  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 325.2k Views 52 Watching
  • Mark JeffordM
    Mark JeffordM
    Mark Jefford
    Quick question, semi also referenced on the openhab binding.
    Looking to use this with Openhab, I have managed to get it to work with the serial gateway, however i don't see a way i can pass out any configuration of a valve time, i can however trigger valves with a runtime of 0 seconds.
    Any ideas how i can amend this to either use a fixed runtime in the project (happy to run it in 1min increments trigged from openhab hydro sensor results)
    • Mark JeffordM Mark Jefford
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @Mark-Jefford
      In that case, I would just treat each zone as a separate relay/lamp and use Openhab to control the individual ON times... I think.
      johnecyJ Mark JeffordM 2 Replies Last reply
        @Mark-Jefford
        johnecyJ
        johnecyJ
        johnecy
        can I use pin D6 instead ok pin D8 to control the shift register. I am making the controller on the easy/newbie pc board and there is nothing connected to pin D8 on this board.
        • johnecyJ johnecy
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @johnecy
          const int latchPin = 8;
          I think you should be OK to try that
          johnecyJ 1 Reply Last reply
            @johnecy
            johnecyJ
            johnecyJ
            johnecy
            @BulldogLowell thanks for the reply i will post pictures when i get it finished
              @Mark-Jefford
              Mark JeffordM
              Mark JeffordM
              Mark Jefford
              wrote on last edited by Mark Jefford
              #126
              @BulldogLowell
              Gave up with using openhab now using domoticz which is a lot nicer, forced it to hard coded run times by doing this:
              else if (message.type == V_VAR1)
              int variable1 = 5; // atoi(message.data);// RUN_ALL_ZONES time
              DEBUG_PRINT(F("Recieved variable1 valve:"));
              DEBUG_PRINT(i);
              DEBUG_PRINT(F(" = "));
              DEBUG_PRINTLN(variable1);
              if (variable1 != allZoneTime[i])
              allZoneTime[i] = variable1;
                    zoneTimeUpdate = true;
                else if (message.type == V_VAR2)
                  int variable2 = 5; //atoi(message.data);// RUN_SINGLE_ZONE time
                  DEBUG_PRINT(F("Recieved variable2 valve:"));
                  DEBUG_PRINT(i);
                  DEBUG_PRINTLN(variable2);
                  if (variable2 != valveSoloTime[i])
                    valveSoloTime[i] = variable2;
              one thing to note the shift register 0b0000000010000000 does not seem to work, will work out a plan around this as i need to run a 12 pump off the relay bank to draw water from the water butt.
                @BulldogLowell
                DEBUG_PRINT(i);
                    DEBUG_PRINT(i);
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                Can you explain more? is there a bug?
                Mark JeffordM 1 Reply Last reply
                  Mark JeffordM
                  Mark JeffordM
                  Mark Jefford
                  @BulldogLowell
                  Hi! :)
                  Rather than using valve 8, i am using only a block of 4, but currently have a 2 channel for testing.
                  My reading into shift registers showed 0b0000000010000000 is 2x 8 bit outputs, B0-B7
                  tried configuing B0 and B7 to try and activate relay 1, was still seeing 5V on all pins apart from the output pin for the zone in use (EG zone 2 expecting Zone1 to alway be on)
                  or am i doing this completely wrong? :)
                    @BulldogLowell
                    Hi! :)
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @Mark-Jefford
                    hmmm... are your relays ACTIVE HIGH (actuate wiht a 5V signal) or ACTIVE LOW (actuate when brought to ground) type?
                      @Mark-Jefford
                      Mark JeffordM
                      Mark JeffordM
                      Mark Jefford
                      @BulldogLowell
                      Oh, well this is strange, if i disconnect the pin to the relay, it does not activate when unpowered.
                      but from the shift register it is +5 when the zone is not active, and 0V when active, so i assume its an active low not active high by your example... surely removing the 5V feed to the relay pin should make it activate.. not sure whats going on there, some sort of black magic :P
                      My reading of shift registers has made my brain hurt.. do i need to reverse the 0000000010000000 for 1111111101111111?
                      • rechin304R
                        rechin304R
                        rechin304
                        Dear all,
                        i have trying to make the irrigation controller to start all zones in same time and run for the specified. I'm using version for domoticz. Can you please help me out with hint of what i can change in the code ?
                        Another thing is that from domoticsz when i start a zone that zone start and previous is stopped but that status is not updated.
                        Thank you in advance.
                        P.S. I will post some pictures of the hardware build soon.
                        • rechin304R rechin304
                          Dear all,
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @rechin304
                          have you tried changing the eight to one?
                          #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
                          trigger all your relays with the same output.
                          • rechin304R
                            rechin304R
                            rechin304
                            Well, that's not the point.
                            I will have 4 zones that need different type of water needs. For example one zone will be with micro irrigation watering, another one with lawn sprinkler. i do not understand why not to start all zones at once and they will finish according to the time set and not to start one after other. Another thing is why to wait for a zone to finish when you trigger another one.
                            To start all valve at once when is trigger all zones i did change:
                            else if (state == RUN_ALL_ZONES)
                                if (lastValve != valveNumber)
                                  for (byte i = 0; i <= NUMBER_OF_VALVES; i++)
                                    if (i == 0 || i == valveNumber)
                                      gw.send(msg1valve.setSensor(i).set(true), false);
                                    else
                                      gw.send(msg1valve.setSensor(i).set(false), false);
                                lastValve = valveNumber;
                                fastToggleLed();
                                if (state != lastState)
                                  valveNumber = 1;
                                  updateRelays(ALL_VALVES_OFF);
                                  DEBUG_PRINTLN(F("State Changed, Running All Zones..."));
                                unsigned long nowMillis = millis();
                                if (nowMillis - startMillis < VALVE_RESET_TIME)
                                else if (nowMillis - startMillis < (allZoneTime[valveNumber] * 60000UL))
                                  updateRelays(BITSHIFT_VALVE_NUMBER);
                                else
                            with
                                    else
                                      gw.send(msg1valve.setSensor(i).set(true), false); //to update domoticz
                                fastToggleLed();
                                  valveNumber = 1;
                                  updateRelays(0); //all outputs will be on
                                else
                                      else
                                  fastToggleLed();
                                    valveNumber = 1;
                                  else
                              with
                                      else
                                  fastToggleLed();
                                    valveNumber = 1;
                                  else
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              I will have 4 zones that need different type of water needs. For example one zone will be with micro irrigation watering, another one with lawn sprinkler. i do not understand why not to start all zones at once and they wi finish according to the time set and not to start one after other. Another thing is why to wait for a zone to finish when you trigger another one.
                              I see your point an understand your questions. The purpose of zone cycling is to be able to have enough pressure in each zone independently while also having pressure for household use. Drawing water to every zone (in my case 9) makes the pressure so low, there may not be enough to open the individual pop-up valves, much less fill the washing machine.
                              The wait period (which you may set) is there to allow the time for hydraulic actuation of solenoid valves. These types of valves close slowly, and since they are in a manifold, the next valve to start opens faster if the water pressure at the manifold is allowed time to reach normal static pressure.
                              The beauty of open source is that you get to do it your way. If you have the pressure to run all your valves at the same time, with enough to spare to take a shower, then you are fortunate!
                              So, did you add another 'switch' to your controller to send the all zone command?
                              • rechin304R
                                rechin304R
                                rechin304
                                I did this so all relays on is ok now.
                                What i miss is to start individual zones more than once at a time :).
                                • rechin304R
                                  rechin304R
                                  rechin304
                                  wrote on last edited by rechin304
                                  #136
                                  Pictures of the case project and how is arranged inside. Not yet on the final location, still testing.
                                  5_1461396298101_IMG_3866.JPG 4_1461396298101_IMG_3865.JPG 3_1461396298101_IMG_3863.JPG 1_1461396298101_IMG_3861.JPG 0_1461396298101_IMG_3860.JPG
                                  k5mapK 1 Reply Last reply
                                  • David MoraD
                                    David MoraD
                                    David Mora
                                    Hi I just finished building my first project in arduino ( this one) but the code is too large now for the arduino memory its 32748 bytes could you please share with me the older version of the code / libraries to run it in code bender ?
                                    mfalkviddM petewillP 2 Replies Last reply
                                    • David MoraD David Mora
                                      @David-Mora's question was double-posted. See https://forum.mysensors.org/topic/3921/code-grew-larger-dan-promini/ for the other thread.
                                        petewillP
                                        petewillP
                                        petewill
                                        @David-Mora I responded to your comment on the YouTube video but I'll respond here as well just in case people are reading this thread instead.
                                        This is probably because debug is enabled in the MyConfig.h file. Please comment out this line: #define DEBUG
                                        Make sure to save the .h file then recompile the Arduino code. It should be around 25,342 bytes.
                                        • David MoraD
                                          David MoraD
                                          David Mora
                                          wrote on last edited by David Mora
                                          #140
                                          Hi Pete thank you very much, I am using mysensors online editor , not sure if I should edit that code?0_1463751590886_mysensors.jpg
