  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 255.8k Views 53 Watching
  • scalzS
    scalzS
    wrote on last edited by scalz
    #161
    @MLs
    I'm also still using win7 x64 for my dev and that worked for me.
    Auto install through the Device Manager does not work, nor right-clicking and installing the .inf through Explorer.
    You have to force the install and select the location of the .inf in Device Manager. Then it will ask you if you agree about the driver supplier. Of course you're! And you should be able to see it in Device Manager.
    M 1 Reply Last reply
    • D
      D
      Dany
      There are example program for W5100? The original GatewayW5100 program uses SOFTSPI, different NRF CE/CSN pins? Will work with this hardware properly?
      tbowmoT 1 Reply Last reply
      • scalzS scalz
        @MLs
        MLs
        @scalz
        Heh've tried both in the device manager and manually. Device Manager, I get an error message.
        And manually, nothing happens.
        //Mattias
        • scalzS
          scalzS
          #164
          @MLs
          yep that's what i explained.
          you need to force it in Device Manager. How you're doing in Device manager actually is rather auto, imho ;)
          You can try in Device manager to right click on the bad detected device, here Sensebender Gw, and in properties, update driver. At a moment, it should prompt an "Open file" Dialog box (you need to choose the right option in the dialog) and then select your .inf file. And it will ask if you're ok to install a driver from a third party.
          • D Dany
            tbowmoT
            tbowmoT
            tbowmo
            @Dany
            The standard GatewayW5100 example sketch will work on the sensebender gateway. There are conditional compile statements in that sketch, that disables softspi when compiling to the gateway target, and use a hardware SPI instead.
            Remember to choose the correct target in your Arduino IDE
            • scalzS
              scalzS
              #166
              @MLs
              Okay, simpler, forget what i told you, and follow my steps below. I've unstalled mine to show you ;)
              Then if it can be useful for others. Nothing fancy here, it can be used for lot of others drivers.
              Step 1: plugin the GW, as you can see it's not detected, and no additional com port.
              Step 2: right clic, and update driver
              Step 3: click on the 2nd option for searching a driver on your machine
              Step 4: Again 2nd option here (you want to search for a driver on your computer)
              Step 5: This is a Virtual Serial Com port needed for the GW. So choose COM/LPT for the driver type
              Step 6: Now it is asking where the driver (.inf) is stored
              Step 7: You can now see that Windows knows what this is about. And tells you this driver is not "signed". No problem we know @tbowmo has done a great job. So, Next!
              Step 8: Windows here warns again, saying he doesn't know this driver, so it may not work well. No way, it will work well ;) Click "Yes" to install it.
              Step 9: Looks good
              Step 10: Tada! Here you can see now the GW is well detected and setup on COM port 24
              I can't do better!
              I think you'll get it :)
              • scalzS scalz
                @MLs
                Step 9: Looks good
                I can't do better!
                MLs
                wrote on last edited by MLs
                #167
                @scalz
                Thanks for a super instruction but it is the file itself that the computer says from. It says that the folder contains the no driver
                And the driver in the folder I chose I downloaded here
                https://github.com/mysensors/ArduinoHwSAMD/blob/master/driver/mysensors-samd.inf
                // Mattias
                • M MLs
                  @scalz
                  // Mattias
                  MLs
                  @MLs
                  When I downloaded the drivers so I make the following step.
                  Right-click at the file and save target as.
                  //Mattias
                    On the raw file?
                    https://raw.githubusercontent.com/mysensors/ArduinoHwSAMD/master/driver/mysensors-samd.inf
                      On the raw file?
                      MLs
                      @hek
                      https://github.com/mysensors/ArduinoHwSAMD/tree/master/driver
                      I click on the link below the folder drivers
                      //Mattias
                        No, that will download a github html page.
                        Use the link I posted (and save as). It will be the raw content.
                        M 2 Replies Last reply
                          MLs
                          @hek
                          I'll try it tomorrow is not so strange that it did not work for me then.
                          //Mattias
                            MLs
                            @hek
                            Now, I also got the computer to recognize the card. Thanks for all help.
                            The problem was that even when I used save as, the computer renaming the file as a .txt file "mysensors-samd.inf.txt" and not a "mysensors-samd.inf"
                            Again, thanks for all the help.
                            //Mattias
                              meddie
                              Hi together,
                              i have some questions to you! I bought a sensebender gateway and a w5100 Ethernet Modul, but i cant get it to work. When i upload the Gateway5100 Sketch and put my yip address in it, then the GW is booting up i get some Data on the serial port but i cant ping the configured ip address. Then i tried to config via DHCP and see that the GW dont get an IP Address.
                              And when i connect the NRF24 Modul then it seems that the GW is not bootin up anymore because i dont get any data on serial port.
                              i need your help. Thanks a lot in advance
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @meddie
                                Could you please post the logs that you get on the serial port, when the W5100 is attached?
                                Do you get anything on the serial port if you configure the sensebender to be a serial gateway, and only add a NRF24 module to it?
                                  meddie
                                  Hi tbowmo,
                                  with the gatewayw5100 Sketch i get every 10 seconds 5 lines output on serial monitor:
                                  The sketch is default i changed only the ip adress
                                  0;255;3;0;9;TSM:FAIL:RE-INIT
                                  0;255;3;0;9;TSM:INIT
                                  0;255;3;0;9;!TSM:INIT:TSP FAIL
                                  0;255;3;0;9;TSM:FAIL:CNT=3
                                  0;255;3;0;9;TSM:FAIL:PDT
                                  0;255;3;0;9;TSM:FAIL:CNT=4
                                  0;255;3;0;9;TSM:FAIL:CNT=5
                                  0;255;3;0;9;
                                  i dont know why, but i just uploaded the sensebenderserialgateway sketch and now i get this output:
                                  0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGS--,VER=2.1.1
                                  0;255;3;0;9;TSF:LRT:OK
                                  0;255;3;0;9;TSF:WUR:MS=0
                                  0;255;3;0;9;TSM:INIT:TSP OK
                                  0;255;3;0;9;TSM:INIT:GW MODE
                                  0;255;0;0;18;2.1.1
                                  0;255;3;0;9;MCO:BGN:STP
                                  0;255;3;0;9;
                                  the NRF Module is connected! Now i need to get the w5100 module to work.
                                    meddie
                                    wrote on last edited by meddie
                                    #177
                                    Ok i just connected the W5100 and NRF24 Module and uploaded the GatewayW5100 Sketch and when the upload is done after reset i dont get any output on serial monitor.
                                    The orange, green and red led are lighting.
                                    When i upload the SensebenderGatewaySerial then i get output on serial monitor. It think the problem must be the w5100. But what going wrong?
                                    alexsh1A 1 Reply Last reply
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @meddie
                                      Is it the standard GatewayW5100 sketch, without modifications, from the mysensors examples?
                                      If you have done any modifications to the sketch, then please post your modified sketch here.
                                        meddie
                                        i have only changed the ip adress
                                        here is the sketch:
                                         * Version 1.0 - Henrik EKblad
                                         * Contribution by Tomas Hozza <thozza@gmail.com>
                                         * LED purposes:
                                         * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
                                        #define MY_GATEWAY_W5100
                                        //#define MY_W5100_SPI_EN 4
                                        // radio on the same spi bus.
                                        #define MY_SOFTSPI
                                        #ifndef MY_RF24_CE_PIN
                                        #define MY_RF24_CE_PIN 5
                                        #ifndef MY_RF24_CS_PIN
                                        #define MY_RF24_CS_PIN 6
                                        // Enable to UDP
                                        //#define MY_USE_UDP
                                        #define MY_IP_ADDRESS 10,0,0,253   // If this is disabled, DHCP is used to retrieve address
                                        #define MY_PORT 5003
                                        //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
                                        // Enable inclusion mode
                                        // Set blinking period
                                        // Flash leds on rx/tx/err
                                        //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                                        //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                                        //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
                                        #if defined(MY_USE_UDP)
                                        #include <EthernetUdp.h>
                                        #include <Ethernet.h>
                                        J 1 Reply Last reply
                                        • M meddie
                                          here is the sketch:
                                           * LED purposes:
                                          #define MY_SOFTSPI
                                          // Enable to UDP
                                          J
                                          J
                                          jeti
                                          So I think i have a maybe already solved issue, but I can not get int working...
                                          In Arduino IDE 1.8.1 this is the error during compiling:
                                          "Local\Arduino15\packages\arduino\hardware\samd\1.6.12\cores\arduino/Arduino.h:48:17: fatal error: sam.h: No such file or directory"
                                          • I have the MySensors SAMD boards installed, so Sensbender Gateway is availabe
                                          • Arduino SAMD boards are also installed
                                          • I have installed the "M0" boards
                                          • Running windows 10 so no need for the inf file, is this correct?
                                          what am I missing?
                                          thanks in advance!
                                          tekkaT 1 Reply Last reply
