  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 255.8k Views 53 Watching
  • martinhjelmareM
    martinhjelmareM
    martinhjelmare
    This is on my most wanted purchase list now. :smile:
    FYI, I noticed the spelling of "Sensebender" is "Sensbender" for this gateway on openhardware.io, so you're breaking your brand name. :wink: Would it be possible to amend it? If you try to search for it with the original spelling you only find the two sensor Sensebenders.
    hekH 1 Reply Last reply
      Opps! Thanks for reporting @martinhjelmare.
      • alexsh1A
        alexsh1A
        alexsh1
        This has been on my watch list for some time. Excellent work guys - I placed an order and looking forward upgrading my gateway.
        • Sander TeunissenS
          Sander TeunissenS
          Sander Teunissen
          Is this device capable of being a gateway for both nRF24L01+ radio and the Hope RF RFM69HCW radio simultaneously ?
          I have some nRF24 nodes and see a lot of new goodies equiped with the RFM69 radio. One gateway to serve both would be excellent !
          tbowmoT 1 Reply Last reply
            No, only one radio type or rs485 is possible at the moment.
            • Sander TeunissenS Sander Teunissen
              tbowmoT
              tbowmoT
              tbowmo
              @Sander-Teunissen
              The hardware supports both NRF and RFM69 at the same time, they share the same SPI bus, but has separate chip select lines etc.
              Unfortunately the MySensors library doesn't support multiple transports, so this time it's the software that limits things.
              FotoFieberF 1 Reply Last reply
              • F
                F
                Fabien
                Yes ! Itead send me the gateway today
                alexsh1A 1 Reply Last reply
                • F Fabien
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @Fabien said in 💬 Sensebender Gateway:
                  I have got mine today. Very quick
                  • tbowmoT tbowmo
                    @Sander-Teunissen
                    FotoFieberF
                    FotoFieberF
                    FotoFieber
                    @tbowmo
                    The fact, that MySensors doesn't support more then one radio, was the reason for me not to order the sensebender gateway.
                    I am working on a gateway⁄controller based on an arduino due, which supports at least up to 3 serial gateways via hardware serial. It handles ID and time (synced with ntp) requests and does pub/sub to mqtt with readable topics.(inspired by the old mqtt client gateway)
                    • FotoFieberF FotoFieber
                      @tbowmo
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @FotoFieber this is a software limitation. Hardware wise I do not see why Sensebender GW cannot handle two (nrf24l01+ and rfm69/rfm95) GWs at the same time
                      • alexsh1A alexsh1
                        FotoFieberF
                        FotoFieberF
                        FotoFieber
                        @alexsh1
                        The question is: will the software restriction be solved? If not, I do not care if it is a software or a hardware restriction. :)
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @FotoFieber
                          Well, you need to hack the core anyways, if you want to accomplish your goal.
                          You could also help out with the core development, so we can get support for multiple transport on one gateway ;)
                          • tbowmoT tbowmo
                            @FotoFieber
                            FotoFieberF
                            FotoFieberF
                            FotoFieber
                            @tbowmo
                            No, I don't have to hack the core. I use the serial API. From an architectural point of view, I don't see the need to change anything in MySensors. A serial controller can be built for under 20€ Including the radio. Why should I add complexity to support more than one radio support with one cpu in MySensors, if I can have the functipnality with the abstraction layer of the serial API? Please keep MySensors s simple as possible.
                            AnticimexA tbowmoT alexsh1A 3 Replies Last reply
                              @tbowmo
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @FotoFieber simple for who? Simplicity also involve maintenance and code complexity. What about testability and regression testing? Nobody gets paid for maintaining mysensors.
                                @tbowmo
                                tbowmoT
                                tbowmoT
                                tbowmo
                                @FotoFieber
                                But you ditched the sensebender Gateway, as it doesn't support multiple radios at the same time? Now you are saying that you would keep it as one radio per gateway?
                                This doesn't make sense :)
                                • tbowmoT tbowmo
                                  @FotoFieber
                                  FotoFieberF
                                  FotoFieberF
                                  FotoFieber
                                  @tbowmo
                                  Maybe the design of the sensebender gateway doesn't make sense to my architectural viewpoint....
                                    @alexsh1
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @FotoFieber This is a question for the MySensors dev team. Sensebender can handle both radios. Currently, there is a software restriction.
                                      @tbowmo
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #98
                                      @FotoFieber No, you do have to hack the core if you want both radios to be handled properly, i.e. to handle message queues with corresponding radios. For example, sending a message is done via rfm69 only and not via nrf24l01+
                                      • AnticimexA
                                        AnticimexA
                                        Anticimex
                                        The architecture we use would place this kind of situation to the controller to solve. One gw per network. So one gw for nrf and one for rfm.
                                        HW is cheap, and library should be kept simple.
                                        • AnticimexA Anticimex
                                          FotoFieberF
                                          FotoFieberF
                                          FotoFieber
                                          @Anticimex
                                          One gateway per radio, that is what I think is best. :+1:
                                          What I try to do, is to implement a controller with arduino due for up to three serial gateways. If there would be a solution for ethernet&rfm69 I may not have invested time in this. :laughing:
