  3. Here's how to verify the clock frequency on your Pro Mini
1 Posts 1 Posters 1.4k Views 1 Watching
  • NeverDieN
    NeverDieN
    I received some 8Mhz Pro Mini's, and I wanted to verify that they are indeed 8Mhz.
    Here's a test procedure that worked for me using an oscilliscope:
    1. Connect ground of test Probe to ground of Pro Mini
    2. Power up the Pro Mini
    3. Touch test probe to PB6 or PB7 of the mcu:
      and you will get this, which verifies the frequency:
      For some reason I was expecting a square wave, so I compared it to a 16Mhz Pro Mini from a different vendor:
      and that one wasn't a square wave either, as you can see.
    Regardless, I wanted to test frequency, and this worked for doing that.
