  3. Relay node keeps dropping out
5 Posts 3 Posters 2.2k Views 1 Watching
  • K
    K
    kopite
    Hi
    Has anyone experienced problems with relay nodes randomly dropping out and needing a reset?
    I have a "sprinkler" node with 6 relays\switches published to mysensor gateway.
    it is sitting approx 20-30m from the gw and will work flawlessly for 2-3 days and then just drop out and need a reset.
    I was thinking of adding a repeater sensor inbetween?
    • T
      TimO
      Hey!
      This is a common problem. Had it myself.
      Often there are two possible reasons:
      • There are spikes of power if a relay is switched, that may lead to a freeze of the NRF.
      • The emission of the relay may cause a freeze of the NRF too.
      I suggest:
      • Ensure a proper power supply. Maybe switch the power supply.
      • Add a capacitor to NRF.
      • Check debug output: is the atmel mcu freezing or the NRF?
      • Add optocoupler between Arduino and Relay
      Good luck!
      • K
        K
        kopite
        Thanks @TimO
        Power spike would make sense as there is a mix of 240 and 24VAC
        I am going to put the 240 into another box where my zwave 240 switches are and ill add a capacitor
        • bjacobseB
          bjacobseB
          bjacobse
          I once had a sonar device that behaved similar, could run for a few days, and suddenly be dead, then I unplugged power and power back and it could run again a few days - I was the NRF24L01+ that somehow was broken, since after I replaced the NRF24L01+ it have been working stable for several months
          • K
            K
            kopite
            I have not been home so i am unable to change radios or add capacitors, but what i have done and has worked for 3-4 days now is just adding delays between switching the relays.
            Before i would switch 1 off and 1 on at the same time, now i have added 15 seconds between and it is working without issue (fingers crossed)
