  3. 💬 Sensebender Micro
💬 Sensebender Micro
temperatureatmega328atsha204ahumidityflashmysensors
116 Posts 42 Posters 52.2k Views 38 Watching
  • toabhishekvermaT
    toabhishekvermaT
    toabhishekverma
    cool .. Any idea how long it last on battery?
    • mfalkviddM
      The history thread mentioned in forum.mysensors.org/topic/1345/sensebender-micro/1 has a lot of information. I think the conclusion was 1-2 years.
      • GertSandersG
        GertSandersG
        GertSanders
        A version with the SMD NRF24L01+ would be cool !
        • RJ_MakeR
          RJ_MakeR
          RJ_Make
          Is it possible to add an ds18b20 to the Sensebender?
          RJ_Make
          • RJ_MakeR RJ_Make
            GertSandersG
            GertSandersG
            GertSanders
            @RJ_Make
            That certainly is possble, but there is already an excellent SI7021 on board (temperature AND humidity), so why would you need it?
            In any case you can connect it via de exposed pins.
            RJ_MakeR 1 Reply Last reply
            • GertSandersG GertSanders
              @RJ_Make
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              @GertSanders Thanks, It would be used for remote temp. sensing in a Ref/freezer/aquarium.. etc.
              RJ_Make
              • RJ_MakeR RJ_Make
                GertSandersG
                GertSandersG
                GertSanders
                @RJ_Make
                Certainly possible, check the examples.
                • SaimenS
                  SaimenS
                  Saimen
                  is it possible, that the Sketch posted here, does not work with the MySensors libraray V2.0? There have been removed many libs, (SI7021, sha204, RunningAverage), which are used in the Sketch "SensebenderMicro.ino" V01.4.
                  I had a little bit trouble last weekend, to get it run.
                  I switched back to Mysensors lib 1.56 and used the expamle Sketch "SensebenderMicro" which was included in this lib. Then it worked.
                  But thanks for this Great Projekt, and this great Board Sensenbender Micro
                  Saimen
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Saimen
                    External libraries (and examples depending on them) have been moved to a separate repository https://github.com/mysensors/MySensorsArduinoExamples.
                    This was done because we can not have the external libraries in the main repository now that we are in the arduino library manager.
                    • SaimenS
                      SaimenS
                      Saimen
                      @tbowmo Thank you very much for your response and explaining.
                      • fearoffishF
                        fearoffishF
                        fearoffish
                        Anyone managed to get this working with PlatformIO (through Atom) yet? I'm struggling.
                        • phildeferP
                          phildeferP
                          phildefer
                          @tbowmo
                          I upgrade my sensebender firmware with the new one (V1.4), and i have a question.
                          In the sketch (https://www.mysensors.org/hardware/micro) the line
                          //#include <avr/power.h>
                          is commented.
                          Is it "normal" or is it a mistake ?
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @phildefer
                            I think it's a leftover from a cleanup at some point in time. Not used anymore.. The MySensors core library is handling the sleep mechanism now.
                            • denisvdbD
                              denisvdbD
                              denisvdb
                              To reprogram the sketch in a sensbender micro, wich board must be selected in the arduino prg?
                              I have problem with inclusion in jeedom, the command are not loaded.
                              thx
                              • fearoffishF fearoffish
                                marceltrapmanM
                                marceltrapmanM
                                marceltrapman
                                @fearoffish did you manage to get this working?
                                And, if so, what was the issue?
                                I am looking into changing to PlatformIO on Atom or even CLion...
                                Fulltime Servoy Developer
                                • loic13L
                                  loic13L
                                  loic13
                                  Hi, I'm getting this error message when compiling the sketch with the 2.1.1 MySensors library:
                                  SensebenderMicro:168: error: 'getConfig' was not declared in this scope
                                  isMetric = getConfig().isMetric;
                                  I just commented out the line as workaround, but not sure that its correct.
                                    Hmm.. The api was recently changed to getControllerConfig().isMetric;
                                    I'll update the example.
                                    • loic13L
                                      loic13L
                                      loic13
                                      Thank you.
                                      • T
                                        Toyman
                                        How difficult is to replace 0402 components with 0603 or 0804 components in Eagle? I am too old for 0402 soldering :-)))
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @Toyman
                                          Not that hard, but you'll probably need to redesign the board, to get room for the larger components.
                                          Another option is to order the board pre-assembled from our partner, itead studio
