  3. SerialGateway.ino fatal error MySigningNone.h no such file or directory compilation terminated
4 Posts 2 Posters 4.2k Views 1 Watching
  • A
    A
    Alex B Goode
    wrote on last edited by Alex B Goode
    Hello
    I followed the guidance how to get started and faced the problem of wrong location of libraries or something around
    I am doing it in OSX. I did it already with FastLED libraries when played around Ambilight and it worked fine with no surprises.
    I downloaded Arduino-master.zip from github and extracted in a temp location.
    Surprisingly the extracted folder structure contained a lot of extra things which should not be placed at Arduino IDE library location. Okay, I should not use anything except the library folder in the archive!
    The default location for Arduino IDE libraries is ~/Documents/Arduino/libraries
    I created a subfolder MySensors and moved all the content of the library folder from the downloaded archive
    So finally I got the following folder structure
    ~/Documents/Arduino/libraries/MySensors:
    • Adafruit_BMP085
    • Adafruit_NeoPixel
    • BH1750
    • UTFT_Buttons
    • UTouch
    Is that the proper location and the structure for the libraries?
    Dear folks, please advice on this
      All the libraries (including MySensors) should be in the libraries folder.
      • A
        A
        Alex B Goode
        Thanks, it is better that way. Now I understand that in my case I created an extra top level folder MySensors which included all libraries. When I have these two libraries then SerialGateway is being compiled well.
        ~/Documents/Arduino/libraries:
        • PinChangeInt
        Meanwhile I wonder why does the archive include so many irrelevant libraries as well?
        I mean for example:
        • Adafruit_BMP085
        • Adafruit_NeoPixel
        How are they connected to the topic of MySensors?!
          They are used by the examples under MySensors.
