  3. Can't see devices in Domoticz(Newbie)
6 Posts 2 Posters 2.9k Views 4 Watching
  • uncensoredU
    uncensoredU
    uncensored
    I have a problem with seeing my nodes as devices in Domoticz.
    I can see them in my hardware setup but not in my devices. Maybe I missed something?
    Got a clone nano as gateway and a clone uno as sensor node just for testing. I'm going to run it on a rpi but for now it is on my laptop.
    I hope someone here can help me out.
    Thank you,
    Nick
    AWIA 1 Reply Last reply
    • uncensoredU uncensored
      Thank you,
      Nick
      AWIA
      AWIA
      AWI
      @uncensored you need to receive some information from the sensor before it shows up in Domoticz.
      If you are not sure, please post some more information, like serial log of the node.
      • uncensoredU
        uncensoredU
        uncensored
        well the only log i can find is the log of domoticz, don't know if you mean that. can you maybe tell me where i can find the serial log of the node?
        016-09-30 13:32:23.862 Domoticz V3.4834 (c)2012-2016 GizMoCuz
        2016-09-30 13:32:23.864 Build Hash: 8398125, Date: 2016-03-02 08:43:51
        2016-09-30 13:32:23.887 Sunrise: 07:43:00 SunSet:19:20:00
        2016-09-30 13:32:23.887 EventSystem: reset all events...
        2016-09-30 13:32:23.892 Active notification subsystems: (0/11)
        2016-09-30 13:32:23.893 WebServer(HTTP) started on address: :: with port 8080
        2016-09-30 13:32:24.136 WebServer(SSL) started on address: :: with port 443
        2016-09-30 13:32:24.137 Proxymanager started.
        2016-09-30 13:32:24.138 Starting shared server on: :::6144
        2016-09-30 13:32:24.139 TCPServer: shared server started...
        2016-09-30 13:32:24.139 RxQueue: queue worker started...
        2016-09-30 13:32:24.329 Incoming connection from: 127.0.0.1
        2016-09-30 13:32:26.147 EventSystem: reset all events...
        2016-09-30 13:32:26.149 EventSystem: reset all device statuses...
        2016-09-30 13:32:26.150 EventSystem: Started
        2016-09-30 13:32:27.194 MySensors: Using serial port: COM5
        2016-09-30 13:32:28.681 MySensors: Gateway Ready...
        2016-09-30 13:32:28.760 MySensors: Gateway Version: 2.0.0
        2016-09-30 13:33:03.650 MySensors: Node: 1, Sketch Name: TemperatureAndHumidity
        2016-09-30 13:33:03.660 MySensors: Node: 1, Sketch Version: 1.1
        strange thing is that he can't see my Temperature and Humidity sensor but only when i reboot the arduino of the sensor.
        Thank you for the fast reply!
        greetings,
        Nick
          greetings,
          Nick
          AWIA
          AWIA
          AWI
          @uncensored From this log I can read that "Node 1" presents itself but no values are sent. That could be the reason for not showing the devices. At least the node is connecting to the Gateway.
          The "serial log" can be found when you connect the node via USB and look at the arduino serial monitor . Something like below. Also post your sketch and include it in code marks:
          0_1475236182167_upload-3b58db87-fbb5-4553-a7e6-bc35d79aea46
          TSM:INIT
          TSM:RADIO:OK
          TSP:ASSIGNID:OK (ID=90)
          TSM:FPAR
          TSP:MSG:SEND 90-90-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSP:MSG:READ 3-3-90 s=255,c=3,t=8,pt=1,l=1,sg=0:1
          TSP:MSG:FPAR RES (ID=3, dist=1)
          TSP:MSG:PAR OK (ID=3, dist=2)
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=90)
          TSM:UPL
          TSP:PING:SEND (dest=0)
          TSP:MSG:SEND 90-90-3-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
          TSP:MSG:READ 0-3-90 s=255,c=3,t=25,pt=1,l=1,sg=0:2
          TSP:MSG:PONG RECV (hops=2)
          TSP:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          • uncensoredU
            uncensoredU
            uncensored
            Well... I did the arduino monitor but got something strange... Not at all what you have...
            And i just got the code from mysensors. only needed to download the DHT.h library, got it from mysensorsarduinoexamples zip file.
            Thank You for helping me. Must be frustrating helping a total newbie :sweat_smile:
             * Version 1.0: Henrik EKblad
            // Enable debug prints
            //#define MY_RS485
            #include <DHT.h>
            #define DHT_DATA_PIN 2
            #define SENSOR_TEMP_OFFSET 0
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            float lastTemp;
            float lastHum;
            uint8_t nNoUpdatesTemp;
            uint8_t nNoUpdatesHum;
            bool metric = true;
            DHT dht;
              sendSketchInfo("TemperatureAndHumidity", "1.1");
              present(CHILD_ID_HUM, S_HUM);
              metric = getConfig().isMetric;
              dht.readSensor(true);
              if (isnan(temperature)) {
                lastTemp = temperature;
                if (!metric) {
                // Reset no updates counter
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                Serial.print("T: ");
                Serial.println(temperature);
              } else {
                nNoUpdatesTemp++;
              if (isnan(humidity)) {
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                Serial.print("H: ");
                Serial.println(humidity);
              } else {
                nNoUpdatesHum++;
              sleep(UPDATE_INTERVAL);
            • uncensoredU
              uncensoredU
              uncensored
              got it, had to change symbol rate
              i gues there is something wrome with my sensor...
              TSM:INIT
              TSM:RADIO:OK
              TSP:ASSIGNID:OK (ID=1)
              TSM:FPAR
              TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
              TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
              TSP:MSG:PAR OK (ID=0, dist=1)
              TSM:FPAR:OK
              TSM:ID
              TSM:CHKID:OK (ID=1)
              TSM:UPL
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
              TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
              TSP:MSG:PONG RECV (hops=1)
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
              TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
              TSP:MSG:READ 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=ok:TemperatureAndHumidity
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
              TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
              TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
              Request registration...
              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
              TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
              Node registration=1
              Init complete, id=1, parent=0, distance=1, registration=1
