  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 209.5k Views 36 Watching
    #21
    @minscof got an answer in this thread: http://forum.mysensors.org/topic/2367/pigatewayserial-using-interrupts/3
    The high cpu usage will go away as soon as you start your controller (or something else that reads from the tty the gateway creates).
    • E
      E
      Eawo
      Is it possible to use NRF24L01+PA+LNA Antenna version or is it to power hungry? Do i have to change something in the code?
      • G
        G
        georgep56
        @Eawo If you look at the excellent original post from @mfalkvidd above:
        The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required.
        I don't believe that you will need to make any changes to code.
        • E
          E
          Eawo
          wrote on last edited by Eawo
          #24
          My friend also started with mysensors and i gave him my old raspberry with the 26 pin gpio. Can he also use this guide? Also if it possible how do u wire it? Im just a beginner so i ask stupid questions. maybe serial gateway is the way to go but we are waiting for arduino's
            @Eawo Yes, it should work. I ran Domoticz and MySensors Gateway on my Raspberry Pi 1 when I first tried MySensors. If I remember correctly I had to connect CE to pin 15 instead of 22 but I am not sure why. Try using the same connections as on your Raspberry Pi 2 first, and switch CE pin if you get "check wires". Please report back here how it goes, so I can add the necessary information to the original post.
            • OitzuO
              OitzuO
              Oitzu
              I get stuff like
              read: 2-2-0 s=255,c=0,t=17,pt=0,l=3:1.5
              send: 2-194-1-0 s=255,c=0,t=17,pt=0,l=3,st=fail:1.5
              read: 2-2-0 s=255,c=3,t=6,pt=1,l=1:0
              send: 2-194-1-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
              read: 2-2-0 s=1,c=1,t=2,pt=2,l=2:1
              send: 2-194-1-0 s=1,c=1,t=2,pt=2,l=2,st=fail:1
              from 'PiGatewaySerial' but no results on the Serial Port. Any idea what i'm doing wrong?
              • OitzuO
                OitzuO
                Oitzu
                Somehow the node thought it is node id 194 and a repeater...
                I hacked in node id 0 and it worked. But it even works slower then the arduino serial gateway.
                  In http://forum.mysensors.org/topic/2305/nrf24l01-rpi2-direct-connection-problem/1 an user also got node id 194. Maybe the discussion there can help?
                  • J
                    J
                    jpbabou
                    wrote on last edited by jpbabou
                    #29
                    Hi
                    something is missing..
                    Is there a problem with the repository
                    Tks a lot for your job!
                    pi@domoticjp ~ $ sudo git clone https://github.com/mysensors/Raspberry.git
                    Cloning into 'Raspberry'...
                    remote: Counting objects: 273, done.
                    remote: Compressing objects: 100% (3/3), done.
                    remote: Total 273 (delta 0), reused 0 (delta 0), pack-reused 270
                    Receiving objects: 100% (273/273), 215.00 KiB | 0 bytes/s, done.
                    Resolving deltas: 100% (114/114), done.
                    Checking connectivity... done.
                    pi@domoticjp ~ $ cd Raspberry/librf24-bcm
                    -bash: cd: Raspberry/librf24-bcm: No such file or directory
                    alexsh1A mfalkviddM 2 Replies Last reply
                      Ah yes, the guide became invalid yesterday when a PR was merged. I'll update the guide, thanks for noticing.
                      Information about how to get the rf library is available in the readme in the Raspberry folder if you want to get going.
                        msantang
                        wrote on last edited by msantang
                        #31
                        I got it working on my rb2 but i got 100% of cpu ussage.
                        I read a lot of post about this but i cant found a solution.
                        Some one know how to fix this?
                        OitzuO 1 Reply Last reply
                        • J jpbabou
                          Hi
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @jpbabou said:
                          Hi
                          Please go ahead and install the rf24 library from https://github.com/TMRh20/RF24
                          The rest should be the same
                          • M msantang
                            OitzuO
                            OitzuO
                            Oitzu
                            wrote on last edited by Oitzu
                            #33
                            The 100% cpu usage is probably due to the style of receiving new messages from rf24/serial port.
                            The current state is that the PiSerialGateway tries to poll data in a endless loop from rf24/serial.
                            This could maybe fixed with using the interrupt of the nrf24l01+ to signal new data and reading data from the serial in blocking mode.
                            I want to solve this but using interrupts on the RPi isn't that trivial.
                              http://forum.mysensors.org/topic/2367/pigatewayserial-using-interrupts/2 has information on how to use interrupts. I haven't tried it myself though.
                                OitzuO
                                OitzuO
                                Oitzu
                                Oh yeah, thanks for the hint @Bens got the exact same problem and seem to solved the rf24 part already. I hope he gets back online and shares his results. :)
                                • D
                                  D
                                  den2k
                                  Hi all,
                                  I'm following this thread and have upgraded to MySensors v1.5 and get the following error. Version mismatch.
                                  It looks like the Protocol version is 1.4.
                                  Does the Raspberry MySensors Gateway support v1.5 or only v1.4? Any ideas on how to fix?
                                  upload-27647566-60ff-4341-97aa-4d1186e5e670
                                  alexsh1A 1 Reply Last reply
                                  • D den2k
                                    Hi all,
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @den2k said:
                                    Hi all,
                                    Up until now, MySensors v1.4 only for nrf24l01+ direct connection.
                                    Did you upgrade the GW or the sensors or both ?
                                    D 1 Reply Last reply
                                      Protocol version hasn't changed since 1.4
                                      https://github.com/mysensors/Raspberry/blob/master/MyMessage.h#L41
                                      So you must have some other problem.. As you can see you only get zeroes in the log...
                                      • GertSandersG
                                        GertSandersG
                                        GertSanders
                                        wrote on last edited by GertSanders
                                        #39
                                        You can "fake" a later version (e.g, 1.5) on the Raspberry by changing the version code in the version.h file and recompiling the Gateway software.
                                        As far as I understand, the gateway will still pass the messages to the controller, even is there is a version mismatch message on the console.
                                        • alexsh1A alexsh1
                                          @den2k said:
                                          Hi all,
                                          D
                                          D
                                          den2k
                                          @alexsh1 I know the sensors are on v1.5. As for the Raspberry Gateway, it looks like based on the info here, that is running v1.4.
