  3. Turning off connected ArduCAM
8 Posts 3 Posters 4.8k Views 3 Watching
  • OitzuO
    OitzuO
    Oitzu
    I have this nice spi camera ArduCAM Mini connected to a 3.3V arduino pro mini.
    I would like to turn it off while the camera is not needed to save energy. (The low-power mode is not enough, it still drains about 40mA in low-power.)
    Normally i would connect a n-channel mosfet (like the 2N7000) to the low-side of the Camera module.
    The problem is: The module is, despite the mosfet "turned off", still draining about 20mA over the datalines to the arduino.
    Does any one know a nice solution to switch the camera off on the "high side"?
    (Probably a combination of an n and p-channel mosfet will do it?)
    PS: The camera module also runs on 3.3V.
    • 5546dug5
      5546dug5
      5546dug
      @Oitzu
      While I can't
      Help you this
      Is
      A
      Way
      Cool project!
      Is it running well and how do you get the pictures from the cam to the ? My sensors/ computer?
      • AnticimexA
        AnticimexA
        Anticimex
        If you look in one of my schematics, I use a "high side" power toggle (see the "Optional MYSX 3.3V power toggle" box). You could probably use that type of design to toggle the power to the camera module. I use a single P-MOS (datasheet) with a pullup on the gate to keep the transistor closed by default, and enable it by pulling the gate low from the MCU. The transistor is especially designed for a low Rds(on) so it should be enough with only one.
        • OitzuO
          OitzuO
          Oitzu
          @5546dug see http://forum.mysensors.org/topic/1668/sending-image-data-over-the-mysensors-network/9
          I'm using a serial gateway connected to an raspberry pi with a perl script as "custom controller".
          Running well atm but is still a little bit slow.
          @Anticimex said:
          If you look in one of my [schematics]...
          Ah. Thanks, this looks exactly like what i need. Do you happen to know a similiar P-MOS in a through-hole technology package? (like to 220/92)
          AnticimexA 1 Reply Last reply
          • OitzuO Oitzu
            AnticimexA
            AnticimexA
            Anticimex
            @Oitzu sorry no, I never considered those packages.
            • OitzuO
              OitzuO
              Oitzu
              @Anticimex because i don't know any better...
              Would this also work?
              • OitzuO Oitzu
                AnticimexA
                AnticimexA
                Anticimex
                @Oitzu it should work just fine.
                • OitzuO
                  OitzuO
                  Oitzu
                  Thanks. Ordered this. :+1:
