  3. How to mill a PCB at Home!
11 Posts 6 Posters 8.2k Views 3 Watching
  • Frank HerrmannF Offline
    Frank Herrmann
    wrote on last edited by Frank Herrmann
    Hey Friends,
    i'm proud to present my small VideoSessions (2) to describe the complete process to mill a PCB with chilipeppr. I hope you like it? Comments are welcome!
    This Playlist describe the process (Eagle + Chilipeppr + Prepare CNC + Mill on CNC) on my CNC (eShapeoko) to made a PCB with Chilipeppr and GRBL.
    https://youtu.be/pfTT7T0mfBE
    https://youtu.be/KeY3bZJbtm0
    Y 1 Reply Last reply
    • S Offline
      thx for share. very nice vids :smiley:
      • N Offline
        N Offline
        NotYetRated
        @Frank-Herrmann said:
        eShapeoko
        Awesome vid! Now I need to look in to that eShapeoko!
        • Frank HerrmannF Frank Herrmann
          Hey Friends,
          Y Offline
          Y Offline
          my CNC (eShapeoko)
          That seems like a very affordable CNC! Didn't know it existed until you wrote about it.
          Did you order it as a kit?
            Frank Herrmann
            Yes i got this (nice) machine last year from this shop. It's a kind of shapeoko2. The guy work hard, but he has to much orders. I guess a small xcarve are also ok. But i have to warn you, it's not a cheap hobby :)
            Here some machines they could mill PCB's:
            http://www.ebay.de/itm/CNC-3040T-DQ-Graviermaschine-Gravurmaschine-Graviergeraet-Engraver-Engraving-MILL-/271920866786 (IMHO the best for PCB milling)
            https://www.inventables.com/technologies/x-carve
            • L Offline
              L Offline
              Lars65
              I did build my own CNC mill. It's build of MDF and I use ballscrews from Ebay, also tracks from Ebay, motors and so on. I am not even close to the price of what that will costs. I can mill on a surface as big as 1100x800mm. I mill in wood, plastic and even PCB boards. To mill PCB and some plastic have I build a vacuum board driven by a standard vacuum cleaner.
              It's really fun project. Now mine is finished , but I do upgrades time to time.
              Frank HerrmannF 1 Reply Last reply
              • L Lars65
                Frank Herrmann
                Same by me, now i can mill my PCB's and i want to make a solder dispenser/pick and place header. my Dream, build a Header he can:
                • mill a double side PCB
                • put the solder paste drops to PCB
                • put the (smd) components on PCB
                I'll add this features to chilipeppr :)
                lars, can we see some photos from your machine and maybe a foto from a milled PCB?
                • L Offline
                  L Offline
                  Lars65
                  wrote on last edited by Lars65
                  Here is my CNC mill, when i mill PCB boards do I use a plastic sheet, and have an opening just for the PCB board. I also use a 60 degree engraving bit, and mill to a depth of 0,145mm. The vacuum table do mill of about 1 tenth of a mm, time to time so I know that it's 100% flat. No need to probe more than to find the top of the PCB
                  The spindle is 1kw aircold, so I can't run it below 6000rpm Max speed is 24 000 rpm.
                  • L Offline
                    L Offline
                    Lars65
                    More info about milling. I use a software "designsparks" to draw the PCB. From Designspark do I export the file as an gerber file *.gbr. Next do I open the *.gbr in an another software "CamBam", this is the software to create the *.nc file for the mill. In this do I set up what tools I will use in the mill, also what cutting speed, and spindle speed.
                    Anyone interested of building a mill, you have a load of websites on the internet. Ebay is also a good source of buying things, but you need to have study what things you buy. Stepper motors for the X,Y and Z movements there is standards like NEMA 17, NEMA 24 etc. But some suppliers sell not so good motors, so reading forums and study is a really good thing to do.
                    • L Offline
                      L Offline
                      Lars65
                      Engraving the PCB
                      https://www.youtube.com/watch?v=CyfzYnQ8BGI&feature=youtu.be
                      Drilling the PCB
                      https://www.youtube.com/watch?v=VYDVqSGmoBQ&feature=youtu.be
                      Software I use:
                      Designspark This do I use to draw the PCB and it's a free software.
                      Cambam is the software I use to produce G-code to my CNC. This is not free, but you can run up to 500 raws of code.
                      This is my vacuum table.
                      This is a finnished PCB, a serial gaway.
                      This is the finnished gatway up and running.
                      • M Offline
                        M Offline
                        Martin Tellblom
                        Hi all,
                        Just bought a little CNC + Laser engraver machine that I'm going to use for PCB milling and have some questians for the experienced users.
                        @Frank-Herrmann will your Chillipeppr code work on all arduino/gcode based CNC routers?
                        Any other free software like BamCam for use will small projects?
                        What cutting bits are you using for PCB milling?
                        MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
