  3. πŸ’¬ Sensebender Micro
temperatureatmega328atsha204ahumidityflashmysensors
116 Posts 42 Posters 52.1k Views 38 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    wrote on last edited by hek
    https://www.mysensors.org/view/1/Sensebender-Micro
    • maslinarM
      maslinarM
      maslinar
      This module looks very good. Where can I buy these? Does it sells as soldered module or (can I buy) only PCB?
      • tbowmoT
        tbowmoT
        tbowmo
        @maslinar
        See this page for more info.. It's the official mysensors pcb :)
        • maslinarM
          maslinarM
          maslinar
          How stupid of me. But of course it would be on the official mysensors site πŸ˜€πŸ˜‚πŸ˜‚πŸ˜‚
          • I
            I
            Ironbar
            Let me know if you manage to order them. The IMALL website won't let me actually place an order due to it sending the wrong address to Paypal. I'm curious if it is just me...
            • T
              ToniA
              I had no problems two weeks ago. Just got them last week.
              • Dan S.D
                Dan S.D
                Dan S.
                I had that same problem, but then I carefully checked my address entry on the site and found I had made an error. Once corrected it processed OK.
                I 1 Reply Last reply
                • Dan S.D Dan S.
                  I
                  I
                  Ironbar
                  @Dan-S.
                  Crazy but there was a space after my city name that was preventing it from working. I would have never thought it was that picky. Ordered 5 and I cannot wait to see how well they work!
                  • toabhishekvermaT
                    toabhishekvermaT
                    toabhishekverma
                    cool .. Any idea how long it last on battery?
                    • mfalkviddM
                      The history thread mentioned in forum.mysensors.org/topic/1345/sensebender-micro/1 has a lot of information. I think the conclusion was 1-2 years.
                      • GertSandersG
                        GertSandersG
                        GertSanders
                        A version with the SMD NRF24L01+ would be cool !
                        • RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          Is it possible to add an ds18b20 to the Sensebender?
                          RJ_Make
                          • RJ_MakeR RJ_Make
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @RJ_Make
                            That certainly is possble, but there is already an excellent SI7021 on board (temperature AND humidity), so why would you need it?
                            In any case you can connect it via de exposed pins.
                            RJ_MakeR 1 Reply Last reply
                            • GertSandersG GertSanders
                              @RJ_Make
                              RJ_MakeR
                              RJ_MakeR
                              RJ_Make
                              @GertSanders Thanks, It would be used for remote temp. sensing in a Ref/freezer/aquarium.. etc.
                              RJ_Make
                              • RJ_MakeR RJ_Make
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @RJ_Make
                                Certainly possible, check the examples.
                                • SaimenS
                                  SaimenS
                                  Saimen
                                  is it possible, that the Sketch posted here, does not work with the MySensors libraray V2.0? There have been removed many libs, (SI7021, sha204, RunningAverage), which are used in the Sketch "SensebenderMicro.ino" V01.4.
                                  I had a little bit trouble last weekend, to get it run.
                                  I switched back to Mysensors lib 1.56 and used the expamle Sketch "SensebenderMicro" which was included in this lib. Then it worked.
                                  But thanks for this Great Projekt, and this great Board Sensenbender Micro
                                  Saimen
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @Saimen
                                    External libraries (and examples depending on them) have been moved to a separate repository https://github.com/mysensors/MySensorsArduinoExamples.
                                    This was done because we can not have the external libraries in the main repository now that we are in the arduino library manager.
                                    • SaimenS
                                      SaimenS
                                      Saimen
                                      @tbowmo Thank you very much for your response and explaining.
                                      • fearoffishF
                                        fearoffishF
                                        fearoffish
                                        Anyone managed to get this working with PlatformIO (through Atom) yet? I'm struggling.
                                        • phildeferP
                                          phildeferP
                                          phildefer
                                          @tbowmo
                                          I upgrade my sensebender firmware with the new one (V1.4), and i have a question.
                                          In the sketch (https://www.mysensors.org/hardware/micro) the line
                                          //#include <avr/power.h>
                                          is commented.
                                          Is it "normal" or is it a mistake ?
                                          With your input, this post could be even better πŸ’—
