  3. Ethernet Gateway - Using an Arduino UNO
2 Posts 1 Posters 1.8k Views 1 Watching
  • N
    N
    Newzwaver
    Hi
    Wondering if anyone has used an UNO for the gateway? Does anything change? I am using the ENC28J60 and made the change as follows;
    #include <UIPEthernet.h> // Use this if you have attached a Ethernet ENC28J60 shields
    I also used the default IP address and programed it into the vera, am I missing something?
    I changed from the serial gateway and that worked perfect, I wanted to use the UNO as I have more of them and I was told the Ethernet gateway worked better.
    Any help would be greatly appreciated.
    • N
      N
      Newzwaver
      The error I get is as follows; and I am using U17 and NRF24L01. I have power to the UNO as well.
      MySensors plugin : Cannot send command - communications error
      ERROR : Error in lua for scenes and events Not sure if this is related to this or my calendar issue.
