  3. πŸ’¬ Sensebender Micro
temperatureatmega328atsha204ahumidityflashmysensors
116 Posts 42 Posters 27.0k Views 38 Watching
  • openhardware.ioO Offline
    openhardware.io
    wrote on last edited by hek
    https://www.mysensors.org/view/1/Sensebender-Micro
    • maslinarM Offline
      maslinarM Offline
      maslinar
      This module looks very good. Where can I buy these? Does it sells as soldered module or (can I buy) only PCB?
      • tbowmoT Offline
        tbowmoT Offline
        tbowmo
        @maslinar
        See this page for more info.. It's the official mysensors pcb :)
        • maslinarM Offline
          maslinarM Offline
          maslinar
          How stupid of me. But of course it would be on the official mysensors site πŸ˜€πŸ˜‚πŸ˜‚πŸ˜‚
          • I Offline
            I Offline
            Ironbar
            Let me know if you manage to order them. The IMALL website won't let me actually place an order due to it sending the wrong address to Paypal. I'm curious if it is just me...
            • T Offline
              T Offline
              ToniA
              I had no problems two weeks ago. Just got them last week.
              • Dan S.D Offline
                Dan S.D Offline
                Dan S.
                I had that same problem, but then I carefully checked my address entry on the site and found I had made an error. Once corrected it processed OK.
                I 1 Reply Last reply
                • Dan S.D Dan S.
                  I Offline
                  I Offline
                  Ironbar
                  @Dan-S.
                  Crazy but there was a space after my city name that was preventing it from working. I would have never thought it was that picky. Ordered 5 and I cannot wait to see how well they work!
                  • toabhishekvermaT Offline
                    toabhishekverma
                    cool .. Any idea how long it last on battery?
                    • mfalkviddM Offline
                      The history thread mentioned in forum.mysensors.org/topic/1345/sensebender-micro/1 has a lot of information. I think the conclusion was 1-2 years.
                      • GertSandersG Offline
                        GertSanders
                        A version with the SMD NRF24L01+ would be cool !
                        • RJ_MakeR Offline
                          RJ_MakeR Offline
                          RJ_Make
                          Is it possible to add an ds18b20 to the Sensebender?
                          RJ_Make
                          • RJ_MakeR RJ_Make
                            GertSanders
                            wrote on last edited by GertSanders
                            @RJ_Make
                            That certainly is possble, but there is already an excellent SI7021 on board (temperature AND humidity), so why would you need it?
                            In any case you can connect it via de exposed pins.
                            RJ_MakeR 1 Reply Last reply
                            • GertSandersG GertSanders
                              @RJ_Make
                              RJ_MakeR Offline
                              RJ_MakeR Offline
                              RJ_Make
                              @GertSanders Thanks, It would be used for remote temp. sensing in a Ref/freezer/aquarium.. etc.
                              RJ_Make
                              • RJ_MakeR RJ_Make
                                GertSanders
                                @RJ_Make
                                Certainly possible, check the examples.
                                • SaimenS Offline
                                  SaimenS Offline
                                  Saimen
                                  is it possible, that the Sketch posted here, does not work with the MySensors libraray V2.0? There have been removed many libs, (SI7021, sha204, RunningAverage), which are used in the Sketch "SensebenderMicro.ino" V01.4.
                                  I had a little bit trouble last weekend, to get it run.
                                  I switched back to Mysensors lib 1.56 and used the expamle Sketch "SensebenderMicro" which was included in this lib. Then it worked.
                                  But thanks for this Great Projekt, and this great Board Sensenbender Micro
                                  Saimen
                                  • tbowmoT Offline
                                    tbowmoT Offline
                                    tbowmo
                                    @Saimen
                                    External libraries (and examples depending on them) have been moved to a separate repository https://github.com/mysensors/MySensorsArduinoExamples.
                                    This was done because we can not have the external libraries in the main repository now that we are in the arduino library manager.
                                    • SaimenS Offline
                                      SaimenS Offline
                                      Saimen
                                      @tbowmo Thank you very much for your response and explaining.
                                      • fearoffishF Offline
                                        fearoffishF Offline
                                        fearoffish
                                        Anyone managed to get this working with PlatformIO (through Atom) yet? I'm struggling.
                                        • phildeferP Offline
                                          phildeferP Offline
                                          phildefer
                                          @tbowmo
                                          I upgrade my sensebender firmware with the new one (V1.4), and i have a question.
                                          In the sketch (https://www.mysensors.org/hardware/micro) the line
                                          //#include <avr/power.h>
                                          is commented.
                                          Is it "normal" or is it a mistake ?
