  3. My Ugly ESP GW Prototype
34 Posts 18 Posters 20.3k Views 8 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @NeverDie
    Looks interesting. However, it's probably a bit more complicated to use for newcommers, as it's not arduino compatible (not yet anyways).
    NeverDieN 1 Reply Last reply
    • tbowmoT tbowmo
      @NeverDie
      NeverDieN
      NeverDieN
      #22
      @tbowmo said:
      @NeverDie
      Good point. Also, the Photon already has header pins soldered on, and not having that means extra work.
      I think I'm persuaded that, at least for now, the Photon can justify its higher price.
      What's the best board to dock it into? Or is it simply roll-you-own with female headers on some prototyping board?
      Sparkfun will have a Photon redboard, but at $39.95....
      • tbowmoT
        tbowmoT
        tbowmo
        @NeverDie
        Is Photon compatible with Arduino? (the build eco system). That is one of the key elements of mysensors at the moment, and what makes it accessible for newcommers.
        If not then everything needs to be ported to another build system..
        BulldogLowellB NeverDieN 2 Replies Last reply
        • tbowmoT tbowmo
          @NeverDie
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          It is "Arduino-like" for sure, but a little different in that it's implementation is still developing. I've done a few projects with Photon, including (vera controlled) LED projects and sensors. There are some differences so you may find it rough at first (particularly with the availability of Libraries).
          Probably a great add-on to your sensor network if you are more experienced with Arduino.
          Like MySensors, they have a terrific forum!
          PS, comparable to the EMW3165, the P1 version of photon is $10
          • tbowmoT tbowmo
            @NeverDie
            NeverDieN
            NeverDieN
            @tbowmo said:
            @NeverDie
            Glad you brought this up.
            • rvendrameR
              rvendrameR
              rvendrame
              @tekka said:
              I'm running the GW sketch (and repeater node) natively on the ESP8266 - however, the porting needs some additional work on EEPROM handling and pointer addressing. Also, a stable power supply is important (>3.1V with ESP8266 and NRF24 attached, no peaks). Will post more as porting progresses.
              Would mind to share your sketch for the ESP8266 + WiFi+GW + nRF24 ? If I understood correctly --- the ESP can run the mySensors GW + regular Wi-fi, replacing the arduino? Any other downside than the EEPROM ?
              Thanks!
              ESP8266 GW + mySensors 2.3.2
              Alexa / Google Home
              tekkaT 1 Reply Last reply
              • rvendrameR rvendrame
                Thanks!
                tekkaT
                tekkaT
                tekka
                @rvendrame yes, ESP8266 + nRF24L01 = GW. However, build is currently unstable and WIP.
                • rvendrameR
                  rvendrameR
                  rvendrame
                  @tekka, ok got it. I just managed to run my serial GW on my media-player computer (using a serial to ethernet program), so I now I finally have my kind of ethernet GW. Thanks!
                  Alexa / Google Home
                  barduinoB 1 Reply Last reply
                    barduinoB
                    barduinoB
                    barduino
                    @rvendrame said:
                    @tekka, ok got it. ... so I now I finally have my kind of ethernet GW. Thanks!
                    NodeJS?
                    • rvendrameR
                      rvendrameR
                      rvendrame
                      @barduino , I have Vera as controller. And I have a old mac mini which is my media player / nas / voip / etc... I just installed the .99c TCP2Serial on it, and plugged my serial gateway. It is working like a charm.
                      Alexa / Google Home
                      • Daniel OliveiraD
                        Daniel OliveiraD
                        Daniel Oliveira
                        Hi @hek and everyone,
                        I'm starting to get really interested in knowing more about these ESP8266 litle things but after some "googling" I still didn't figured out one thing. I already saw some projects to use an ESP alone as a GW (with a RF24 module attached) but is it not possible to have a MySensor's network of only ESPs?
                        One ESP as GE and multiple others as sensor nodes? Why?
                        Thank you all in advance,
                        Daniel
                        MySensors rules my home :)
                          Most probably possible once someone get library running on it.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @Daniel-Oliveira
                            If you were to make a sensor network only with ESP8266, you don't need mysensors (as I see it). It has network capabilities by itself (wifi), so you could actually just connect them to your existing wifi network (or create a new one with an old router).
                            One thing though, they probably will use more current, compared to nrf24 / rfm69. Unless you can power up/down the module. But then you'll have latency time when connecting to the wifi, before sending the actual sensor values.
                            But besides that, it should be possible to make some sort of sensor network with the ESP only..
                            • Lucas FiggL
                              Lucas FiggL
                              Lucas Figg
                              Does anyone have any working examples of Sensebender Micro working with a Photon? I have all the parts but finding it difficult to unravel all GW libs and so on. I just want to use my sensebender with a Onewire waterproof temp sensor and for it to report back to the Photon every 5 minutes or so.
