  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 212.7k Views 36 Watching
  • rmtuckerR
    rmtuckerR
    rmtucker
    I have been thinking about giving this a try But:-
    The Raspberry port is using protocol version 1.4.
    Do the sensors also have to use version 1.4?
    • rmtuckerR rmtucker
      GertSandersG
      GertSandersG
      GertSanders
      @rmtucker
      No, the sensors can be running 1.5 or 2.0-beta, the PI will run a 1.4 version.
      The only thing not supported by the PiGateway is message signing.
      But I have a mix of sensors in 1.5, 1.6-beta and 2.0-beta in my home network, so it certainly works.
      rmtuckerR 1 Reply Last reply
      • GertSandersG GertSanders
        @rmtucker
        rmtuckerR
        rmtuckerR
        rmtucker
        @GertSanders
        Is it best to start with a blank jessie image and manually install/compile domoticz or just use the domoticz sd image?
        The latter would be the easiest for me because i am useless with the CLI but if the first method is best??
        • AnticimexA
          AnticimexA
          Anticimex
          Adding support for signing on a pi gw should just be a matter of implementing random number generation and use software signing. With slight modification in the software signing backend as it assumes Arduino api:s for obtaining a seed for the rng.
            @GertSanders
            @rmtucker if you want to be able to run the very latest version of Domoticz, use the Debian image and compile Domoticz from git.
            I use the Domoticz image. The downside is that I need to wait for new "official" Domoticz builds before upgrading, but the upside is that getting up and running was very easy.
              GertSandersG
              GertSandersG
              GertSanders
              @mfalkvidd
              Actually ... I started with an official Domoticz build, and then I indicated in the settings that I wanted to update with the beta version. Since then I'm always on the latest beta (v5143 at the moment).
                @mfalkvidd
                @GertSanders cool. How often is the beta updated? Every build?
                • rmtuckerR
                  rmtuckerR
                  rmtucker
                  Just set this up on my existing Raspberry pi B+ Domoticz server and it is working perfectly so i have managed to get rid of the uno Gateway.
                  Thank you so much,I can now try and squeeze it all in the Raspi case and the job is finished.
                  • rmtuckerR
                    rmtuckerR
                    rmtucker
                    This is the cpu usage,the spike is me compiling the software as above.
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @mfalkvidd
                      Well, that seems to be the case. Sometimes I see daily updates, sometimes a week passes by without any changes. I selected the BETA channel for updates and since then I have seen new functionality come in on a regular basis. Not all of it is relevant to Mysensors of course, but none the less it's fun to see Domoticz is developed actively.
                      W 1 Reply Last reply
                        @mfalkvidd
                        W
                        W
                        wergeld
                        @GertSanders I have seen no issues in Domoticz stable with CPU usage. Thing just purrs along. Will have to check when I get home but i believe my system uptime is approaching 1 year. It "just works" as they say.
                        I would like to upgrade to mysensors 2.0 library by it looks like the Pi repo has not being updated as often (last I checked, anyway).
                        • W wergeld
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @wergeld
                          Correct, the PI repo is basically unchanged. But it still is compatible with the 2.0-beta Mysensors library.
                            @wergeld
                            W
                            W
                            wergeld
                            @GertSanders What? I was under the impression that some features (like sending messages to nodes from domitcz wouldn't work).
                            • W wergeld
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @wergeld
                              Did not notice that, I can send values and "switch on" messages to nodes. The only thing I miss is the signing via ATSHA204. Even V_TEXT sending to and from nodes works.
                              • Tore André RosanderT
                                Tore André Rosander
                                I have some trouble with the gateway not storing the network map, if i restart the gateway my non-sensor nodes need to send some kind of heartbeat to reconnect to the gateway.
                                Is this a known problem or is it something wrong with my setup?
                                  Yes, known problem.
                                  I had some hopes on @marceloaqno and @aaron832 providing a PR into development branch (so we can scrap the old RPI code). But there hasn't been any activity in a while.
                                  https://forum.mysensors.org/topic/2759/mysensors-raspberry-port-suggestions/12
                                  Tore André RosanderT 1 Reply Last reply
                                    Yes, known problem.
                                    Tore André Rosander
                                    @hek But insted of including heartbeats from every non sensor node (trying to keep 2.4 ghz traffic to a minimum), can i solve this by using an arduino repeater node? So the repeater knows the network map and sends heartbeat to the gateway.
                                      @Tore-André-Rosander
                                      No, not possible. The repeater won't propagate it's knowledge about all sub-nodes.
                                      • Sander StolkS Sander Stolk
                                        @mfalkvidd I did the make clean and the make install and rebooted.
                                        Still 0x4c eq. 76
                                        Using username "pi".
                                        Server refused our key
                                        pi@192.168.1.14's password:
                                        ______                      _   _
                                        |  _  \                    | | (_)
                                        | | | |___  _ __ ___   ___ | |_ _  ___ ____
                                        | | | / _ \| '_ ` _ \ / _ \| __| |/ __|_  /
                                        | |/ / (_) | | | | | | (_) | |_| | (__ / /
                                        |___/ \___/|_| |_| |_|\___/ \__|_|\___/___|
                                        Last login: Sat Apr  9 18:41:17 2016 from 192.168.1.34
                                        Monday, 11 April 2016, 12:10:24 pm CEST
                                        Linux 4.1.18-v7+ armv7l GNU/Linux
                                        Uptime.............: 1 days, 17h29m13s
                                        Memory.............: 520336kB (Free) / 948056kB (Total)
                                        Load Averages......: 0.00, 0.01, 0.05 (1, 5, 15 min)
                                        Running Processes..: 97
                                        IP Addresses.......: 192.168.1.14
                                        pi@Domoticz3:~$ cd Raspberry/
                                        pi@Domoticz3:~/Raspberry$ cat MyConfig.h
                                         The MySensors library adds a new layer on top of the RF24 library.
                                         It handles radio network routing, relaying and ids.
                                         Created by Henrik Ekblad <henrik.ekblad@gmail.com>
                                         12/10/14 - Ported to Raspberry Pi by OUJABER Mohamed <m.oujaber@gmail.com>
                                         This program is free software; you can redistribute it and/or
                                         modify it under the terms of the GNU General Public License
                                         version 2 as published by the Free Software Foundation.
                                        #ifndef MyConfig_h
                                        #define MyConfig_h
                                         * Configure Sensor Network
                                        #define RF24_CHANNEL       111             //RF channel for the sensor net, 0-127
                                        #define RF24_DATARATE      RF24_250KBPS   //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
                                        #define RF24_PA_LEVEL      RF24_PA_MAX    //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
                                        #define RF24_PA_LEVEL_GW   RF24_PA_MAX  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401+ in your gateway.
                                        #define BASE_RADIO_ID      ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
                                        // MySensors online examples defaults
                                        #define DEFAULT_CE_PIN 9
                                        #define DEFAULT_CS_PIN 10
                                         * Enable/Disable debug logging
                                        #define DEBUG
                                        #ifdef __Raspberry_Pi
                                                #define vsnprintf_P vsnprintf
                                                #define snprintf_P snprintf
                                                #define PSTR(x) (x)
                                                #define printf_P printf
                                                #define strlen_P strlen
                                        pi@Domoticz3:~/Raspberry$ make clean
                                        rm -rf MyGateway MySensor MyMessage PiEEPROM PiGateway PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o PiGatewaySerial.o
                                        pi@Domoticz3:~/Raspberry$ make all
                                        g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm
                                        g++ -c -o PiGatewaySerial.o PiGatewaySerial.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                        g++ -o PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGatewaySerial.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm -lutil
                                        pi@Domoticz3:~/Raspberry$ sudo reboot
                                        Broadcast message from pi@Domoticz3 on pts/1 (Mon 2016-04-11 12:12:17 CEST):
                                        The system is going down for reboot NOW!
                                        ______                      _   _
                                        |  _  \                    | | (_)
                                        Last login: Mon Apr 11 12:10:24 2016 from 192.168.1.34
                                        Monday, 11 April 2016, 12:12:45 pm CEST
                                        Uptime.............: 0 days, 00h00m25s
                                        Memory.............: 770952kB (Free) / 948056kB (Total)
                                        Load Averages......: 0.59, 0.16, 0.05 (1, 5, 15 min)
                                        Running Processes..: 100
                                        pi@Domoticz3:~$ ls
                                        bash_scripts  domoticz  Dropbox-Uploader  Raspberry  RF24
                                        pi@Domoticz3:~$ sudo /etc/init.d/PiGatewaySerial start
                                        [ ok ] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.service.
                                        pi@Domoticz3:~$ sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                                        ln: failed to create symbolic link ‘/dev/ttyUSB20’: File exists
                                        pi@Domoticz3:~$ sudo /usr/local/sbin/PiGatewaySerial
                                        Starting PiGatewaySerial...
                                        Protocol version - 1.4
                                        Created PTY '/dev/pts/2'
                                        Gateway tty: /dev/ttyMySensorsGateway
                                        ================ SPI Configuration ================
                                        CSN Pin          = CE0 (PI Hardware Driven)
                                        CE Pin           = Custom GPIO25
                                        Clock Speed      = 8 Mhz
                                        ================ NRF Configuration ================
                                        STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                                        RX_ADDR_P0-1     = 0xa8a8e
                                        RX_ADDR_P2-5     = 0xff 0xc4
                                        TX_ADDR          = 0xa8a8e1fc07
                                        RX_PW_P0-6       = 0x20 0x20 0x20 0x00 0x00 0x00
                                        EN_AA            = 0x3b
                                        EN_RXADDR        = 0x06
                                        RF_CH            = 0x4c
                                        RF_SETUP         = 0x23
                                        CONFIG           = 0x0e
                                        DYNPD/FEATURE    = 0x3f 0x06
                                        Data Rate        = 250KBPS
                                        Model            = nRF24L01+
                                        CRC Length       = 16 bits
                                        PA Power         = PA_LOW
                                        read: 5-5-5 s=5,c=5,t=5,pt=0,l=0:
                                        version mismatch
                                        ^CReceived SIGINT
                                        Exiting...
                                        pi@Domoticz3:~$
                                        J
                                        J
                                        jpbabou
                                        @Sander-Stolk hi
                                        how do you achieve to have a nice 'logon' screen ou your PI: Domotics Logo, @ip,memory,date... etc etc..
                                        Im' newbee on raspberry from france
                                        HAve a nice day
                                        JP
                                        i really want to have the same or any available sample like yours
                                        | _ \ | | ()
                                        | | | / _ | '_ ` _ \ / _ | | |/ | /
                                        | |/ / () | | | | | | () | |_| | (
                                        / _/|| || ||___/ _||_/|
                                        • J jpbabou
                                          @Sander-Stolk hi
                                          HAve a nice day
                                          JP
                                          | _ \ | | ()
                                          Tore André Rosander
                                          @jpbabou That is the Message of the day (motd) and you can edit it to fit your needs.
                                          This guide should work on debian weezy and jessie
                                          https://oitibs.com/debian-wheezy-dynamic-motd/
                                          J 2 Replies Last reply
