  3. Domoticz cannot see devices from my sensors
8 Posts 3 Posters 3.1k Views 3 Watching
  • B
    B
    bbrowaros
    Hi All,
    I'm compleatly new to mysensors however I've read a lot about this. Now decided to create my own mysensors network with domoticz and attached ethernet GW (on raspberrypi) using NRF24 modules.
    I've got a succesful GW and configuration in domoticz and I've created my own first node with simple soil moisture sensor.
    Now I see the node in the domoticz gui and I see its detected correctly, passing data:
    Now all looks to be good. Domoticz is receiving data presentation of the node is also ok but domoticz is not presenting device which I can add. Actually I don't see any device from Mysensor GW (or Mysensors GW in the device list).
    Is there anything which I'm doing wrong? I think this is a simple mistake but I've spent almost 4h figuring out that my radio was badly connected so I'm out of ideas. Any suggestion would be welcome.
    • B bbrowaros
      Hi All,
      @piotr-piwonski welcome to the forum!
      Have the nodes sent any data yet? Domoticz doesn't display devices until they have sent their first data. Presenting is not enough.
      • B
        B
        bbrowaros
        wrote on last edited by bbrowaros
        Thanks for the welcome :)
        Yep it did send data. If you look closer at the V_LEVEL you see 8. When I see changes on the node serial monitor and refresh domoticz it the V_LEVEL reflects the changes. So looks like the data are sent and parsed by GW and Domoticz.
          ok. Sorry I didn't notice.
          This is what my humidity sensors look like
          I am using S_HUM and V_HUM instead. But according to https://www.mysensors.org/controller Domoticz should support S_MOISTURE.
          I don't want to derail this thread, but how come you have more than 7,000 devices in Domoticz?
          • B
            B
            bbrowaros
            I've got also 433 RFlink attached to the same domoticz. Most of the devices are fantoms on that RF433 link.
            This is also why I want to move to Mysensors and NRF24 modules.
            I'll try tomorrow change my nodes to use a S_HUM and V_HUM.
            • P
              P
              pjr
              wrote on last edited by pjr
              @bbrowaros Have you enabled: "Accept new devices" from settings?
              • B
                B
                bbrowaros
                @pjr that was it. I've disabled it due to 433 link and the noise which was generating and forgot about it. Thanks all for help.
                • P
                  P
                  pjr
                  @bbrowaros It has happened to me so many times that it was easy to guess :D
