  3. My Slim 2AA Battery Node
498 Posts 71 Posters 584.5k Views 69 Watching
  • siodS siod
    I've set up two sensors with 2 reed switches and 1 HTU21D attached. When I was testing them around 60 cm away from my gateway they worked very fine. Now I moved them to their final destination which is around 8-10 meters away from the gateway and now they don't reach the gateway anymore. Any idea what could cause this? Any way to increase the range?
    W
    W
    wergeld
    @siod
    Is there any obstruction between the nodes and the gateway? Trees, walls, etc? Depending on what is in between the radios you can dramatically lose signal.
    • siodS
      siodS
      siod
      wrote on last edited by siod
      #342
      each one goes around a corner and so one wall is partly between the nodes and the gateway and it´s not even concrete. I have one node in my basement attached to an arduino nano and I have no range problems...
      The batteries are all fully loaded.
      edit:
      I would like to post my Node sketch as well as my gateway sketch and MyConfig.h. Maybe there is some optimization potential:
      Node sktech:
      // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
      #define MY_RADIO_NRF24 //MySensor Library auf NRF24 Funkmodul einstellen, muss vor MySensor.h Initialisierung geschehen
      // Define Node ID
      #define MY_NODE_ID 4
      //Batterysensor
      int oldBatteryPcnt = 0;
      #define CHILD_ID_BATT 7
      //Kontaktschalter
      //#include <Bounce2.h>
      #define CHILD1_ID 1 // Kontaktschalter 1
      #define CHILD2_ID 2 // Kontaktschalter 2
      #define BUTTON1_PIN  2  // Kontaktschalter 1
      #define BUTTON2_PIN  3  // Kontaktschalter 2
      int oldValueReed1=-1;
      int oldValueReed2=-1;
      //Tempsensor
      #include <SparkFunHTU21D.h>
      #include <Wire.h>
      #define CHILD_ID_HUM 3
      #define CHILD_ID_TEMP 4
      unsigned long SLEEP_TIME = 900000; // Sleep time between reads (in milliseconds)
      //tempsensor
      HTU21D myHumidity;
      float lastTemp;
      float lastHum;
      //boolean metric = true;
      //Messages
      //Battery
      MyMessage msgbatt(CHILD_ID_BATT,V_VOLTAGE);
      // Kontaktschalter
      MyMessage msgReed1(CHILD1_ID,V_TRIPPED); // Kontaktschalter 1
      MyMessage msgReed2(CHILD2_ID,V_TRIPPED); // Kontaktschalter 2
      //TempMessage
      //Presentation; present sensors to gateway!
      void presentation(){
        sendSketchInfo("Küche Messstation", "2.0", true);
        present(CHILD1_ID, S_DOOR);
        present(CHILD2_ID, S_DOOR);
        //Tempsensor
        present(CHILD_ID_HUM, S_HUM);
        //metric = getConfig().isMetric;
        //Battery
        present(CHILD_ID_BATT,V_VOLTAGE);
      //Setup
        //Serial.begin(9600);
        Serial.println("Hello!");
        //Batterysensor
         analogReference(INTERNAL1V1);
      #else
         analogReference(INTERNAL);
      //Tempsensor
        Serial.println("Setting up TempSensor...");
        myHumidity.begin();
        Serial.println("...done!");
      // Setup Kontaktschalter 1
        pinMode(BUTTON1_PIN,INPUT);
          // Activate internal pull-up
        digitalWrite(BUTTON1_PIN,HIGH);
      // Setup Kontaktschalter 2
        pinMode(BUTTON2_PIN,INPUT);
        digitalWrite(BUTTON2_PIN,HIGH);
      //Starte den Loop
        //Batterysensor
        // get the battery Voltage
        delay(1000);
         #ifdef DEBUG
         float batteryV  = sensorValue * 0.003363075;
         #ifdef DEBUG
         Serial.print(batteryV);
         Serial.println(" V");
         Serial.print(batteryPcnt);
         Serial.println(" %");
           // Power up radio after sleep
           sendBatteryLevel(batteryPcnt,true);
           send(msgbatt.set(batteryPcnt),true);
           oldBatteryPcnt = batteryPcnt;
        //Kontakstschalter 1
        sleep(10);
        // Get the update value
        int valueReed1 = digitalRead(BUTTON1_PIN);
        if (valueReed1 != oldValueReed1) {
           // Send in the new value
           send(msgReed1.set(valueReed1==HIGH ? 1 : 0),true);
           Serial.println("Button 1 geschaltet");
           oldValueReed1 = valueReed1;
        //Kontakstschalter 2
        int valueReed2 = digitalRead(BUTTON2_PIN);
        if (valueReed2 != oldValueReed2) {
           send(msgReed2.set(valueReed2==HIGH ? 1 : 0),true);
           Serial.println("Button 2 geschaltet");
           oldValueReed2 = valueReed2;
       //Tempsensor
      Serial.println("Starte Messung...");
          float temp = myHumidity.readTemperature();
        if (isnan(temp)) {
        } else if (temp != lastTemp) {
          lastTemp = temp;
          send(msgTemp.set(temp, 1),true);
          Serial.print("T: ");
          Serial.println(temp);
       float humd = myHumidity.readHumidity();
        if (isnan(humd)) {
        } else if (humd != lastHum) {
            lastHum = humd;
            send(msgHum.set(humd, 1),true);
            Serial.print("H: ");
            Serial.println(humd);
       Serial.println("Sleep...");
       sleep(BUTTON1_PIN - 2, CHANGE, BUTTON2_PIN - 2, CHANGE, SLEEP_TIME); //sleep a bit
      Gateway sketch:
      // Set this nodes subscripe and publish topic prefix
      // Set MQTT client id
      //#define MY_W5100_SPI_EN 4
      // radio on the same spi bus.
        #define MY_SOFTSPI
      #ifndef MY_RF24_CE_PIN
        #define MY_RF24_CE_PIN 5
      #ifndef MY_RF24_CS_PIN
        #define MY_RF24_CS_PIN 6
      #define MY_IP_ADDRESS 192,168,1,51
      #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
      #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 50
      #define MY_PORT 1883
      // Flash leds on rx/tx/err
      #define MY_LEDS_BLINKING_FEATURE
      // Set blinking period
      // Enable inclusion mode
      #include <Ethernet.h>
      void presentation() {
        // Send locally attech sensors data here
      MyConfig.h
       * @file MyConfig.h
       * MySensors specific configurations
      #ifndef MyConfig_h
      #define MyConfig_h
      #include <stdint.h>
      *  Serial and debug options
      // Enable MY_DEBUG in sketch to show debug prints. This option will add a lot to the size of the
      // final sketch but is helpful to see what is actually is happening during development
      //#define MY_DEBUG
      // Enable MY_SPECIAL_DEBUG in sketch to activate I_DEBUG messages if MY_DEBUG is disabled.
      // I_DEBUG requests are:
      // R: routing info (only repeaters): received msg XXYY (as stream), where XX is the node and YY the routing node
      // V: CPU voltage
      // F: CPU frequency
      // M: free memory
      // E: clear MySensors EEPROM area and reboot (i.e. "factory" reset)
      //#define MY_SPECIAL_DEBUG
      // Enable MY_DEBUG_VERBOSE_SIGNING flag for verbose debug prints related to signing.
      // Requires DEBUG to be enabled.
      // This will add even more to the size of the final sketch!
      //#define MY_DEBUG_VERBOSE_SIGNING
      // Enable this in sketch if you want to use TX(1), RX(0) as normal I/O pin
      //#define MY_DISABLED_SERIAL
      // Enable MY_CORE_ONLY flag if you want to use core functions without loading the framework
      //#define MY_CORE_ONLY
      // Turn off debug if serial pins is used for other stuff
      #ifdef MY_DISABLED_SERIAL
      #undef MY_DEBUG
       * @def MY_BAUD_RATE
       * @brief Serial output baud rate (debug prints and serial gateway speed).
      #ifndef MY_BAUD_RATE
      #define MY_BAUD_RATE 115200
      // Disables over-the-air reset of node
      //#define MY_DISABLE_REMOTE_RESET
      *  Radio selection and node config
      // Selecting uplink transport layer is optional (for a gateway node).
      //#define MY_RADIO_NRF24
      //#define MY_RS485
      * @def MY_TRANSPORT_SANITY_CHECK
      * @brief If enabled, node will check transport in regular intervals to detect HW issues and re-initialize in case of failure. This feature is enabled for all repeater nodes (incl. GW)
      //#define MY_TRANSPORT_SANITY_CHECK
      * @def MY_TRANSPORT_SANITY_CHECK_INTERVAL
      * @brief Interval (in ms) of transport sanity checks
      #ifndef MY_TRANSPORT_SANITY_CHECK_INTERVAL
      #define MY_TRANSPORT_SANITY_CHECK_INTERVAL ((uint32_t)60000)
       * @def MY_REGISTRATION_FEATURE
       * @brief If enabled, node has to register to gateway/controller before allowed to send sensor data.
      #define MY_REGISTRATION_FEATURE
       * @def MY_REGISTRATION_RETRIES
       * @brief Number of registration retries if no reply received from GW/controller
      #ifndef MY_REGISTRATION_RETRIES
      #define MY_REGISTRATION_RETRIES 3
       * @def MY_REGISTRATION_DEFAULT
       * @brief Node registration default - this applies if no registration response is recieved from controller
      #define MY_REGISTRATION_DEFAULT true
       * @def MY_REGISTRATION_CONTROLLER
       * @brief If enabled, node registration request has to be handled by controller
       // #define MY_REGISTRATION_CONTROLLER
       * @def MY_CORE_COMPATIBILITY_CHECK
       * @brief If enabled, library compatibility is checked during node registration. Incompatible libraries are unable to send sensor data.
      #define MY_CORE_COMPATIBILITY_CHECK
       * @def MY_NODE_ID
       * @brief Node id defaults to AUTO (tries to fetch id from controller).
      #ifndef MY_NODE_ID
      #define MY_NODE_ID AUTO
       * @def MY_PARENT_NODE_ID
       * @brief Node parent defaults to AUTO (tries to find a parent automatically).
      #ifndef MY_PARENT_NODE_ID
      #define MY_PARENT_NODE_ID AUTO
       * @def MY_PARENT_NODE_IS_STATIC
       * @brief Enable MY_PARENT_NODE_IS_STATIC to disable fall back if parent node fails
      //#define MY_PARENT_NODE_IS_STATIC
      // Enables repeater functionality (relays messages from other nodes)
      // #define MY_REPEATER_FEATURE
       * @def MY_SMART_SLEEP_WAIT_DURATION
       * @brief The wait period before going to sleep when using smartSleep-functions.
       * This period has to be long enough for controller to be able to send out
       * potential buffered messages.
      #ifndef MY_SMART_SLEEP_WAIT_DURATION
      #define MY_SMART_SLEEP_WAIT_DURATION 500
      *  Over the air firmware updates
      // Enable MY_OTA_FIRMWARE_FEATURE in sketch to allow safe over-the-air firmware updates.
      // This feature requires external flash and the DualOptiBoot boot-loader.
      // Note: You can still have OTA FW updates without external flash but it
      // requires the MYSBootloader and disabled MY_OTA_FIRMWARE_FEATURE
      //#define MY_OTA_FIRMWARE_FEATURE
       * @def MY_OTA_FLASH_SS
       * @brief Slave select pin for external flash.
      #ifndef MY_OTA_FLASH_SS
      #define MY_OTA_FLASH_SS 8
       * @def MY_OTA_FLASH_JDECID
       * @brief Flash jdecid.
      #ifndef MY_OTA_FLASH_JDECID
      #define MY_OTA_FLASH_JDECID 0x1F65
      *  Gateway config
       * @def MY_GATEWAY_MAX_RECEIVE_LENGTH
       * @brief Max buffersize needed for messages coming from controller.
      #ifndef MY_GATEWAY_MAX_RECEIVE_LENGTH
      #define MY_GATEWAY_MAX_RECEIVE_LENGTH 100
       * @def MY_GATEWAY_MAX_SEND_LENGTH
       * @brief Max buffer size when sending messages.
      #ifndef MY_GATEWAY_MAX_SEND_LENGTH
      #define MY_GATEWAY_MAX_SEND_LENGTH 120
       * @def MY_GATEWAY_MAX_CLIENTS
       * @brief Max number of parallel clients (sever mode).
      #ifndef MY_GATEWAY_MAX_CLIENTS
      #define MY_GATEWAY_MAX_CLIENTS 1
      *  Information LEDs blinking
      // This feature enables LEDs blinking on message receive, transmit
      // or if some error occurred. This was commonly used only in gateways,
      // but now can be used in any sensor node. Also the LEDs can now be
      // disabled in the gateway.
      // The following setting allows you to inverse the blinking feature MY_LEDS_BLINKING_FEATURE
      // When MY_WITH_LEDS_BLINKING_INVERSE is enabled LEDSs are normally turned on and switches
      // off when blinking
      // The following defines can be used to set the port pin, that the LED is connected to
      // If one of the following is defined here, or in the sketch, MY_LEDS_BLINKING_FEATURE will be
      // enabled by default. (Replace x with the pin number you have the LED on)
      //#define MY_DEFAULT_ERR_LED_PIN x
      //#define MY_DEFAULT_TX_LED_PIN x
      //#define MY_DEFAULT_RX_LED_PIN x
      *  Gateway inclusion button/mode configuration
      // Enabled inclusion mode feature
      // Enables inclusion-mode button feature on the gateway device
      // Disable inclusion mode button if inclusion mode feature is not enabled
      #ifndef MY_INCLUSION_MODE_FEATURE
      #undef MY_INCLUSION_BUTTON_FEATURE
       * @def MY_INCLUSION_MODE_BUTTON_PIN
       * @brief The default input pin used for the inclusion mode button.
      #ifndef MY_INCLUSION_MODE_BUTTON_PIN
      	#if defined(ARDUINO_ARCH_ESP8266)
      		#define MY_INCLUSION_MODE_BUTTON_PIN 5
      	#else
       * @def MY_INCLUSION_MODE_DURATION
       * @brief Number of seconds (default one minute) inclusion mode should be enabled.
      #ifndef MY_INCLUSION_MODE_DURATION
       * @def MY_INCLUSION_BUTTON_PRESSED
       * @brief The logical level indicating a pressed inclusion mode button.
      #if defined(MY_INCLUSION_BUTTON_EXTERNAL_PULLUP)
      #define MY_INCLUSION_BUTTON_PRESSED HIGH
      #else
      #define MY_INCLUSION_BUTTON_PRESSED LOW
      *  Message Signing Settings
       * @def MY_SIGNING_ATSHA204
       * @brief Enables HW backed signing functionality in library.
       * For any signing related functionality to be included, this define or @ref MY_SIGNING_SOFT has to be enabled.
      //#define MY_SIGNING_ATSHA204
       * @def MY_SIGNING_SOFT
       * @brief Enables SW backed signing functionality in library.
       * For any signing related functionality to be included, this define or @ref MY_SIGNING_ATSHA204 has to be enabled.
      //#define MY_SIGNING_SOFT
       * @def MY_SIGNING_REQUEST_SIGNATURES
       * @brief Enable this to inform gateway to sign all messages sent to this node.
       * If used for a gateway, gateway will only request signatures from nodes that in turn
       * request signatures from gateway.
      //#define MY_SIGNING_REQUEST_SIGNATURES
       * @def MY_VERIFICATION_TIMEOUT_MS
       * @brief Define a suitable timeout for a signature verification session
       * Consider the turnaround from a nonce being generated to a signed message being received
       * which might vary, especially in networks with many hops. 5s ought to be enough for anyone.
      #ifndef MY_VERIFICATION_TIMEOUT_MS
      #define MY_VERIFICATION_TIMEOUT_MS 5000
       * @def MY_SIGNING_NODE_WHITELISTING
       * @brief Enable to turn on whitelisting
       * When enabled, a signing node will salt the signature with it's unique signature and nodeId.<br>
       * The verifying node will look up the sender in a local table of trusted nodes and
       * do the corresponding salting in order to verify the signature.<br>
       * For this reason, if whitelisting is enabled on one of the nodes in a sign-verify pair, both
       * nodes have to implement whitelisting for this to work.<br>
       * Note that a node can still transmit a non-salted message (i.e. have whitelisting disabled)
       * to a node that has whitelisting enabled (assuming the receiver does not have a matching entry
       * for the sender in it's whitelist). The whitelist to use is defined as the value of the flag.
      //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
       * @def MY_SIGNING_ATSHA204_PIN
       * @brief Atsha204 default pin setting
       * Pin where ATSHA204 is attached
      #ifndef MY_SIGNING_ATSHA204_PIN
      #define MY_SIGNING_ATSHA204_PIN 17
       * @def MY_SIGNING_SOFT_RANDOMSEED_PIN
       * @brief Pin used for random generation in soft signing
       * Do not connect anything to this when soft signing is enabled
      #ifndef MY_SIGNING_SOFT_RANDOMSEED_PIN
      #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
      *  RS485 Driver Defaults
       * @def MY_RS485_BAUD_RATE
       * @brief The RS485 BAUD rate.
      #ifndef MY_RS485_BAUD_RATE
      #define MY_RS485_BAUD_RATE 9600
       * @def MY_RS485_MAX_MESSAGE_LENGTH
       * @brief The maximum message length used for RS485.
      #ifndef MY_RS485_MAX_MESSAGE_LENGTH
      #define MY_RS485_MAX_MESSAGE_LENGTH 40
      *  NRF24L01P Driver Defaults
      // Enables RF24 encryption (all nodes and gateway must have this enabled, and all must be personalized with the same AES key)
      //#define MY_RF24_ENABLE_ENCRYPTION
       * @def MY_DEBUG_VERBOSE_RF24
       * @brief Enable MY_DEBUG_VERBOSE_RF24 flag for verbose debug prints related to the RF24 driver. Requires DEBUG to be enabled.
      //#define MY_DEBUG_VERBOSE_RF24
       * @def MY_RF24_SPI_MAX_SPEED
       * @brief MY_RF24_SPI_MAX_SPEED to overrule default nRF24L01+ SPI speed.
      //#define MY_RF24_SPI_MAX_SPEED 4000000
       * @def MY_RF24_CE_PIN
       * @brief Default RF24 chip enable pin setting. Override in sketch if needed.
      		#define MY_RF24_CE_PIN 4
      	#elif defined(ARDUINO_ARCH_SAMD)
      		#define MY_RF24_CE_PIN 27
      	#else
      		#define MY_RF24_CE_PIN 9
       * @def MY_RF24_CS_PIN
       * @brief Default RF24 chip select pin setting. Override in sketch if needed.
      		#define MY_RF24_CS_PIN 15
      		#define MY_RF24_CS_PIN 3
      	#else
      		#define MY_RF24_CS_PIN 10
       * @def MY_RF24_PA_LEVEL
       * @brief Default RF24 PA level. Override in sketch if needed.
      #ifndef MY_RF24_PA_LEVEL
       * @def MY_RF24_CHANNEL
       * @brief RF channel for the sensor net, 0-125.
       * Frequence: 2400 Mhz - 2525 Mhz Channels: 126
       * http://www.mysensors.org/radio/nRF24L01Plus.pdf
       * 0 => 2400 Mhz (RF24 channel 1)
       * 1 => 2401 Mhz (RF24 channel 2)
       * 76 => 2476 Mhz (RF24 channel 77)
       * 83 => 2483 Mhz (RF24 channel 84)
       * 124 => 2524 Mhz (RF24 channel 125)
       * 125 => 2525 Mhz (RF24 channel 126)
       * In some countries there might be limitations, in Germany for example only the range 2400,0 - 2483,5 Mhz is allowed
       * http://www.bundesnetzagentur.de/SharedDocs/Downloads/DE/Sachgebiete/Telekommunikation/Unternehmen_Institutionen/Frequenzen/Allgemeinzuteilungen/2013_10_WLAN_2,4GHz_pdf.pdf
      #ifndef MY_RF24_CHANNEL
      #define MY_RF24_CHANNEL	76
       * @def MY_RF24_DATARATE
       * @brief RF24 datarate (RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps or RF24_2MBPS for 2Mbps).
      #ifndef MY_RF24_DATARATE
      #define MY_RF24_DATARATE RF24_250KBPS
       * @def MY_RF24_BASE_RADIO_ID
       * @brief RF24 radio network identifier.
       * This acts as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
      #ifndef MY_RF24_BASE_RADIO_ID
      #define MY_RF24_BASE_RADIO_ID 0x00,0xFC,0xE1,0xA8,0xA8
       * @def MY_RF24_ADDR_WIDTH
       * @brief RF24 address width.
       * This defines the width of the base address.
      #ifndef MY_RF24_ADDR_WIDTH
      #define MY_RF24_ADDR_WIDTH 5
       * @def MY_RF24_SANITY_CHECK
       * @brief RF24 sanity check to verify functional RF module
       * This reads back and compares configuration registers. Disable if using non-P modules
      #define MY_RF24_SANITY_CHECK
      // Enable SOFTSPI for NRF24L01, useful for the W5100 Ethernet module
      //#define MY_SOFTSPI
       * @def MY_SOFT_SPI_SCK_PIN
       * @brief Soft SPI SCK pin.
      #ifndef MY_SOFT_SPI_SCK_PIN
       * @def MY_SOFT_SPI_MISO_PIN
       * @brief Soft SPI MISO pin.
      #ifndef MY_SOFT_SPI_MISO_PIN
       * @def MY_SOFT_SPI_MOSI_PIN
       * @brief Soft SPI MOSI pin.
      #ifndef MY_SOFT_SPI_MOSI_PIN
      *  RFM69 Driver Defaults
       * @def MY_RFM69_FREQUENCY
       * @brief RFM69 frequency to use (RF69_433MHZ for 433MHz, RF69_868MHZ for 868MHz or RF69_915MHZ for 915MHz).
       * This must match the hardware version of the RFM69 radio.
      #ifndef MY_RFM69_FREQUENCY
      #define MY_RFM69_FREQUENCY   RF69_868MHZ
       * @def MY_IS_RFM69HW
       * @brief Enable this if you're running the RFM69HW model.
      //#define MY_IS_RFM69HW
       * @def MY_RFM69HW
       * @brief Set to true if @ref MY_IS_RFM69HW is set.
      #ifdef MY_IS_RFM69HW
      	#define MY_RFM69HW true
      #else
      	#define MY_RFM69HW false
       * @def MY_RFM69_NETWORKID
       * @brief RFM69 Network ID. Use the same for all nodes that will talk to each other.
      #ifndef MY_RFM69_NETWORKID
      #define MY_RFM69_NETWORKID     100
       * @def MY_RF69_IRQ_PIN
       * @brief RF69 IRQ pin.
      #ifndef MY_RF69_IRQ_PIN
      #define MY_RF69_IRQ_PIN RF69_IRQ_PIN
       * @def MY_RF69_SPI_CS
       * @brief RF69 SPI chip select pin.
      #ifndef MY_RF69_SPI_CS
      #define MY_RF69_SPI_CS RF69_SPI_CS
       * @def MY_RF69_IRQ_NUM
       * @brief RF69 IRQ pin number.
      #ifndef MY_RF69_IRQ_NUM
      		#define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
      	#else
      		#define MY_RF69_IRQ_NUM RF69_IRQ_NUM
      // Enables RFM69 encryption (all nodes and gateway must have this enabled, and all must be personalized with the same AES key)
      //#define MY_RFM69_ENABLE_ENCRYPTION
      * Ethernet Gateway Transport  Defaults
      // The gateway options available
      //#define MY_GATEWAY_W5100
      //#define MY_GATEWAY_ENC28J60
      //#define MY_GATEWAY_ESP8266
       * @def MY_PORT
       * @brief The Ethernet TCP/UDP port to open on controller or gateway.
      #ifndef MY_PORT
      #define MY_PORT 5003
      // Static ip address of gateway (if this is disabled, DHCP will be used)
      //#define MY_IP_ADDRESS 192,168,178,66
      // Enables UDP mode for Ethernet gateway (W5100)
      //#define MY_USE_UDP
       * @def MY_IP_RENEWAL_INTERVAL
       * @brief DHCP, default renewal setting in milliseconds.
      #ifndef MY_IP_RENEWAL_INTERVAL
      #define MY_IP_RENEWAL_INTERVAL 60000
       * @def MY_MAC_ADDRESS
       * @brief Ethernet MAC address.
       * This needs to be unique on the network.
      #ifndef MY_MAC_ADDRESS
      #define MY_MAC_ADDRESS 0xAD, 0xAD, 0xBE, 0xAD, 0xFE, 0xED
      // Controller ip-address, if this is defined, gateway will act as a client trying to contact controller on MY_PORT.
      // If MY_CONTROLLER_IP_ADDRESS is left un-defined, gateway acts as server allowing incoming connections.
      //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
       * @defgroup MyLockgrp MyNodeLock
       * @ingroup internals
       * @brief The node lock feature is a security related feature. It locks a node that suspect itself for being
       * under some form of attack.
       * This is achieved by having a counter stored in EEPROM which decrements when suspicious activity is detected.
       * If the counter reaches 0, node will not work anymore and will transmit a @ref I_LOCKED message to the
       * gateway/controller with 30m intervals. Payload is a string with a reason for the locking.
       * The string is abbreviated to accomodate a signature. The following abbreviations exist at the moment:
       * - LDB (Locked During Boot)
       * - TMNR (Too Many Nonce Requests)
       * - TMFV (Too Many Failed Verifications)
       * Typically, the counter only decrements when suspicious activity happens in a row.
       * It is reset if legit traffic is present.
       * Examples of malicious activity are:
       * - Repeatedly incorrectly checksummed OTA firmware
       * - Repeated requests for signing nonces without properly signed messages arriving
       * - Repeatedly failed signature verifications
       * If counter reaches zero, node locks down and EEPROM has to be erased/reset to reactivate node.
       * Node can also be unlocked by grounding a pin (see @ref MY_NODE_UNLOCK_PIN).
       * The size of the counter can be adjusted using @ref MY_NODE_LOCK_COUNTER_MAX.
       * @def MY_NODE_LOCK_FEATURE
       * @brief Enable this to activate intrusion prevention mechanisms on the node.
      //#define MY_NODE_LOCK_FEATURE
       * @def MY_NODE_UNLOCK_PIN
       * @brief By grounding this pin durig reset of a locked node, the node will unlock.
       * If using a secure bootloader, grounding the pin is the only option to reactivate the node.
       * If using stock Android bootloader or a DualOptiBoot it is also possible to download a sketch
       * using serial protocol to erase EEPROM to unlock the node.
      #ifndef MY_NODE_UNLOCK_PIN
      #define MY_NODE_UNLOCK_PIN 14
       * @def MY_NODE_LOCK_COUNTER_MAX
       * @brief Maximum accepted occurances of suspected malicious activity in a node.
       * Counter decrements on reoccuring incidents but resets if legitimate behaviour is identified.
      #ifndef MY_NODE_LOCK_COUNTER_MAX
      #define MY_NODE_LOCK_COUNTER_MAX 5
      /** @}*/ // Node lock group
      // Doxygen specific constructs, not included when built normally
      // This is used to enable disabled macros/definitions to be included in the documentation as well.
      #if DOXYGEN
      edit2:
      Now I get this this from the node on my gateway´s serial monitor:
      0;255;3;0;9;TSP:MSG:READ 4-4-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;TSP:MSG:BC
      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=4)
      0;255;3;0;9;TSP:CHKUPL:OK
      0;255;3;0;9;TSP:MSG:GWL OK
      0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
      0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
      0;255;3;0;9;TSP:SANCHK:OK
      and so on...
      edit: I restarted my gateway and the nodes, it is working for a while, but after 1 or 2 days 1 or more nodes freeze. Does anybody else have equal problems?
      still learning...
      • carlekiC
        carlekiC
        carleki
        I have ordered the 2.0 boards, they are on their way to my home :)
        I'm plannign to use them as :
        • temperature node
        • door sensor
        For the door sensor, can you tell me if I'm good :
        I have to use a 1MOhm resistor between the pin of atmega and one wire of the reed switch ? So I will have the longest battery life (my atmegas are burned at 1 Mhz or 8 Mhz)
        Am I right ?
        m26872M 1 Reply Last reply
        • carlekiC carleki
          • temperature node
          • door sensor
          Am I right ?
          m26872M
          m26872M
          m26872
          @carmelo42
          Thanks for your support by ordering. I actually recieved another 50+ share credit transfer from DirtyPCBs today. It'll be donated to MySensors right away.
          If you look at post 116 you'll see the I used a 10Mohm pull-up between Vcc and atmega input pin. Reed switch connects between Gnd and input pin.
          carlekiC 1 Reply Last reply
          • m26872M m26872
            @carmelo42
            carlekiC
            carlekiC
            carleki
            @m26872 said:
            @carmelo42
            Thanks to you for providing us theses files :)
            Ok, my mistake (I juste received my 10 MOhm resistor ;)
            Perfect, I just have to wait now for the little yellow packet ;)
            • carlekiC
              carlekiC
              carleki
              I have received yesterday my little packet from DirtyPCB :)
              11 PCBs, so 33 sensors :)
              I'm just wondering where the C5 capactior will go on the board .. Can't figure out :(
              J 1 Reply Last reply
              • carlekiC carleki
                J
                J
                jeti
                wrote on last edited by jeti
                #347
                @carmelo42: maybe this helps, all Cs and the R assembled!
                • J jeti
                  J
                  J
                  jeti
                  ups... C5 is also not there on my board,it shoud be parallel to C4!
                  • J jeti
                    carlekiC
                    carlekiC
                    carleki
                    is your sensor working without C5 ?
                    • carlekiC
                      carlekiC
                      carleki
                      @m26872 is it possible to send the sketch in the atmega on board ? using an FTDI serial/usb ?
                      • carlekiC carleki
                        J
                        J
                        jeti
                        @carmelo42 yes
                        • J jeti
                          @carmelo42 yes
                          carlekiC
                          carlekiC
                          carleki
                          @jeti said:
                          @carmelo42 yes
                          I have this serial/usb adapter :
                          https://img1.picload.org/image/ldrrddg/deekrobot-isp.png
                          Can you tell me how I connect it to my node ? (noob question I guess ... but I don't want to burn my node :( )
                          • carlekiC carleki
                            @jeti said:
                            @carmelo42 yes
                            carlekiC
                            carlekiC
                            carleki
                            @carmelo42 said:
                            @jeti said:
                            @carmelo42 yes
                            I have found the answer myself with the schematic ;)
                            Have you ever tried to power the node with 1 x CR2032 battery ?
                            I have tried, but the node doesn't send anything further than 5 meters ...
                            • siodS
                              siodS
                              siod
                              I would like to know if your nodes are working all fine. I have the problem that my nodes freeze after a day or sometimes after a week.
                              still learning...
                              • siodS siod
                                carlekiC
                                carlekiC
                                carleki
                                @siod my temperature nodes work good, but my relay one doesn't work :'(
                                Do you have any logs when it freezes ?
                                • siodS
                                  siodS
                                  siod
                                  @carmelo42 no, unfortunately I don´t have any logs, any idea how to create logs?
                                  still learning...
                                  • siodS siod
                                    carlekiC
                                    carlekiC
                                    carleki
                                    maybe if you keep your node connected to your computer with USB to serial adapter ?
                                    • siodS
                                      siodS
                                      siod
                                      mmh, no, that would mean I would have to run my computer for maybe 2 weeks 24/7...
                                      I guess it has somehting to do with the sleep function, the device seems to nat wake up after a while for some reason
                                      still learning...
                                      • dpressleD
                                        dpressleD
                                        dpressle
                                        wrote on last edited by dpressle
                                        #359
                                        So i got the boards and build them and they work perfect.
                                        One thing i couldn't figure out is why do i get relatively high current consumption, when the node is sleeping i get 1.5mA and not 5.8uA as in mentioned in this post.
                                        I use 8MHz internal clock and the sleep function and nothing is connected to the node.
                                        Can someone help?
                                        AWIA 1 Reply Last reply
                                        • dpressleD dpressle
                                          Can someone help?
                                          AWIA
                                          AWIA
                                          AWI
                                          @dpressle Can you post the sketch?
