  3. 💬 Sensebender Micro
💬 Sensebender Micro
temperatureatmega328atsha204ahumidityflashmysensors
116 Posts 42 Posters 52.3k Views 38 Watching
  • T
    ToniA
    I had no problems two weeks ago. Just got them last week.
    • Dan S.D
      Dan S.D
      Dan S.
      I had that same problem, but then I carefully checked my address entry on the site and found I had made an error. Once corrected it processed OK.
      I 1 Reply Last reply
      • Dan S.D Dan S.
        I
        I
        Ironbar
        @Dan-S.
        Crazy but there was a space after my city name that was preventing it from working. I would have never thought it was that picky. Ordered 5 and I cannot wait to see how well they work!
        • toabhishekvermaT
          toabhishekvermaT
          toabhishekverma
          cool .. Any idea how long it last on battery?
          • mfalkviddM
            The history thread mentioned in forum.mysensors.org/topic/1345/sensebender-micro/1 has a lot of information. I think the conclusion was 1-2 years.
            • GertSandersG
              GertSandersG
              GertSanders
              A version with the SMD NRF24L01+ would be cool !
              • RJ_MakeR
                RJ_MakeR
                RJ_Make
                Is it possible to add an ds18b20 to the Sensebender?
                RJ_Make
                • RJ_MakeR RJ_Make
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @RJ_Make
                  That certainly is possble, but there is already an excellent SI7021 on board (temperature AND humidity), so why would you need it?
                  In any case you can connect it via de exposed pins.
                  RJ_MakeR 1 Reply Last reply
                  • GertSandersG GertSanders
                    @RJ_Make
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    @GertSanders Thanks, It would be used for remote temp. sensing in a Ref/freezer/aquarium.. etc.
                    RJ_Make
                    • RJ_MakeR RJ_Make
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @RJ_Make
                      Certainly possible, check the examples.
                      • SaimenS
                        SaimenS
                        Saimen
                        is it possible, that the Sketch posted here, does not work with the MySensors libraray V2.0? There have been removed many libs, (SI7021, sha204, RunningAverage), which are used in the Sketch "SensebenderMicro.ino" V01.4.
                        I had a little bit trouble last weekend, to get it run.
                        I switched back to Mysensors lib 1.56 and used the expamle Sketch "SensebenderMicro" which was included in this lib. Then it worked.
                        But thanks for this Great Projekt, and this great Board Sensenbender Micro
                        Saimen
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Saimen
                          External libraries (and examples depending on them) have been moved to a separate repository https://github.com/mysensors/MySensorsArduinoExamples.
                          This was done because we can not have the external libraries in the main repository now that we are in the arduino library manager.
                          • SaimenS
                            SaimenS
                            Saimen
                            @tbowmo Thank you very much for your response and explaining.
                            • fearoffishF
                              fearoffishF
                              fearoffish
                              Anyone managed to get this working with PlatformIO (through Atom) yet? I'm struggling.
                              • phildeferP
                                phildeferP
                                phildefer
                                @tbowmo
                                I upgrade my sensebender firmware with the new one (V1.4), and i have a question.
                                In the sketch (https://www.mysensors.org/hardware/micro) the line
                                //#include <avr/power.h>
                                is commented.
                                Is it "normal" or is it a mistake ?
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @phildefer
                                  I think it's a leftover from a cleanup at some point in time. Not used anymore.. The MySensors core library is handling the sleep mechanism now.
                                  • denisvdbD
                                    denisvdbD
                                    denisvdb
                                    To reprogram the sketch in a sensbender micro, wich board must be selected in the arduino prg?
                                    I have problem with inclusion in jeedom, the command are not loaded.
                                    thx
                                    • fearoffishF fearoffish
                                      marceltrapmanM
                                      marceltrapmanM
                                      marceltrapman
                                      @fearoffish did you manage to get this working?
                                      And, if so, what was the issue?
                                      I am looking into changing to PlatformIO on Atom or even CLion...
                                      Fulltime Servoy Developer
                                      • loic13L
                                        loic13L
                                        loic13
                                        Hi, I'm getting this error message when compiling the sketch with the 2.1.1 MySensors library:
                                        SensebenderMicro:168: error: 'getConfig' was not declared in this scope
                                        isMetric = getConfig().isMetric;
                                        I just commented out the line as workaround, but not sure that its correct.
                                          Hmm.. The api was recently changed to getControllerConfig().isMetric;
                                          I'll update the example.
