCrystal.h>
                                        #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
                                        #define VALVE_RESET_TIME 7500UL   // Change this (in milliseconds) for the time you need your valves to hydraulically reset and change state
                                        #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
                                        #define SKETCH_NAME "MySprinkler Domoticz"
                                        #define SKETCH_VERSION "2.0"
                                        #define CHILD_ID_SPRINKLER 0
                                        //#define ACTIVE_LOW // comment out this line if your relays are active high
                                        #define DEBUG_ON   // comment out to supress serial monitor output
                                        #ifdef ACTIVE_LOW
                                        #define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber-1))
                                        #define ALL_VALVES_OFF 0xFFFF
                                        #else
                                        #define BITSHIFT_VALVE_NUMBER (1U << (valveNumber-1))
                                        #define ALL_VALVES_OFF 0U
                                        #ifdef DEBUG_ON
                                        #define DEBUG_PRINT(x)   Serial.print(x)
                                        #define SERIAL_START(x)  Serial.begin(x)
                                        #else
                                        typedef enum {
                                          STAND_BY_ALL_OFF, RUN_SINGLE_ZONE, RUN_ALL_ZONES, CYCLE_COMPLETE, ZONE_SELECT_MENU
                                        SprinklerStates;
                                        SprinklerStates state = STAND_BY_ALL_OFF;
                                        SprinklerStates lastState;
                                        byte menuState = 0;
                                        unsigned long menuTimer;
                                        byte countDownTime = 10;
                                        int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
                                        int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
                                        int valveNumber;
                                        int lastValve;
                                        unsigned long startMillis;
                                        const int ledPin = 5;
                                        const int waterButtonPin = 3;
                                        boolean buttonPushed = false;
                                        boolean showTime = true;
                                        boolean clockUpdating = false;
                                        boolean recentUpdate = true;
                                        const char *dayOfWeek[] = {
                                          "Null", "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
                                        // Name your Zones here or use Vera to edit them by adding a name in Variable3...
                                        String valveNickName[17] = {
                                          "All Zones", "Zone 1", "Zone 2", "Zone 3", "Zone 4", "Zone 5", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
                                        time_t lastTimeRun = 0;
                                        //Setup Shift Register...
                                        const int latchPin = 8;
                                        const int clockPin = 4;
                                        const int dataPin  = 7;
                                        byte clock[8] = {0x0, 0xe, 0x15, 0x17, 0x11, 0xe, 0x0}; // fetching time indicator
                                        byte raindrop[8] = {0x4, 0x4, 0xA, 0xA, 0x11, 0xE, 0x0,}; // fetching Valve Data indicator
                                        // Set the pins on the I2C chip used for LCD connections:
                                        //                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
                                        LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                                        MyMessage msg1valve(CHILD_ID_SPRINKLER, V_LIGHT);
                                        MyMessage var1valve(CHILD_ID_SPRINKLER, V_VAR1);
                                        MyMessage var2valve(CHILD_ID_SPRINKLER, V_VAR2);
                                          SERIAL_START(115200);
                                          DEBUG_PRINTLN(F("Initialising..."));
                                          pinMode(latchPin, OUTPUT);
                                          pinMode(clockPin, OUTPUT);
                                          pinMode(dataPin, OUTPUT);
                                          pinMode(ledPin, OUTPUT);
                                          pinMode(waterButtonPin, INPUT_PULLUP);
                                          //pinMode(waterButtonPin, INPUT);
                                          attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                                          digitalWrite (ledPin, HIGH);
                                          DEBUG_PRINTLN(F("Turning All Valves Off..."));
                                          updateRelays(ALL_VALVES_OFF);
                                          //delay(5000);
                                          lcd.begin(16, 2); //(16 characters and 2 line display)
                                          lcd.clear();
                                          lcd.backlight();
                                          lcd.createChar(0, clock);
                                          lcd.createChar(1, raindrop);
                                          //check for saved date in EEPROM
                                          DEBUG_PRINTLN(F("Checking EEPROM for stored date:"));
                                          delay(500);
                                          if (gw.loadState(0) == 0xFF); // EEPROM flag
                                            DEBUG_PRINTLN(F("Retreiving last run time from EEPROM..."));
                                            for (int i = 0; i < 4 ; i++)
                                              lastTimeRun = lastTimeRun << 8;
                                              lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                                          gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                                          gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
                                            gw.present(i, S_LIGHT);
                                          DEBUG_PRINTLN(F("Sensor Presentation Complete"));
                                          digitalWrite (ledPin, LOW);
                                          DEBUG_PRINTLN(F("Ready..."));
                                          lcd.setCursor(0, 0);
                                          lcd.print(F(" Syncing Time  "));
                                          lcd.write(byte(0));
                                          int clockCounter = 0;
                                          while (timeStatus() == timeNotSet && clockCounter < 21)
                                            gw.process();
                                            gw.requestTime(receiveTime);
                                            DEBUG_PRINTLN(F("Requesting time from Gateway:"));
                                            delay(1000);
                                            lcd.print(".");
                                            clockCounter++;
                                            if (clockCounter > 16)
                                              DEBUG_PRINTLN(F("Failed initial clock synchronization!"));
                                              lcd.clear();
                                              lcd.print(F("  Failed Clock  "));
                                              lcd.print(F(" Syncronization "));
                                              delay(2000);
                                              break;
                                          lcd.clear();
                                          //Update valve data when first powered on
                                            lcd.print(i);
                                            DEBUG_PRINT(i);
                                              delay(100);
                                              delay(100);
                                              delay(100);
                                          lcd.clear();
                                          gw.process();
                                          updateClock();
                                          updateDisplay();
                                          if (buttonPushed)
                                            menuTimer = millis();
                                            DEBUG_PRINTLN(F("Button Pressed"));
                                            if (state == STAND_BY_ALL_OFF)
                                              state = ZONE_SELECT_MENU;
                                              menuState = 0;
                                            else if (state == ZONE_SELECT_MENU)
                                              menuState++;
                                              if (menuState > NUMBER_OF_VALVES)
                                                menuState = 0;
                                            else
                                            slowToggleLED ();
                                            if (state != lastState)
                                              DEBUG_PRINTLN(F("State Changed... all Zones off"));
                                                delay(50);
                                                gw.send(msg1valve.setSensor(i).set(false), false);
                                              lcd.clear();
                                              lcd.setCursor(0,0);
                                              lcd.print(F("** Irrigation **"));
                                              lcd.setCursor(0,1);
                                              lcd.print(F("**   Halted   **"));
                                              delay(2000);
                                              lastValve = -1;
                                          else if (state == RUN_ALL_ZONES)
                                            if (lastValve != valveNumber)
                                                if (i == 0 || i == valveNumber)
                                                  gw.send(msg1valve.setSensor(i).set(true), false);
                                                else
                                            lastValve = valveNumber;
                                            fastToggleLed();
                                              valveNumber = 1;
                                              DEBUG_PRINTLN(F("State Changed, Running All Zones..."));
                                            unsigned long nowMillis = millis();
                                            if (nowMillis - startMillis < VALVE_RESET_TIME)
                                            else if (nowMillis - startMillis < (allZoneTime[valveNumber] * 60000UL))
                                              updateRelays(BITSHIFT_VALVE_NUMBER);
                                            else
                                              DEBUG_PRINTLN(F("Changing Valves..."));
                                              startMillis = millis();
                                              valveNumber++;
                                              if (valveNumber > NUMBER_OF_VALVES)
                                                state = CYCLE_COMPLETE;
                                                lastValve = -1;
                                                lastTimeRun = now();
                                                saveDateToEEPROM(lastTimeRun);
                                                DEBUG_PRINT(F("State = "));
                                                DEBUG_PRINTLN(state);
                                          else if (state == RUN_SINGLE_ZONE)
                                            fastToggleLed();
                                                else
                                              DEBUG_PRINTLN(F("State Changed, Single Zone Running..."));
                                              DEBUG_PRINT(F("Zone: "));
                                              DEBUG_PRINTLN(valveNumber);
                                            else if (nowMillis - startMillis < (valveSoloTime [valveNumber] * 60000UL))
                                            else
                                          else if (state == CYCLE_COMPLETE)
                                            if (millis() - startMillis < 30000UL)
                                              fastToggleLed();
                                            else
                                          else if (state = ZONE_SELECT_MENU)
                                            displayMenu();
                                          lastState = state;
                                        void displayMenu(void)
                                          static byte lastMenuState = -1;
                                          static int lastSecond;
                                          if (menuState != lastMenuState)
                                            lcd.clear();
                                            lcd.print(valveNickName[menuState]);
                                            lcd.print(F("Starting"));
                                            DEBUG_PRINT(valveNickName[menuState]);
                                            Serial.print(F(" Starting Shortly"));
                                          int thisSecond = (millis() - menuTimer) / 1000UL;
                                          if (thisSecond != lastSecond && thisSecond < 8)
                                            lcd.print(F("."));
                                            Serial.print(".");
                                          lastSecond = thisSecond;
                                          if (millis() - menuTimer > 10000UL)
                                            if (menuState == 0)
                                              valveNumber = 1;
                                              state = RUN_ALL_ZONES;
                                            else
                                              valveNumber = menuState;
                                              state = RUN_SINGLE_ZONE;
                                          else
                                          lastMenuState = menuState;
                                        void updateRelays(int value)
                                          digitalWrite(latchPin, LOW);
                                          shiftOut(dataPin, clockPin, MSBFIRST, highByte(value));
                                          shiftOut(dataPin, clockPin, MSBFIRST, lowByte(value));
                                          digitalWrite(latchPin, HIGH);
                                        void PushButton() //interrupt with debounce
                                          static unsigned long last_interrupt_time = 0;
                                          unsigned long interrupt_time = millis();
                                          if (interrupt_time - last_interrupt_time > 200)
                                            buttonPushed = true;
                                          last_interrupt_time = interrupt_time;
                                        void fastToggleLed()
                                          static unsigned long fastLedTimer;
                                          if (millis() - fastLedTimer >= 100UL)
                                            digitalWrite(ledPin, !digitalRead(ledPin));
                                            fastLedTimer = millis ();
                                        void slowToggleLED ()
                                          static unsigned long slowLedTimer;
                                          if (millis() - slowLedTimer >= 1250UL)
                                            slowLedTimer = millis ();
                                        void getVariables(const MyMessage &message)
                                          boolean zoneTimeUpdate = false;
                                          if (message.isAck())
                                            DEBUG_PRINTLN(F("This is an ack from gateway"));
                                            if (message.sensor == i)
                                              if (message.type == V_LIGHT)
                                                int switchState = atoi(message.data);
                                                if (switchState == 0)
                                                  DEBUG_PRINTLN(F("Recieved Instruction to Cancel..."));
                                                else
                                                  if (i == 0)
                                                    valveNumber = 1;
                                                    DEBUG_PRINTLN(F("Recieved Instruction to Run All Zones..."));
                                                  else
                                                    valveNumber = i;
                                                    DEBUG_PRINT(F("Recieved Instruction to Activate Zone: "));
                                                    DEBUG_PRINTLN(i);
                                              else if (message.type == V_VAR1)
                                                int variable1 = atoi(message.data);// RUN_ALL_ZONES time
                                                DEBUG_PRINT(F("Recieved variable1 valve:"));
                                                DEBUG_PRINT(i);
                                                DEBUG_PRINT(F(" = "));
                                                DEBUG_PRINTLN(variable1);
                                                if (variable1 != allZoneTime[i])
                                                  allZoneTime[i] = variable1;
                                                  zoneTimeUpdate = true;
                                              else if (message.type == V_VAR2)
                                                int variable2 = atoi(message.data);// RUN_SINGLE_ZONE time
                                                DEBUG_PRINT(F("Recieved variable2 valve:"));
                                                DEBUG_PRINT(i);
                                                DEBUG_PRINTLN(variable2);
                                                if (variable2 != valveSoloTime[i])
                                                  valveSoloTime[i] = variable2;
                                              else if (message.type == V_VAR3)
                                                String newMessage = String(message.data);
                                                if (newMessage.length() == 0)
                                                  DEBUG_PRINT(F("No Name Recieved for zone "));
                                                  DEBUG_PRINTLN(i);
                                                  break;
                                                if (newMessage.length() > 16)
                                                  newMessage.substring(0, 16);
                                                valveNickName[i] = "";
                                                valveNickName[i] += newMessage;
                                                DEBUG_PRINT(F("Recieved new name for zone "));
                                                DEBUG_PRINT(i);
                                                DEBUG_PRINT(F(" and it is now called: "));
                                                DEBUG_PRINTLN(valveNickName[i]);
                                          if (zoneTimeUpdate)
                                            DEBUG_PRINTLN(F("New Zone Times Recieved..."));
                                              if (i != 0)
                                                DEBUG_PRINT(F("Zone "));
                                                DEBUG_PRINT(i);
                                                DEBUG_PRINT(F(" individual time: "));
                                                DEBUG_PRINT(valveSoloTime[i]);
                                                DEBUG_PRINT(F(" group time: "));
                                                DEBUG_PRINTLN(allZoneTime[i]);
                                          else
                                            recentUpdate = false;
                                        void updateDisplay()
                                          static unsigned long lastUpdateTime;
                                          static boolean displayToggle = false;
                                          //static byte toggleCounter = 0;
                                          static SprinklerStates lastDisplayState;
                                          if (state != lastDisplayState || millis() - lastUpdateTime >= 3000UL)
                                            displayToggle = !displayToggle;
                                            switch (state) {
                                              case STAND_BY_ALL_OFF:
                                                fastClear();
                                                if (displayToggle)
                                                  lcd.print(F("  System Ready "));
                                                  if (clockUpdating)
                                                    lcd.write(byte(0));
                                                  lcd.print(hourFormat12() < 10 ? F(" ") : F(""));
                                                  lcd.print(hourFormat12());
                                                  lcd.print(minute() < 10 ? F(":0") : F(":"));
                                                  lcd.print(minute());
                                                  lcd.print(isAM() ? F("am") : F("pm"));
                                                  lcd.print(month() < 10 ? F(" 0") : F(" "));
                                                  lcd.print(month());
                                                  lcd.print(day() < 10 ? F("/0") : F("/"));
                                                  lcd.print(day());
                                                  lcd.print(F("/"));
                                                  lcd.print(year() % 100);
                                                else
                                                  lcd.print(F("  Last Watered "));
                                                  if (clockUpdating)
                                                    lcd.write(byte(0));
                                                  lcd.print(dayOfWeek[weekday(lastTimeRun)]);
                                                  lcd.setCursor(11, 1);
                                                  lcd.print(month(lastTimeRun) < 10 ? F(" ") : F(""));
                                                  lcd.print(month(lastTimeRun));
                                                  lcd.print(day(lastTimeRun) < 10 ? F("/0") : F("/"));
                                                  lcd.print(day(lastTimeRun));
                                                break;
                                              case RUN_SINGLE_ZONE:
                                                fastClear();
                                                if (displayToggle)
                                                  lcd.print(F("Single Zone Mode"));
                                                  lcd.print(F(" Zone:"));
                                                  if (valveNumber < 10) lcd.print(F("0"));
                                                  lcd.print(valveNumber);
                                                  lcd.print(F(" Active"));
                                                else
                                                  lcd.print(F(" Time Remaining "));
                                                  if (valveSoloTime[valveNumber] == 0)
                                                    lcd.print(F(" No Valve Time "));
                                                  else
                                                    unsigned long timeRemaining = (valveSoloTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                                                    lcd.print(timeRemaining / 60 < 10 ? "   0" : "   ");
                                                    lcd.print(timeRemaining / 60);
                                                    lcd.print("min");
                                                    lcd.print(timeRemaining % 60 < 10 ? " 0" : " ");
                                                    lcd.print(timeRemaining % 60);
                                                    lcd.print("sec  ");
                                                break;
                                              case RUN_ALL_ZONES:
                                                fastClear();
                                                if (displayToggle)
                                                  lcd.print(F(" All-Zone  Mode "));
                                                  lcd.print(F(" Active "));
                                                else
                                                  int timeRemaining = (allZoneTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                                                  lcd.print((timeRemaining / 60) < 10 ? "   0" : "   ");
                                                  lcd.print("min");
                                                  lcd.print("sec  ");
                                                break;
                                              case CYCLE_COMPLETE:
                                                if (displayToggle)
                                                  lcd.print(F(" Watering Cycle "));
                                                  lcd.print(F("    Complete    "));
                                                else
                                                  int totalTimeRan = 0;
                                                  for (int i = 1; i < NUMBER_OF_VALVES + 1; i++)
                                                    totalTimeRan += allZoneTime[i];
                                                  lcd.print(F(" Total Time Run "));
                                                  lcd.print(totalTimeRan < 10 ? "   0" : "   ");
                                                  lcd.print(totalTimeRan);
                                                  lcd.print(" Minutes   ");
                                            lastUpdateTime = millis();
                                          lastDisplayState = state;
                                        void receiveTime(time_t newTime)
                                          DEBUG_PRINTLN(F("Time value received and updated..."));
                                          int lastSecond = second();
                                          int lastMinute = minute();
                                          int lastHour = hour();
                                          setTime(newTime);
                                          if (((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour)) || showTime)
                                            DEBUG_PRINTLN(F("Clock updated...."));
                                            DEBUG_PRINT(F("Sensor's time currently set to:"));
                                            DEBUG_PRINT(hourFormat12() < 10 ? F(" 0") : F(" "));
                                            DEBUG_PRINT(hourFormat12());
                                            DEBUG_PRINT(minute() < 10 ? F(":0") : F(":"));
                                            DEBUG_PRINT(minute());
                                            DEBUG_PRINTLN(isAM() ? F("am") : F("pm"));
                                            DEBUG_PRINT(month());
                                            DEBUG_PRINT(F("/"));
                                            DEBUG_PRINT(day());
                                            DEBUG_PRINTLN(year());
                                            DEBUG_PRINTLN(dayOfWeek[weekday()]);
                                            showTime = false;
                                          else
                                            DEBUG_PRINTLN(F("Sensor's time did NOT need adjustment greater than 1 second."));
                                        void fastClear()
                                          lcd.print(F("                "));
                                          lcd.print(F("                "));
                                        void updateClock()
                                          static unsigned long lastVeraGetTime;
                                          if (millis() - lastVeraGetTime >= 3600000UL) // updates clock time and gets zone times from vera once every hour
                                            DEBUG_PRINTLN(F("Requesting time and valve data from Gateway..."));
                                            lcd.write(byte(0));
                                            clockUpdating = true;
                                            lastVeraGetTime = millis();
                                        void saveDateToEEPROM(unsigned long theDate)
                                          DEBUG_PRINTLN(F("Saving Last Run date"));
                                          if (gw.loadState(0) != 0xFF)
                                            gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                                          for (int i = 1; i < 5; i++)
                                            gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                                        void goGetValveTimes()
                                          static unsigned long valveUpdateTime;
                                          static byte valveIndex = 1;
                                          if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                                            DEBUG_PRINTLN(F("Calling for Valve Data..."));
                                            lcd.write(byte(1)); //lcd.write(1);
                                            gw.request(valveIndex, V_VAR1);
                                            gw.request(valveIndex, V_VAR2);
                                            gw.request(valveIndex, V_VAR3);
                                            valveUpdateTime = millis();
                                            valveIndex++;
                                            if (valveIndex > NUMBER_OF_VALVES + 1)
                                              valveIndex = 1;
                                        • petewillP
                                          petewillP
                                          petewill
                                          Hey Everyone,
                                          I just made a follow up video to this irrigation controller that shows my logic I'm using to save water. It's pretty specific to my environment but hopefully you can use some of the ideas to save water in your environment. I have attached the logic I used in my PLEG device.
                                          Pete
                                          PLEG Irrigation.pdf
                                          https://youtu.be/_voDZH2EBgw
