  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 212.7k Views 36 Watching
  • alexsh1A alexsh1
    @stranger just to make sure - you said you have two gateways at home. Did you change the channel so that they do not interfere with each other?
    strangerS
    strangerS
    stranger
    @alexsh1 No actually. I didn't want to go around and reprogram all my nodes, and I forgot to turn off my other gateway. That is what I was going to do next, but I've just been running it for a few hours with no problems (with a heap of nodes and another gateway a few metres away, all on the same channel).
    I then Home Assistant and tested out a few nodes, and now it sometimes breaks, but mostly works fine.
    All that being said, I've realised I need signing (I have a few electronic locks), so I'm going back to a hardware serial gateway. If anyone has got signing working I'd love to hear how - I had a look but couldn't figure it out and don't have much time to spare on it.
    • Sander StolkS
      Sander StolkS
      Sander Stolk
      wrote on last edited by Sander Stolk
      #82
      pi@Domoticz3:~/Raspberry$ sudo ./PiGatewaySerial
      Starting PiGatewaySerial...
      Protocol version - 1.4
      Created PTY '/dev/pts/1'
      Gateway tty: /dev/ttyMySensorsGateway
      ================ SPI Configuration ================
      CSN Pin          = CE0 (PI Hardware Driven)
      CE Pin           = Custom GPIO25
      Clock Speed      = 8 Mhz
      ================ NRF Configuration ================
      STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
      RX_ADDR_P0-1     = 0xa8--------------------------------
      RX_ADDR_P2-5     = 0xff 0xc-----------------
      TX_ADDR          = 0xe7e7e7e7e7
      RX_PW_P0-6       = 0x20 0x20 0x20 0x00 0x00 0x00
      EN_AA            = 0x3b
      EN_RXADDR        = 0x06
      RF_CH            = 0x4c
      RF_SETUP         = 0x23
      CONFIG           = 0x0e
      DYNPD/FEATURE    = 0x3f 0x06
      Data Rate        = 250KBPS
      Model            = nRF24L01+
      CRC Length       = 16 bits
      PA Power         = PA_LOW
      ^[read: 1-1-0 s=0,c=1,t=0,pt=7,l=5:16.1
      read: 1-1-0 s=0,c=1,t=23,pt=2,l=2:1022
      read: 1-1-0 s=1,c=1,t=23,pt=2,l=2:1023
      read: 1-1-0 s=2,c=1,t=23,pt=2,l=2:1021
      Received SIGINT^C
      Exiting...
      pi@Domoticz3:~/Raspberry$ sudo cat /dev/ttyMySensorsGateway
      cat: /dev/ttyMySensorsGateway: No such file or directory
      pi@Domoticz3:~/Raspberry$ sudo /etc/init.d/PiGatewaySerial start
      [....] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.serviceFailed to start PiGatewaySerial.service: Unit PiGatewaySerial.service failed to load: No such file or directory.
       failed!
      Playing with a RPI 3 B and a NRF24+ radio I got this error message above.
      Running Jessie but with no luck...
      Anybody else got this problem?
      • Sander StolkS Sander Stolk
        Clock Speed      = 8 Mhz
        EN_AA            = 0x3b
        EN_RXADDR        = 0x06
        RF_CH            = 0x4c
        RF_SETUP         = 0x23
        CONFIG           = 0x0e
        Data Rate        = 250KBPS
        Model            = nRF24L01+
        PA Power         = PA_LOW
        Received SIGINT^C
        Exiting...
         failed!
        @Sander-Stolk did you run
        sudo make install
        What happens if you run
        sudo /usr/local/sbin/PiGatewaySerial
        Sander StolkS 1 Reply Last reply
          sudo make install
          Sander StolkS
          Sander StolkS
          Sander Stolk
          @mfalkvidd
          Tnx that worked but this is not in the tutorial I'm I right?
          If this happens, double-check your wiring and correct any problems. Press Ctrl+Z and type
          sudo killall PiGatewaySerial
          to get rid of the non-functioning Gateway. Then run sudo /usr/local/sbin/PiGatewaySerial again
          If all is well, exit PiGatewaySerial by pressing Ctrl+C. Then run
          to start the gateway as a background process. Verify that it started correctly by running```
            Yes it is. See the section under
            COMPILING THE GATEWAY
            also, you ran sudo ./PiGatewaySerial instead of sudo /usr/local/sbin/PiGatewaySerial described in the instructions.
              I have added a
              TROUBLESHOOTING
              section in the original post to cover for this error. Hopefully it can help if someone else makes the same mistake.
              • micahM
                micahM
                micah
                Any thoughts on making a version for the 2.0 dev branch?
                I recently switched my in-progress builds to 2.0 and am in the process of "trying" to get my Raspberry Pi2 setup with OpenHab and Mosquito. And the idea of not having to have an ethernet gateway arduino in the mix is appealing to me.
                I would do it myself but I probably only have 3.275% of the required knowledge at this point
                  I'm unfortunately at about the same level as you. I can compile stuff and do basic troubleshooting, but merging the dev branch with the gateway code is way out of my league.
                  micahM 1 Reply Last reply
                    micahM
                    micahM
                    micah
                    There is no way you are at 3.275% knowledge like me... I've seen many of your posts on here and you are at least a 4.532%... lol.... no honestly I've liked your posts and you seem very knowledgeable. You've got to be at least a 84.5% ;)
                    • Sander StolkS
                      Sander StolkS
                      Sander Stolk
                      Can somebody tell me how to change the channel after compiling and using the Gateway for a couple of days?
                      Changing the channel in MyConfig.h in the dir Raspberry doesnt bother even after a reboot.
                      Still 0x4c channel / 76 when I run the PiSerialGateway program.
                      alexsh1A 1 Reply Last reply
                        alexsh1A
                        alexsh1A
                        alexsh1
                        Did you recompile the code after changing the channel?
                        • alexsh1A alexsh1
                          Sander StolkS
                          Sander StolkS
                          Sander Stolk
                          #92
                          @alexsh1 I did this after changeing the channel in MyConfig.h: make all && sudo make install
                          Rebooted after that but no luck
                            That should be sufficient but you could see if running make clean before make all helps.
                              Sander StolkS
                              Sander StolkS
                              Sander Stolk
                              #94
                              @mfalkvidd I did the make clean and the make install and rebooted.
                              Still 0x4c eq. 76
                              Using username "pi".
                              Server refused our key
                              pi@192.168.1.14's password:
                              ______                      _   _
                              |  _  \                    | | (_)
                              | | | |___  _ __ ___   ___ | |_ _  ___ ____
                              | | | / _ \| '_ ` _ \ / _ \| __| |/ __|_  /
                              | |/ / (_) | | | | | | (_) | |_| | (__ / /
                              |___/ \___/|_| |_| |_|\___/ \__|_|\___/___|
                              Last login: Sat Apr  9 18:41:17 2016 from 192.168.1.34
                              Monday, 11 April 2016, 12:10:24 pm CEST
                              Linux 4.1.18-v7+ armv7l GNU/Linux
                              Uptime.............: 1 days, 17h29m13s
                              Memory.............: 520336kB (Free) / 948056kB (Total)
                              Load Averages......: 0.00, 0.01, 0.05 (1, 5, 15 min)
                              Running Processes..: 97
                              IP Addresses.......: 192.168.1.14
                              pi@Domoticz3:~$ cd Raspberry/
                              pi@Domoticz3:~/Raspberry$ cat MyConfig.h
                               The MySensors library adds a new layer on top of the RF24 library.
                               It handles radio network routing, relaying and ids.
                               Created by Henrik Ekblad <henrik.ekblad@gmail.com>
                               12/10/14 - Ported to Raspberry Pi by OUJABER Mohamed <m.oujaber@gmail.com>
                               This program is free software; you can redistribute it and/or
                               modify it under the terms of the GNU General Public License
                               version 2 as published by the Free Software Foundation.
                              #ifndef MyConfig_h
                              #define MyConfig_h
                               * Configure Sensor Network
                              #define RF24_CHANNEL       111             //RF channel for the sensor net, 0-127
                              #define RF24_DATARATE      RF24_250KBPS   //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
                              #define RF24_PA_LEVEL      RF24_PA_MAX    //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
                              #define RF24_PA_LEVEL_GW   RF24_PA_MAX  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401+ in your gateway.
                              #define BASE_RADIO_ID      ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
                              // MySensors online examples defaults
                              #define DEFAULT_CE_PIN 9
                              #define DEFAULT_CS_PIN 10
                               * Enable/Disable debug logging
                              #define DEBUG
                              #ifdef __Raspberry_Pi
                                      #define vsnprintf_P vsnprintf
                                      #define snprintf_P snprintf
                                      #define PSTR(x) (x)
                                      #define printf_P printf
                                      #define strlen_P strlen
                              pi@Domoticz3:~/Raspberry$ make clean
                              rm -rf MyGateway MySensor MyMessage PiEEPROM PiGateway PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o PiGatewaySerial.o
                              pi@Domoticz3:~/Raspberry$ make all
                              g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                              g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                              g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                              g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                              g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                              g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm
                              g++ -c -o PiGatewaySerial.o PiGatewaySerial.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                              g++ -o PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGatewaySerial.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm -lutil
                              pi@Domoticz3:~/Raspberry$ sudo reboot
                              Broadcast message from pi@Domoticz3 on pts/1 (Mon 2016-04-11 12:12:17 CEST):
                              The system is going down for reboot NOW!
                              ______                      _   _
                              |  _  \                    | | (_)
                              Last login: Mon Apr 11 12:10:24 2016 from 192.168.1.34
                              Monday, 11 April 2016, 12:12:45 pm CEST
                              Uptime.............: 0 days, 00h00m25s
                              Memory.............: 770952kB (Free) / 948056kB (Total)
                              Load Averages......: 0.59, 0.16, 0.05 (1, 5, 15 min)
                              Running Processes..: 100
                              pi@Domoticz3:~$ ls
                              bash_scripts  domoticz  Dropbox-Uploader  Raspberry  RF24
                              pi@Domoticz3:~$ sudo /etc/init.d/PiGatewaySerial start
                              [ ok ] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.service.
                              pi@Domoticz3:~$ sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                              ln: failed to create symbolic link ‘/dev/ttyUSB20’: File exists
                              pi@Domoticz3:~$ sudo /usr/local/sbin/PiGatewaySerial
                              Created PTY '/dev/pts/2'
                              Clock Speed      = 8 Mhz
                              RX_ADDR_P0-1     = 0xa8a8e
                              RX_ADDR_P2-5     = 0xff 0xc4
                              TX_ADDR          = 0xa8a8e1fc07
                              EN_AA            = 0x3b
                              EN_RXADDR        = 0x06
                              RF_CH            = 0x4c
                              RF_SETUP         = 0x23
                              CONFIG           = 0x0e
                              Data Rate        = 250KBPS
                              Model            = nRF24L01+
                              PA Power         = PA_LOW
                              read: 5-5-5 s=5,c=5,t=5,pt=0,l=0:
                              version mismatch
                              ^CReceived SIGINT
                              Exiting...
                              pi@Domoticz3:~$
                              mfalkviddM J 2 Replies Last reply
                                Still 0x4c eq. 76
                                ______                      _   _
                                |  _  \                    | | (_)
                                #ifndef MyConfig_h
                                #define MyConfig_h
                                #define DEBUG
                                        #define PSTR(x) (x)
                                ______                      _   _
                                |  _  \                    | | (_)
                                pi@Domoticz3:~$ ls
                                Clock Speed      = 8 Mhz
                                EN_AA            = 0x3b
                                EN_RXADDR        = 0x06
                                RF_CH            = 0x4c
                                RF_SETUP         = 0x23
                                CONFIG           = 0x0e
                                Data Rate        = 250KBPS
                                Model            = nRF24L01+
                                PA Power         = PA_LOW
                                version mismatch
                                ^CReceived SIGINT
                                Exiting...
                                pi@Domoticz3:~$
                                @Sander-Stolk I don't see a new make install in your output. Did you miss that or is the output just not included?
                                make all compiles the code. The result is a binary file in the Raspberry folder
                                make install copies the binary (and some scripts I think) from the Raspberry folder to the system folders.
                                • Sander StolkS
                                  Sander StolkS
                                  Sander Stolk
                                  Ok here's the deal to change the channel or other settings:
                                  cd Raspberry
                                  make clean
                                  make all
                                  sudo make install
                                  Done!
                                  • Tore André RosanderT
                                    Tore André Rosander
                                    wrote on last edited by Tore André Rosander
                                    #97
                                    Does anyone know what this error is about?
                                    RPi2, NRF24l01, OSMC (Debian jessie), Domoticz v3.5051.
                                    osmc@osmc:~/Raspberry$ sudo make install
                                    Installing PiGatewaySerial to /usr/local/sbin
                                    Installing PiGateway to /usr/local/sbin
                                    Installing initscripts to /etc/init.d
                                    Installing syslog config to /etc/rsyslog.d
                                    Failed to restart rsyslog.service: Unit rsyslog.service failed to load: No such file or directory.
                                    Makefile:79: recipe for target 'install-initscripts' failed
                                    make: *** [install-initscripts] Error 6
                                    I can run the gateway even with the error, i can also add it to Domoticz and send/receive data.
                                    But after a few minutes i get a massive error in domoticz saying "(24) Too many files open" on every logentry and my domoticz loose connection to the Logitech mediaserver, remote Kodi hardware, mqtt server etc.
                                    osmc@osmc:~/Raspberry$ sudo ./PiGatewaySerial
                                    Clock Speed      = 8 Mhz
                                    RX_ADDR_P0-1     = 0xa8a8e1fc00 0xa8a8e1fc00
                                    RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                                    TX_ADDR          = 0xa8a8e1fc02
                                    EN_AA            = 0x3b
                                    EN_RXADDR        = 0x06
                                    RF_CH            = 0x4c
                                    RF_SETUP         = 0x23
                                    CONFIG           = 0x0e
                                    Data Rate        = 250KBPS
                                    Model            = nRF24L01+
                                    PA Power         = PA_LOW
                                    • C
                                      C
                                      cingolanifede
                                      Hi, is signing supported using this library? thanks.
                                      • C cingolanifede
                                        @cingolanifede the Raspberry Pi gateway does not support signing.
                                        • B
                                          B
                                          BikeDan
                                          I'm looking for some help in getting "PiGatewaySerial" running properly. I am having no issue running "PiGateway" and receiving all data from a counter node I'm using for testing. When I try to run "PiGatewaySerial", only intermittent data appears. For this example, I have my counter sending increasing integers at 1 second intervals, and receives fewer than 1 in 25 through the "PiGatewaySerial" script. I previously had this working reliably on a RPi2, reading in the tty output and logging it to a file. Now, I cannot repeat that on either that device, nor the current RPi B+ I'm working with. I'm sure there's some basic setting that I'm missing, but I can't seem to figure it out. Thanks!
                                          An example of "PiGateway" correctly receiving all messages:
                                          pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGateway
                                          Starting Gateway...
                                          Clock Speed	 = 8 Mhz
                                          EN_AA		 = 0x3b
                                          EN_RXADDR	 = 0x06
                                          RF_CH		 = 0x4c
                                          RF_SETUP	 = 0x23
                                          CONFIG		 = 0x0e
                                          Data Rate	 = 250KBPS
                                          Model		 = nRF24L01+
                                          PA Power	 = PA_LOW
                                          [CALLBACK]0;0;3;0;14;Gateway startup complete.
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:906
                                          [CALLBACK]0;33;1;0;38;906
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:907
                                          [CALLBACK]0;33;1;0;38;907
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:908
                                          [CALLBACK]0;33;1;0;38;908
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:909
                                          [CALLBACK]0;33;1;0;38;909
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:910
                                          [CALLBACK]0;33;1;0;38;910
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:911
                                          [CALLBACK]0;33;1;0;38;911
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:912
                                          [CALLBACK]0;33;1;0;38;912
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:913
                                          [CALLBACK]0;33;1;0;38;913
                                          an example of "PiGatewaySerial" missing most messages:
                                          pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGatewaySerial
                                          Clock Speed	 = 8 Mhz
                                          EN_AA		 = 0x3b
                                          EN_RXADDR	 = 0x06
                                          RF_CH		 = 0x4c
                                          RF_SETUP	 = 0x23
                                          CONFIG		 = 0x0e
                                          Data Rate	 = 250KBPS
                                          Model		 = nRF24L01+
                                          PA Power	 = PA_LOW
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:301
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:302
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:303
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:328
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:353
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:378
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:403
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:428
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:454
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:479
                                          read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:504
                                          I'm running a RPi B+, NRF24l01+, on a clean install of Jessie, and using only a few percent of the CPU power.
