  3. combining scripts almost finished but with a fault I don't see.
2 Posts 2 Posters 1.1k Views 3 Watching
  • Remco van GeelR
    Remco van GeelR
    Remco van Geel
    I tried to combine some scripts. first I had a 4 in 1: dht22, motion sensor and lux. Now I wanted to add a ds1820 for temperatur of warm water.
    the idea is to send every 2 a 3 minutes all readings to domoticz. execpt motion that must be immediately.
    this is my script:
    #include <DHT.h>
    #include <BH1750.h>
    #include <Wire.h>
      #include <OneWire.h>
      #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
      #define ONE_WIRE_BUS 5
      #define MAX_ATTACHED_DS18B20 1
    #define CHILD_ID_LIGHT 0
    #define CHILD_ID_TEMP2 5
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_MOT 2   // Id of the sensor child
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4
    BH1750 lightSensor;
    DHT dht;
    int numSensors=0;
    boolean metric = true;
    float lastTemp;
    float lastHum;
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
    MyMessage msgTemperature(CHILD_ID_TEMP2,V_TEMP);
    uint16_t lastlux;
      sensors.begin();
      gw.begin();
      gw.sendSketchInfo("Temp/Temp/Humidity/Motion/Lux", "1.0");
      gw.present(CHILD_ID_TEMP2, S_TEMP);
      gw.present(CHILD_ID_MOT, S_MOTION);
      gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
        lightSensor.begin();
      // Read digital motion value
      Serial.println(tripped);
      gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("Temp: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("Hum: ");
          Serial.println(humidity);
        uint16_t lux = lightSensor.readLightLevel();// Get Lux value
        if (lux != lastlux) {
          gw.send(msg.set(lux));
          lastlux = lux;
      Serial.print("lux: ");
        Serial.println(lux);
      // Ds1820
        gw.process();
        gw.sleep(conversionTime);
            #if COMPARE_TEMP == 1
            #else
            Serial.print("DS1820: ");
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    and this is the serial output:
    send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
    send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    sensor started, id=1, parent=0, distance=1
    send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=25,sg=0,st=ok:Temp/Temp/Humidity/Motion
    send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    send: 1-1-0-0 s=5,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
    send: 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 1-1-0-0 s=2,c=0,t=1,pt=0,l=0,sg=0,st=ok:
    send: 1-1-0-0 s=0,c=0,t=16,pt=0,l=0,sg=0,st=ok:
    send: 1-1-0-0 s=2,c=1,t=16,pt=0,l=1,sg=0,st=ok:0
    send: 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:22.9
    Temp: 22.90
    send: 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:41.8
    Hum: 41.80
    send: 1-1-0-0 s=0,c=1,t=23,pt=3,l=2,sg=0,st=ok:984
    lux: 984
    send: 1-1-0-0 s=2,c=1,t=16,pt=0,l=1,sg=0,st=ok:1
    send: 1-1-0-0 s=0,c=1,t=23,pt=3,l=2,sg=0,st=ok:977
    lux: 977
    send: 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:41.9
    Hum: 41.90
    send: 1-1-0-0 s=0,c=1,t=23,pt=3,l=2,sg=0,st=ok:979
    lux: 979
    Hum: 41.80
    send: 1-1-0-0 s=0,c=1,t=23,pt=3,l=2,sg=0,st=ok:978
    lux: 978
    Hum: 41.90
    lux: 977
    send: 1-1-0-0 s=2,c=1,t=16,pt=0,l=1,sg=0,st=fail:1
    send: 1-1-0-0 s=0,c=1,t=23,pt=3,l=2,sg=0,st=ok:660
    lux: 660
    send: 1-1-0-0 s=0,c=1,t=23,pt=3,l=2,sg=0,st=fail:593
    lux: 593
    what is wrong?
      The output looks fine to me. Is there anything wrong? Values for all sensors are presented and the values look good.
