  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 675.9k Views 99 Watching
  • ben999B
    ben999B
    ben999
    wrote on last edited by ben999
    #441
    Guys,
    I am getting this in Karaf :
    16:20:33.171 [WARN ] [thome.io.rest.core.item.ItemResource] - Received HTTP PUT request at 'items/MySensorsDevice21_Lock' with an invalid item type 'Status'.
    and this in PaperUI
     "ERROR : undefined - undefined"  "some error occured"
    when trying to link "Lock status" of an rfid node to an item in PaperUI...
    Is that anything to do with the binding ? Or shall i ask eslewhere ?
    Thanks a lot for your help (in general as well ;) )
    • T TimO
      @Samuel235 said in openHAB 2.0 binding:
      In this case then i will have to wait for this release then as i can't achieve what i need to do with rules. Do we have any idea when the release will be?
      What is it, what you want to achieve? I'm running MQTT too, as a connection between OpenHAB2 and nodered (50% of my rules are now nodered based). My gateways are serial or ethernet based.
      serial / ethernet gateway
      OpenHAB2 binding
      MQTT Event bus
      nodered
      @Samuel235 Are you willing and have the ability to test the MQTT implementation of the binding? Any help is really appreciated!
      Samuel235
      @TimO - I have implemented a work-around for the issue that i was facing. OpenHAB just can't handle a empty MQTT message, so there is a fix for the pulse sensor to work with OpenHAB by changing the message that it send over to the MQTT server.
      If you're interested in how this is done, please refer to: https://forum.mysensors.org/topic/3088/pulse-power-meter-with-openhab/4
      I will be documenting this in possibly better to read steps for people when I get chance to finish the documentation to my new hardware node for the Pulse Sensor.
      MySensors 2.1.1
      • L LastSamurai
        @TimO Right, I guess thats the problem. I have written my sketch against domoticz, so it expects either a 6 bit hex string (rgb = e.g. ff00ff) or a 9 bit (idk why) rgbw hex string (e.g. #ff00ff00).
        According to the mysensors docu "ff00ff00" would be right, I guess.
        RVMRVMR
        RVMRVMR
        RVMRVM
        @LastSamurai
        Hello, i'am trying to connect a RGBW node by the serial gateway, is there already a solution for the hexstring format in the bindings or do we need to handle the rgbw items separatly ?
        kind regards
        Roger
        T 1 Reply Last reply
        • RVMRVMR RVMRVM
          @LastSamurai
          kind regards
          Roger
          TimO
          @RVMRVM could you give this one a try?
          https://github.com/tobof/openhab2-addons/issues/76
          It is not yet integrated into the main branch. If you could test it and give me some feedback I would be very grateful. :)
          M RVMRVMR 2 Replies Last reply
          • L
            L
            LastSamurai
            @RVMRVM Sorry I haven't had the time to test anything yet (was working on another project). Might take me a while to get to.
            • P patrick schaerer
              @TimO said:
              @bentrik said:
              I managed to find an addons directory in /usr/share/openhab2/addons, but I can´t find a way to copy the .jar file there, as I get permission denied both through WinSCP in sudo mode and terminal ssh. The folder has permission 0775.
              That is the correct directory if you installed OH2 via .deb. Seems like you are using a user in WinSCP that is not allowed to write to the directory above. To circumvent this:
              1. Copy the binding jar to /tmp.
              2. Login via ssh and execute:
              sudo cp /tmp/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar /usr/share/openhab2/addons/
              and
              sudo chmod openhab.openhab /usr/share/openhab2/addons/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
              OH2 is started/stopped/restarted with
              service openhab2 start/stop/restart
              To log into the karaf console do:
              ssh openhab@localhost -p 8101
              Password is: habopen
              Follow the guide/wiki from:
              In the console enter feature:install openhab-transport-serial
              I have installed openhab with the openhabian image. I could start the mysensors gateway too.
              I followed the github-openhab2 installation instructions.
              To this point
              I read a lot of posts on this thread but on get this error:
              openhab> install openhab-transport-serial
              Bundle IDs:
              Error executing command: Error installing bundles:
              	Unable to install bundle openhab-transport-serial
              the chmod line posted above doesn't work neither. chmod does not accept openhab.openhab
              I dont have any clue how to install the binding for openhab2 ... why isn't that possible from paperui :-(
              the trung
              @patrick-schaerer
              hi patrick
              i follow your guide with command to install MPC23017 Binding on openhab2
              sudo chmod openhab.openhab /usr/share/openhab2/addons/org.openhab.binding.mcp23017-1.9.0.jar
              but it not work and has information" chmod: invalid mode: ‘openhab.openhab’
              then i take ":" instead of "." into account like
              sudo chmod openhab:openhab /usr/share/openhab2/addons/org.openhab.binding.mcp23017-1.9.0.jar
              but it same error
              0_1496478264776_upload-ff8c1fc1-81fa-4e92-9e2d-46d4d7ca3f33
              can you help me, please.
              thanks you
              • T the trung
                @patrick-schaerer
                hi patrick
                but it same error
                thanks you
                TimO
                @the-trung This thread is OpenHAB and MySensors binding related. Better ask here: https://community.openhab.org
                In your case I suppose you need to switch chmod with chown. :)
                • carlylerC
                  carlylerC
                  carlyler
                  wrote on last edited by carlyler
                  #448
                  I am trying to make use of the customSensor using org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar I see the node 12 var4 message arrive but it is not being assigned to my item; am I doing something wrong? I have tried both string and number item types.
                  10:37:37.879 [DEBUG] [rsAbstractConnection$MySensorsReader] - 12;0;1;0;27;1023
                  10:37:37.880 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 12 found in gateway
                  10:37:37.881 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 12
                  10:37:37.882 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: var4(27) value to: 1023
                  10:37:37.896 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 12/0 to 2017-06-03T10:37:37.000-0400
                  10:37:37.901 [DEBUG] [rsAbstractConnection$MySensorsReader] - 12;255;3;0;22;63464
                  10:37:37.912 [INFO ] [marthome.event.ItemStateChangedEvent] - Sensor12LastUpdate changed from 2017-06-03T10:37:26.000-0400 to 2017-06-03T10:37:37.000-0400
                  10:37:37.925 [INFO ] [marthome.event.ItemStateChangedEvent] - mySMsg01 changed from 1;4;1;0;1;64.2 to 12;0;1;0;27;1023
                  10:37:37.935 [INFO ] [marthome.event.ItemStateChangedEvent] - mySMsg01 changed from 12;0;1;0;27;1023 to 12;255;3;0;22;63464
                  10:37:41.974 [DEBUG] [rsAbstractConnection$MySensorsReader] - 2;0;1;0;17;544
                  10:37:41.975 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 2 found in gateway
                  10:37:41.976 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 2
                  10:37:41.976 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: watt(17) value to: 544
                  10:37:41.984 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 2/0 to 2017-06-03T10:37:41.000-0400
                  10:37:41.995 [INFO ] [marthome.event.ItemStateChangedEvent] - watt01 changed from 547 to 544
                  10:37:42.005 [DEBUG] [rsAbstractConnection$MySensorsReader] - 2;0;1;0;24;1138982
                  10:37:42.006 [INFO ] [marthome.event.ItemStateChangedEvent] - Sensor02LastUpdate changed from 2017-06-03T10:37:27.000-0400 to 2017-06-03
                  Things
                  Bridge mysensors:bridge-eth:ethGatewayPi [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=200 ]
                     /** define things connected to that bridge here */
                     humidity         hum01       [ nodeId="1", childId="0" ]
                     temperature      temp01      [ nodeId="1", childId="1" ]
                     humidity         hum02       [ nodeId="1", childId="2" ]
                     temperature      temp02      [ nodeId="1", childId="3" ]
                     humidity         hum03       [ nodeId="1", childId="4" ]
                     temperature      temp03      [ nodeId="1", childId="5" ]
                     power            power01     [ nodeId="2", childId="0" ]
                     rgbLight         rgb02       [ nodeId="6", childId="0", requestAck=true ]
                     light            relay01     [ nodeId="7", childId="0", requestAck=true ]
                     motion           motion01    [ nodeId="8", childId="0", requestAck=true ]
                     motion           motion02    [ nodeId="9", childId="0", requestAck=true ]
                     light            relay02     [ nodeId="9", childId="1", requestAck=true ]
                     cover            cover03     [ nodeId="10", childId="0", requestAck=true, smartSleep=true ]
                     cover            cover02     [ nodeId="11", childId="0", requestAck=true, smartSleep=true ]
                     customSensor     blind01     [ nodeId="12", childId="0", requestAck=true, smartSleep=true ]
                     mySensorsMessage mySMsg01    [ nodeId="999", childId="999" ]
                  items:
                  String blind1BatReading	    "Blind#1 Battery A/D Reading"  	<battery>			{ channel="mysensors:customSensor:ethGatewayPi:blind01:var4" }
                  DateTime Sensor12LastUpdate "Last seen Nd12 [%1$ta %1$tT]"       <clock>    	{ channel="mysensors:customSensor:ethGatewayPi:blind01:lastupdate" }
                  edit 6/7: I stand corrected, the variables are being updated. I was fooled by the log. For some reason the log does not show the change the way it did it binding 2.0.0. I placed debug messages in my rules and they're updating.
                  • T TimO
                    matt shepherd
                    @TimO is it possible to configure using paper ui?
                    cheers
                    Matt
                    • T TimO
                      the trung
                      @TimO
                      I follow your guid and it's ok, then i checks karaf and see there 0_1496630110147_karaf2.png
                      is this mean i installed my binding?
                      and i have question
                      did you fix error : Unable to install bundle openhab-transport-serial
                      thanks you so much
                      • M matt shepherd
                        cheers
                        Matt
                        TimO
                        @matt-shepherd yes!
                        • carlylerC carlyler
                          Things
                          items:
                          TimO
                          @carlyler thank you for filing an issue, I'll look into it.
                          • T the trung
                            @TimO
                            and i have question
                            thanks you so much
                            TimO
                            @the-trung yes, the binding seems to be installed. Serial transport is needed for MySensors. I'm not able to answer questions about mcp binding.
                            • T TimO
                              RVMRVMR
                              RVMRVMR
                              RVMRVM
                              @TimO Hey Tim, before i start test , i have installed OH2.1 build #925 on 2 new W8 pc's.
                              download the org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar file and put it in the addons folder.
                              result:
                              2017-06-10 15:01:27.812 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
                              2017-06-10 15:01:27.922 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                              2017-06-10 15:01:28.031 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                              2017-06-10 15:01:28.250 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                              2017-06-10 15:01:28.281 [ERROR] [org.openhab.binding.mysensors ] - FrameworkEvent ERROR - org.openhab.binding.mysensors
                              org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [182]
                              Unresolved requirement: Import-Package: gnu.io
                              at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                              at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                              at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                              at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                              at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                              at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                              at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                              at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
                              i cannot start the mysensors binding ...
                              i have installed it on 3 diff pc's, same result , can you help mee with this, i'am stucked ..
                              thanks in advance
                              kind regards
                              andreacioniA 1 Reply Last reply
                              • RVMRVMR RVMRVM
                                result:
                                thanks in advance
                                kind regards
                                andreacioniA
                                andreacioniA
                                andreacioni
                                @RVMRVM
                                Did you run feature:install openhab-transport-serial, on OH console?
                                • RVMRVMR
                                  RVMRVMR
                                  RVMRVM
                                  Oh yes, i dit not, that was the problem, now i can start to test the RGB-RGBW , hope that i can run this
                                  thanks for the quit reaction
                                  Roger
                                  • T TimO
                                    RVMRVMR
                                    RVMRVMR
                                    RVMRVM
                                    wrote on last edited by RVMRVM
                                    #457
                                    @TimO Hello, i tried the RGB & RGBW , it looks ok but there are no commands that been send to the node and this for every item, a'im new in the openHab world, so that will be the problem.
                                    the result is the same for RGB & RGBW
                                    my .things file:
                                    Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.2.190", tcpPort=5003, sendDelay=200 ] {
                                    light:RGBW_23_Status [ nodeId="23", childId="0", requestAck=false]
                                    rgbwLight:RGBW_23_Color [ nodeId="23", childId="1", requestAck=false ]
                                    dimmer:RGBW_23_Dimmer [ nodeId="23", childId="2", requestAck=false ]
                                    my .items file:
                                    Group GF_Living "Living Room" <video> (gGF)
                                    /* Indoor Temperatures */
                                    //Number Temperature_GF_Living "Temperature [%.1f °C]" <temperature> (Temperature, GF_Living)
                                    Switch RGBW_23_Status "Living" (GF_Living, Lights) { channel="mysensors:bridge-eth:gateway:RGBW_23_Status"}
                                    Dimmer RGBW_23_Dimmer "Living" <slider> (GF_Living, Lights) ["Lighting"] { channel="mysensors:bridge-eth:gateway:RGBW_23_Dimmer"}
                                    Color RGBW_23_Color "RGBW Light" <colorwheel> {channel = "mysensors:bridge-eth:gateway:RGBW_23_Color"}
                                    and my .sitemap file
                                    sitemap rvms label="test rvms"
                                    Frame label="RGBW Living" {
                                    Switch item=RGBW_23_Status label="Button Switch" mappings=[ON="on",OFF="off"]
                                    Slider item=RGBW_23_Dimmer switchSupport
                                    Colorpicker item=RGBW_23_Color
                                    as result we have:
                                    0_1497172964239_upload-df31d06d-cc9b-47df-9583-831a701cdeed
                                    and in the paperUI:
                                    0_1497173108301_upload-088cd943-2a85-4ad4-9197-b76b075f4ffe
                                    this is what the log-file shows:
                                    2017-06-11 09:50:48.187 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
                                    2017-06-11 09:50:51.161 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.items'
                                    2017-06-11 09:50:52.088 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.sitemap'
                                    2017-06-11 09:50:52.187 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rvms.things'
                                    2017-06-11 09:50:52.978 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                                    2017-06-11 09:50:53.006 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                                    2017-06-11 09:50:53.073 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                                    2017-06-11 09:50:53.404 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                                    2017-06-11 09:50:53.555 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                                    2017-06-11 09:50:53.558 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                                    2017-06-11 09:55:56.976 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'rvms.things'
                                    2017-06-11 09:55:56.988 [WARN ] [rsAbstractConnection$MySensorsWriter] - Interrupted MySensorsWriter
                                    2017-06-11 09:55:56.989 [WARN ] [rsAbstractConnection$MySensorsReader] - Interrupted MySensorsReader
                                    2017-06-11 09:55:58.010 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                                    2017-06-11 09:55:58.020 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                                    2017-06-11 10:08:57.483 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'rvms.sitemap'
                                    so what is wrong here ?
                                    thanks in advance
                                    Roger
                                    • FusedHe3F
                                      FusedHe3F
                                      FusedHe3
                                      Hi @TimO,
                                      I also tried the RGB Light and it seems to be working! (I am using Maghac's RGB LED strip sketch)
                                      Auto discovery worked instantly. I did have to work with the .items file to get the color picker instead of a text input. I also get these two errors every time I send a command:
                                      16:57:36.770 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'rgbLight01' received command 124,89,100
                                      16:57:36.809 [INFO ] [marthome.event.ItemStateChangedEvent] - rgbLight01 changed from 359,91,100 to 124,89,100
                                      16:57:37.117 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 2 not present
                                      16:57:37.222 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 3 not present
                                      As I'm relatively new to MySensors, I was wondering if it is normal that the RGB Light Sensor channel is used for this. Or is this just temporary until an actual RGB channel is made?
                                        matt shepherd
                                        I've been trying to figure this out for a while. For me openhab discovers 4 things Red, Green, Blue and Status. These are all dimmers and I can't get them all to work together as 1 colour wheel? They all work really well independently but that's as far as I got. I've also tried the .items file but with no luck.
                                        carlylerC 1 Reply Last reply
                                        • D
                                          D
                                          doctor64
                                          Hello!
                                          I just started to play with OpenHab2 and new binding? thank you for great work.
                                          But, i discover some strange behavior:
                                          Openhab2, ethernet gateway, 3 mysensor nodes, all nodes sucessfully detected and configured in PaperUI, but some data looks like not updated. Looking to log i note some suspicious lines like:
                                          00:28:47.077 [DEBUG] [rsAbstractConnection$MySensorsReader] - 3;1;1;0;0;24.6
                                          00:28:47.078 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 3 found in gateway
                                          00:28:47.078 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 1 found in node 3
                                          00:28:47.078 [WARN ] [rs.internal.gateway.MySensorsGateway] - Variable 0 not present
                                          Sorry, i don't know how to dump OpenHab configuration, but item configured.
                                          Any suggestions?
