  3. Your workshop :)
Your workshop :)
183 Posts 36 Posters 108.1k Views 28 Watching
  • M Matt
    OK here's mine.
    Samuel235
    @Matt, i generally keep my chainsaw downstairs away from my electronics. I can't have the oil everywhere!
    MySensors 2.1.1
    M 1 Reply Last reply
    • S Samuel235
      Matt
      @Samuel235 yeah the Dolmar leaks, I think its a design feature. Problem is I live with three drunken monkeys who are entropy impersonated, as such I cant keep anything inside if I want to find it again.
      • YveauxY Yveaux
        @AWI said:
        a universal component tester 11 Euro..
        And click ;-)
        AWIA
        AWIA
        AWI
        wrote on last edited by AWI
        #83
        @Yveaux An updated version ... this one generates PWM, measure frequency and even measures DS18B20 / DHT..
        YveauxY 1 Reply Last reply
        • J
          J
          Jan Gatzke
          I am especially proud of my 20 years old analog soldering station. :D
          • J Jan Gatzke
            YveauxY
            YveauxY
            @Jan-Gatzke said in Your workshop :):
            I have the exact same one! :+1:
            However, it's not in use anymore :flushed:
            J 1 Reply Last reply
            • YveauxY Yveaux
              J
              J
              Jan Gatzke
              @Yveaux
              I just bought a new soldering iron for it last year. Had to google for days to find spare parts. :D
              • AWIA AWI
                YveauxY
                YveauxY
                @AWI said in Your workshop :):
                An updated version
                Kicken!
                  wrote on last edited by gohan
                  #88
                  Im thinking about getting this thing, do you think it may be useful ?
                  dbemowskD 1 Reply Last reply
                    dbemowskD
                    dbemowskD
                    @gohan That looks very much like the one that @AWI posted previously in the thread only with a nice case and a color display. The one he posted is quite a bit cheaper. I may get one myself and just 3D print a case for it. I can use your link for the 3D case design.
                    http://s.click.aliexpress.com/deep_link.htm?dl_target_url=http%3A%2F%2Fwww.aliexpress.com%2Fitem%2FNew-2016-12864-LCD-Transistor-Tester-Capacitance-ESR-Meter-Diode-Triode-MOS-NPN-LCR-Mega328%2F32579390679.html&aff_short_key=e2Vzr3v
                    • dbemowskD
                      dbemowskD
                      Just looked on ebay, and here is one a bit cheaper that comes with a basic case.
                      http://www.ebay.com/itm/LCR-T4-Mega328-Transistor-Tester-Diode-Triode-Capacitance-ESR-Meter-MOS-NPN-PNP-/222247985900?var=&hash=item33bf0322ec:m:mLakYynk0RqdZT62qrYQfdw
                        if you want the case it costs 10$. The one I posted it seems to have pretty much the same specs, but it can detect also IR and probably some more components. It also comes with a lithium battery instead of the classic 9V, color screen and the case looks much better :)
                        J AWIA 2 Replies Last reply
                          J
                          J
                          Jan Gatzke
                          @gohan You are right. I just ordered the thing. With the case and the builtin battery it looks like a real tool. The price seems to be a promotion. Normal price is >30$.
                          You shoult by the way fix the link. Makes it easier for others to order it.
                          I am looking for a soldering vise. Has anyone tested this one: https://www.amazon.de/dp/B00196RV9C/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2COJS1QZ6SUVJ&coliid=IQEGMI1GM2R46 ?
                            Fixed the link; anyway it is a recurring promotion because I have seen that price for quite a while :)
                              J
                              J
                              Jan Gatzke
                              @gohan Then you can safely lean back and wait for my review. ;)
                                @Jan-Gatzke
                                I have something similar on my workbench. Very useful.
                                  nice wall decoration for a workshop :P :D
                                    @gohan
                                    I didn't select the wallpaper.... :woman: :kissing_closed_eyes:
                                    • J Jan Gatzke
                                      YveauxY
                                      YveauxY
                                      #98
                                      @Jan-Gatzke I have this one:
                                      0_1494092799058_upload-26847c60-5afa-46a8-85f7-ece57c9b7960
                                      It's able to hold all kinds of PCB sizes and can rotate easily.
                                      Tip for soldering through-hole components from the back without them falling out:
                                      Place all components on the top of the PCB and put a sponge or scotch-brite on top of them. Fix to the PCB with some rubber bands and swap the PCB to solder!
                                      • YveauxY Yveaux
                                        J
                                        J
                                        Jan Gatzke
                                        @Yveaux I saw that thing on Amazon. There was a review saying the brackets would melt easily when using hot air. Did you use this with hot air?
                                        • J Jan Gatzke
                                          YveauxY
                                          YveauxY
                                          When you clamp a PCB in it only the edges are held by the plastic brackets.
                                          Unless you are blowing directly on the edge of the PCB where it is held I can imagine this could be a problem, but then, why don't you shift or rotate the PCB to get away from the brackets?
                                          Yes
