  3. Scene Controller problem
15 Posts 4 Posters 5.5k Views 1 Watching
  • V
    V
    vampircik
    Hello. I can`t run the script via the display controller. Sketch Good but apart from a white screen got nothing. pumped some examples from the library screen gives all the colors, examples of good work but this DEPT nehochet which I downloaded from http://www.mysensors.org/build/scene_controller
    • V
      V
      vampircik
      • V
        V
        vampircik
          Mabe you could add some Serial.prinln("DEBUG MESSAGE") to see where it fails?
          • V
            V
            vampircik
            monitor usb Serial.prinln. I inserted and nothing happens
            • V
              V
              vampircik
              AWIA 1 Reply Last reply
              • V vampircik
                AWIA
                AWIA
                AWI
                @vampircik Try setting the baud rate to 115200 to get any info on the serial port... (unless you changed the baud rate in the sketch). From what I see in the screen dump you are typing "serial.println" in the serial monitor. I guess what @hek meant was to add Serial.println() messages in the the sketch you are running.. ;-)
                • V
                  V
                  vampircik
                  Serial.println() messages why?
                  • mikeeM
                    mikeeM
                    mikee
                    I had same problem with mega (clone) - tried to program relay and temp node on mega - all over "check wire", and when i switched to uno did compile.
                    • V
                      V
                      vampircik
                      I installed on Megu examples from libraries all work on the screen shows all. but this sketch nehochet.I wanted to know.
                        The error message you see means that mysensors-library is unable to initialise the radio. Did you enabled soft-spi according to the instructions on the build page?
                        • V
                          V
                          vampircik
                          I need to do with these files?MySensors / утилиты / RF24_config.h. I know a little something but there is a great desire to understand.
                          • V
                            V
                            vampircik
                            how to turn it on SOFTSPI in RF24_config.h.?
                              To enable soft-spi you just have to edit RF24_config.h which can be found in your XXX/libraries/MySensors/utility folder. Just remove the commented slashes (//) before "#define SOFTSPI".
                              NOTE: This change must be reverted back when you have compiled and uploaded code to your scene controller. The normal sensors don't need SOFTSPI enabled.
                              • V
                                V
                                vampircik
                                Thanks it worked. you are super
