  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 255.8k Views 53 Watching
  • tbowmoT tbowmo
    @Anticimex
    I think something in the line of
    #if defined(ARDUINO_ARCH_SAMD)
    while (!Serial) {} // halts operation until something attaches to the USB device
    above, is based on hwInit function in MyHwSAMD.cpp
    AnticimexA
    AnticimexA
    Anticimex
    @tbowmo Yep, I have already (locally) done this:
    	while(!Serial()); // Wait for USB enumeration before setting up serial device
    	Serial.begin(MY_BAUD_RATE);
    • AnticimexA
      AnticimexA
      Anticimex
      I have moved the signing specific discussion in this thread here where it belongs.
      • FleischtorteF
        FleischtorteF
        Fleischtorte
        hi all,
        i have some problems to enable encryption on the gateway. When i upload the cleareeprom sketch, the gateway dont clear the eeprom,
        the same problem comes up when i want to set the ENC-Key. Both sketches work with my moteino-gateway and my ProMini-Node, so do i miss something with the SensebenderGW-Config?
        ClearEEPROM:
        while (!Serial) {} // Wait for USB enumeration before setting up serial device
        	Serial.println("Started clearing. Please wait...");
        	for (int i=0; i<EEPROM_LOCAL_CONFIG_ADDRESS; i++) {
        		hwWriteConfig(i,0xFF);
        	Serial.println("Clearing done. You're ready to go!");
        Set ENC-Key:
          Serial.println("Set ENC-Key. Please wait...");
            uint8_t key[32];
            memcpy(key, user_aes_key, 16);
            hwWriteConfigBlock((void*)key, (void*)EEPROM_RF_ENCRYPTION_AES_KEY_ADDRESS, 16);
            Serial.println("Set ENC-Key. Done");
        AnticimexA 1 Reply Last reply
        • FleischtorteF Fleischtorte
          hi all,
          ClearEEPROM:
          Set ENC-Key:
              uint8_t key[32];
          AnticimexA
          AnticimexA
          Anticimex
          @Fleischtorte we have confirmed a bug in the I2C eeprom management in the samd platform. A fix is in the works.
          • FleischtorteF
            FleischtorteF
            Fleischtorte
            @Anticimex okay, thanks for the fast response :+1:
            • scalzS scalz
              @alexsh1 why, i don't understand :stuck_out_tongue_winking_eye:
              Here it is : http://www.thingiverse.com/thing:2084269
              alexsh1A
              alexsh1A
              alexsh1
              @scalz Did you manage to do the 3D case for the PA LNA transceiver for the sensebender gateway please?
              • AnticimexA Anticimex
                @tbowmo ah, I will add that then for samd targets. The personalizer uses MY_CORE_ONLY so your line perhaps is not run.
                ted
                @Anticimex said in 💬 Sensebender Gateway:
                MY_CORE_ONLY
                Just curious, what does "MY_CORE_ONLY" do? The library mentioned that it should be enabled " if you want to use core functions without loading the framework" . What are the core functions and what is the framework?
                • T ted
                  MY_CORE_ONLY
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @ted core functions are things like the HAL and debug logging functionality. Framework means all the presentation message transmissions and handshaking. Basically, MY_CORE_ONLY allow you to leverage the functionality provided by the library without having the library execute things out of your control.
                  • scalzS
                    scalzS
                    wrote on last edited by scalz
                    #209
                    @alexsh1
                    woops, yes i made it but forgot the upload. it's now uploaded here https://www.mysensors.org/hardware/sensebender-gateway#design-files
                    Enjoy :)
                    alexsh1A zboblamontZ 2 Replies Last reply
                    • scalzS scalz
                      @alexsh1
                      Enjoy :)
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #210
                      @scalz Thank you.
                      Does anyone have the PA transceiver version with Sensebender Gateway?
                      Any feedback please?
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @alexsh1
                        If you mean using a nrf24 with lna/pa, with the gateway. Then yes.. I have had it running for some months now.
                        Anything in particular that you want to know?
                        alexsh1A 1 Reply Last reply
                        • tbowmoT tbowmo
                          @alexsh1
                          alexsh1A
                          alexsh1A
                          alexsh1
                          #212
                          @tbowmo yes, that's what I meant
                          I am thinking about installing either a normal nrf24l01+ or lna/pa version. I have had some issues with power in the past with the lna/pa transceiver.
                          What's your experience? What kind of power supply do you use? How better is the coverage?
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            I haven't checked if the coverage is any better with the lna/pa version, compared to standard modules.
                            Currently the gateway is connected to a RPI2, which in turn is powered by a 2A powersupply from RS Components
                            I haven't had any issues with it yet, but then again.. I mainly receive data from sensor nodes, and not that much sending data to distant nodes from the gateway
                            • tbowmoT tbowmo
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @tbowmo It is probably not Sensebender topic, but more lna+pa range one.
                              I am not sure about my RPi3 as though it is powered by the 3A PSU, I have a USB z-wave stick, three transceivers, one UPS Plco (as HAT) and a 20x4 screen. I lot of power is consumed so not sure adding yet another one. (lna+pa is power hungry during peaks).
                              I'll get the nrf24l01+ lna+pa ordered and test the range. In my view rfm69 range is probably better, but I have the rfm69 gateway on moteino with a trace antenna (very small footprint and it is based on ATMega1284P so 128KB sketch flash memory - more than I need).
                              @hek - is it the intention to combine rfm69 and nrf24l01+ gateways in one in the future?
                              I understand Sensebender GW is ready for it, but it is more a software limitation???
                              I am really looking forward to combined GW.
                              I also have a separate one for rfm95 so that I can use some remote sensors.
                                wrote on last edited by hek
                                #215
                                No, I haven't heard of any near plans in the core team about doing multi radio/sub-network support in 2.0.
                                This requires some extra thoughts and would probably only fit on SAMD/ESP nodes.
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @hek Which is good as the Sensebender GW is based on SAMD! So it is ready to be the first 2-in-1 GW.
                                  Anyway, keep on doing a great work! I'll patiently wait until the combined GW is there.
                                  • NiklasON
                                    NiklasON
                                    NiklasO
                                    wrote on last edited by NiklasO
                                    #217
                                    Ordered from ITEAD. Nice to get rid of this stuff:
                                    Just nudging anything result in problems. ;-)
                                    Time to fire up the 3D-printer.
                                    • NiklasON
                                      NiklasON
                                      NiklasO
                                      #218
                                      Aaaand, it's up! Very good fit (the box).
                                      The box on top is just me trying out different colors of the case. ;)
                                      The one on top has better look. Different brands of PLA.
                                      • nick van alstN
                                        nick van alstN
                                        nick van alst
                                        @NiklasO that looks very good!
                                        Are you willing to share your design files with us?
                                        i just ordered my gateway to get rid of cables and lose components :D a case would really make it complete!
                                        • scalzS
                                          scalzS
                                          @NiklasO
                                          great :+1:
                                          @nick-van-alst
                                          you can get enclosure design files here https://www.mysensors.org/hardware/sensebender-gateway (on page bottom)
                                          I designed different variants so pick which one you need.
