  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 213.0k Views 36 Watching
  • B
    B
    BikeDan
    I'm looking for some help in getting "PiGatewaySerial" running properly. I am having no issue running "PiGateway" and receiving all data from a counter node I'm using for testing. When I try to run "PiGatewaySerial", only intermittent data appears. For this example, I have my counter sending increasing integers at 1 second intervals, and receives fewer than 1 in 25 through the "PiGatewaySerial" script. I previously had this working reliably on a RPi2, reading in the tty output and logging it to a file. Now, I cannot repeat that on either that device, nor the current RPi B+ I'm working with. I'm sure there's some basic setting that I'm missing, but I can't seem to figure it out. Thanks!
    An example of "PiGateway" correctly receiving all messages:
    pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGateway
    Starting Gateway...
    ================ SPI Configuration ================
    CSN Pin  	 = CE0 (PI Hardware Driven)
    CE Pin  	 = Custom GPIO25
    Clock Speed	 = 8 Mhz
    ================ NRF Configuration ================
    STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    RX_ADDR_P0-1	 = 0xa8a8e1fc00 0xa8a8e1fc00
    RX_ADDR_P2-5	 = 0xff 0xc4 0xc5 0xc6
    TX_ADDR		 = 0xe7e7e7e7e7
    RX_PW_P0-6	 = 0x20 0x20 0x20 0x00 0x00 0x00
    EN_AA		 = 0x3b
    EN_RXADDR	 = 0x06
    RF_CH		 = 0x4c
    RF_SETUP	 = 0x23
    CONFIG		 = 0x0e
    DYNPD/FEATURE	 = 0x3f 0x06
    Data Rate	 = 250KBPS
    Model		 = nRF24L01+
    CRC Length	 = 16 bits
    PA Power	 = PA_LOW
    [CALLBACK]0;0;3;0;14;Gateway startup complete.
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:906
    [CALLBACK]0;33;1;0;38;906
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:907
    [CALLBACK]0;33;1;0;38;907
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:908
    [CALLBACK]0;33;1;0;38;908
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:909
    [CALLBACK]0;33;1;0;38;909
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:910
    [CALLBACK]0;33;1;0;38;910
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:911
    [CALLBACK]0;33;1;0;38;911
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:912
    [CALLBACK]0;33;1;0;38;912
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:913
    [CALLBACK]0;33;1;0;38;913
    an example of "PiGatewaySerial" missing most messages:
    pi@raspberrypi:/dev/pts $ sudo /usr/local/sbin/PiGatewaySerial
    Starting PiGatewaySerial...
    Protocol version - 1.4
    Created PTY '/dev/pts/1'
    Gateway tty: /dev/ttyMySensorsGateway
    Clock Speed	 = 8 Mhz
    EN_AA		 = 0x3b
    EN_RXADDR	 = 0x06
    RF_CH		 = 0x4c
    RF_SETUP	 = 0x23
    CONFIG		 = 0x0e
    Data Rate	 = 250KBPS
    Model		 = nRF24L01+
    PA Power	 = PA_LOW
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:301
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:302
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:303
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:328
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:353
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:378
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:403
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:428
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:454
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:479
    read: 0-0-0 s=33,c=1,t=38,pt=2,l=2:504
    I'm running a RPi B+, NRF24l01+, on a clean install of Jessie, and using only a few percent of the CPU power.
    • rmtuckerR
      rmtuckerR
      rmtucker
      I have been thinking about giving this a try But:-
      The Raspberry port is using protocol version 1.4.
      Do the sensors also have to use version 1.4?
      • rmtuckerR rmtucker
        GertSandersG
        GertSandersG
        GertSanders
        @rmtucker
        No, the sensors can be running 1.5 or 2.0-beta, the PI will run a 1.4 version.
        The only thing not supported by the PiGateway is message signing.
        But I have a mix of sensors in 1.5, 1.6-beta and 2.0-beta in my home network, so it certainly works.
        rmtuckerR 1 Reply Last reply
        • GertSandersG GertSanders
          @rmtucker
          rmtuckerR
          rmtuckerR
          rmtucker
          @GertSanders
          Is it best to start with a blank jessie image and manually install/compile domoticz or just use the domoticz sd image?
          The latter would be the easiest for me because i am useless with the CLI but if the first method is best??
          • AnticimexA
            AnticimexA
            Anticimex
            Adding support for signing on a pi gw should just be a matter of implementing random number generation and use software signing. With slight modification in the software signing backend as it assumes Arduino api:s for obtaining a seed for the rng.
              @GertSanders
              @rmtucker if you want to be able to run the very latest version of Domoticz, use the Debian image and compile Domoticz from git.
              I use the Domoticz image. The downside is that I need to wait for new "official" Domoticz builds before upgrading, but the upside is that getting up and running was very easy.
                GertSandersG
                GertSandersG
                GertSanders
                @mfalkvidd
                Actually ... I started with an official Domoticz build, and then I indicated in the settings that I wanted to update with the beta version. Since then I'm always on the latest beta (v5143 at the moment).
                  @mfalkvidd
                  @GertSanders cool. How often is the beta updated? Every build?
                  • rmtuckerR
                    rmtuckerR
                    rmtucker
                    Just set this up on my existing Raspberry pi B+ Domoticz server and it is working perfectly so i have managed to get rid of the uno Gateway.
                    Thank you so much,I can now try and squeeze it all in the Raspi case and the job is finished.
                    • rmtuckerR
                      rmtuckerR
                      rmtucker
                      This is the cpu usage,the spike is me compiling the software as above.
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @mfalkvidd
                        Well, that seems to be the case. Sometimes I see daily updates, sometimes a week passes by without any changes. I selected the BETA channel for updates and since then I have seen new functionality come in on a regular basis. Not all of it is relevant to Mysensors of course, but none the less it's fun to see Domoticz is developed actively.
                        W 1 Reply Last reply
                          @mfalkvidd
                          W
                          W
                          wergeld
                          @GertSanders I have seen no issues in Domoticz stable with CPU usage. Thing just purrs along. Will have to check when I get home but i believe my system uptime is approaching 1 year. It "just works" as they say.
                          I would like to upgrade to mysensors 2.0 library by it looks like the Pi repo has not being updated as often (last I checked, anyway).
                          • W wergeld
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @wergeld
                            Correct, the PI repo is basically unchanged. But it still is compatible with the 2.0-beta Mysensors library.
                              @wergeld
                              W
                              W
                              wergeld
                              @GertSanders What? I was under the impression that some features (like sending messages to nodes from domitcz wouldn't work).
                              • W wergeld
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @wergeld
                                Did not notice that, I can send values and "switch on" messages to nodes. The only thing I miss is the signing via ATSHA204. Even V_TEXT sending to and from nodes works.
                                • Tore André RosanderT
                                  Tore André Rosander
                                  I have some trouble with the gateway not storing the network map, if i restart the gateway my non-sensor nodes need to send some kind of heartbeat to reconnect to the gateway.
                                  Is this a known problem or is it something wrong with my setup?
                                    Yes, known problem.
                                    I had some hopes on @marceloaqno and @aaron832 providing a PR into development branch (so we can scrap the old RPI code). But there hasn't been any activity in a while.
                                    https://forum.mysensors.org/topic/2759/mysensors-raspberry-port-suggestions/12
                                    Tore André RosanderT 1 Reply Last reply
                                      Yes, known problem.
                                      Tore André Rosander
                                      @hek But insted of including heartbeats from every non sensor node (trying to keep 2.4 ghz traffic to a minimum), can i solve this by using an arduino repeater node? So the repeater knows the network map and sends heartbeat to the gateway.
                                        @Tore-André-Rosander
                                        No, not possible. The repeater won't propagate it's knowledge about all sub-nodes.
                                        • Sander StolkS Sander Stolk
                                          @mfalkvidd I did the make clean and the make install and rebooted.
                                          Still 0x4c eq. 76
                                          Using username "pi".
                                          Server refused our key
                                          pi@192.168.1.14's password:
                                          ______                      _   _
                                          |  _  \                    | | (_)
                                          | | | |___  _ __ ___   ___ | |_ _  ___ ____
                                          | | | / _ \| '_ ` _ \ / _ \| __| |/ __|_  /
                                          | |/ / (_) | | | | | | (_) | |_| | (__ / /
                                          |___/ \___/|_| |_| |_|\___/ \__|_|\___/___|
                                          Last login: Sat Apr  9 18:41:17 2016 from 192.168.1.34
                                          Monday, 11 April 2016, 12:10:24 pm CEST
                                          Linux 4.1.18-v7+ armv7l GNU/Linux
                                          Uptime.............: 1 days, 17h29m13s
                                          Memory.............: 520336kB (Free) / 948056kB (Total)
                                          Load Averages......: 0.00, 0.01, 0.05 (1, 5, 15 min)
                                          Running Processes..: 97
                                          IP Addresses.......: 192.168.1.14
                                          pi@Domoticz3:~$ cd Raspberry/
                                          pi@Domoticz3:~/Raspberry$ cat MyConfig.h
                                           The MySensors library adds a new layer on top of the RF24 library.
                                           It handles radio network routing, relaying and ids.
                                           Created by Henrik Ekblad <henrik.ekblad@gmail.com>
                                           12/10/14 - Ported to Raspberry Pi by OUJABER Mohamed <m.oujaber@gmail.com>
                                          #ifndef MyConfig_h
                                          #define MyConfig_h
                                           * Configure Sensor Network
                                          #define RF24_CHANNEL       111             //RF channel for the sensor net, 0-127
                                          #define RF24_DATARATE      RF24_250KBPS   //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
                                          #define RF24_PA_LEVEL      RF24_PA_MAX    //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
                                          #define RF24_PA_LEVEL_GW   RF24_PA_MAX  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401+ in your gateway.
                                          #define BASE_RADIO_ID      ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
                                          // MySensors online examples defaults
                                          #define DEFAULT_CE_PIN 9
                                          #define DEFAULT_CS_PIN 10
                                           * Enable/Disable debug logging
                                          #define DEBUG
                                          #ifdef __Raspberry_Pi
                                                  #define vsnprintf_P vsnprintf
                                                  #define snprintf_P snprintf
                                                  #define PSTR(x) (x)
                                                  #define printf_P printf
                                                  #define strlen_P strlen
                                          pi@Domoticz3:~/Raspberry$ make clean
                                          rm -rf MyGateway MySensor MyMessage PiEEPROM PiGateway PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o PiGatewaySerial.o
                                          pi@Domoticz3:~/Raspberry$ make all
                                          g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                          g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                          g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                          g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                          g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                          g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm
                                          g++ -c -o PiGatewaySerial.o PiGatewaySerial.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24
                                          g++ -o PiGatewaySerial MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGatewaySerial.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -I/usr/local/include/RF24 -lrf24-bcm -lutil
                                          pi@Domoticz3:~/Raspberry$ sudo reboot
                                          Broadcast message from pi@Domoticz3 on pts/1 (Mon 2016-04-11 12:12:17 CEST):
                                          The system is going down for reboot NOW!
                                          ______                      _   _
                                          |  _  \                    | | (_)
                                          Last login: Mon Apr 11 12:10:24 2016 from 192.168.1.34
                                          Monday, 11 April 2016, 12:12:45 pm CEST
                                          Uptime.............: 0 days, 00h00m25s
                                          Memory.............: 770952kB (Free) / 948056kB (Total)
                                          Load Averages......: 0.59, 0.16, 0.05 (1, 5, 15 min)
                                          Running Processes..: 100
                                          pi@Domoticz3:~$ ls
                                          bash_scripts  domoticz  Dropbox-Uploader  Raspberry  RF24
                                          pi@Domoticz3:~$ sudo /etc/init.d/PiGatewaySerial start
                                          [ ok ] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.service.
                                          pi@Domoticz3:~$ sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                                          ln: failed to create symbolic link ‘/dev/ttyUSB20’: File exists
                                          pi@Domoticz3:~$ sudo /usr/local/sbin/PiGatewaySerial
                                          Created PTY '/dev/pts/2'
                                          Clock Speed      = 8 Mhz
                                          TX_ADDR          = 0xa8a8e1fc07
                                          EN_AA            = 0x3b
                                          EN_RXADDR        = 0x06
                                          RF_CH            = 0x4c
                                          RF_SETUP         = 0x23
                                          CONFIG           = 0x0e
                                          Data Rate        = 250KBPS
                                          Model            = nRF24L01+
                                          PA Power         = PA_LOW
                                          read: 5-5-5 s=5,c=5,t=5,pt=0,l=0:
                                          version mismatch
                                          ^CReceived SIGINT
                                          Exiting...
                                          pi@Domoticz3:~$
                                          J
                                          J
                                          jpbabou
                                          @Sander-Stolk hi
                                          how do you achieve to have a nice 'logon' screen ou your PI: Domotics Logo, @ip,memory,date... etc etc..
                                          Im' newbee on raspberry from france
                                          HAve a nice day
                                          JP
                                          i really want to have the same or any available sample like yours
                                          | _ \ | | ()
                                          | | | / _ | '_ ` _ \ / _ | | |/ | /
                                          | |/ / () | | | | | | () | |_| | (
                                          / _/|| || ||___/ _||_/|
