  3. My first project, KAKU RF reciever/transmitter
1 Posts 1 Posters 1.8k Views
  • A
    A
    arnoldg
    I build my first mysensor project around an Arduino nano and some cheap RF reciever/transmitter.
    The code could be optimized, maybe some kind of self learning, but don't know how to do that :)
    Also like to decode the recived signal to normal code like (KAKU code A,1)
    So feel free to give some advise ;)
     * Version 1.1 - Arnold Geurtse
     * This sketch is to control my RF433 KAKU plugins with mysensor
     * in this case i use the old rotating switch type recievers
     * Reciver connected to pin 3
     * Transmitter connected to pin 7
     * As transmitter/reciver library i use this site
     * https://bitbucket.org/fuzzillogic/433mhzforarduino/wiki/Home
     * also going to build a beter antene for the reciver and transmitter.
     * http://www.elektor.nl/Uploads/Forum/Posts/How-to-make-a-Air-Cooled-433MHz-antenna.pdf
    #include <RemoteTransmitter.h>
    #include <RemoteReceiver.h>
    #define MY_NODE_ID 100
    #define NODE_TXT "RF433 interface"
    #define CHILD_ID1 1   // Id of the sensor child
    #define CHILD_ID2 2   // Id of the sensor child
    #define CHILD_ID3 3   // Id of the sensor child
    #define CHILD_ID4 4   // Id of the sensor child
    #define CHILD_ID5 5   // Id of the sensor child
    #undef MY_DEBUG;
    MyMessage switch1(CHILD_ID1, V_LIGHT);
    MyMessage switch2(CHILD_ID2, V_LIGHT);
    MyMessage switch3(CHILD_ID3, V_LIGHT);
    MyMessage switch4(CHILD_ID4, V_LIGHT);
    MyMessage switch5(CHILD_ID5, V_LIGHT);
    bool State;
    // Intantiate a new KaKuTransmitter remote, also use pin 11 (same transmitter!)
    KaKuTransmitter kaKuTransmitter(7);
      gw.begin(incomingMessage,MY_NODE_ID);
      gw.sendSketchInfo("RF 433 kaku interface", "1.0");
      gw.present(CHILD_ID1, S_LIGHT, "Keuken", NODE_TXT);
      gw.present(CHILD_ID2, S_LIGHT, "Computer", NODE_TXT);
      gw.present(CHILD_ID3, S_LIGHT, "Bank", NODE_TXT);
      gw.present(CHILD_ID4, S_LIGHT, "Vensterbank", NODE_TXT);
      gw.present(CHILD_ID5, S_LIGHT, "TV", NODE_TXT);
        // Initialize receiver on interrupt 0 (= digital pin 2), calls the callback "showCode"
      // after 3 identical codes have been received in a row. (thus, keep the button pressed
      // for a moment)
      // See the interrupt-parameter of attachInterrupt for possible values (and pins)
      // to connect the receiver.
      RemoteReceiver::init(0, 3, showCode);
      gw.process();
    void showCode(unsigned long receivedCode, unsigned int period) {
        switch (receivedCode) {
          case 24:
            gw.send(switch1.set(0));
          break;
          case 26:
            gw.send(switch1.set(1));
          break;
          case 4398:
            gw.send(switch2.set(0));
          break;
          case 4400:
            gw.send(switch2.set(1));
          break;
          case 1482:
            gw.send(switch3.set(0));
          break;
          case 1484:
            gw.send(switch3.set(1));
          break;
          case 354318:
            gw.send(switch4.set(0));
          break;
          case 354320:
            gw.send(switch4.set(1));
          break;
          case 358692:
            gw.send(switch5.set(0));
          break;
          case 358694:
            gw.send(switch5.set(1));
          break;
         // Change relay state
        State = message.getBool();
        switch (message.sensor) {
          case 1:
            kaKuTransmitter.sendSignal('A',1,State);
          break;
          case 2:
            kaKuTransmitter.sendSignal('A',2,State);
          break;
          case 3:
            kaKuTransmitter.sendSignal('A',3,State);
          break;
          case 4:
            kaKuTransmitter.sendSignal('B',1,State);
          break;
          case 5:
            kaKuTransmitter.sendSignal('B',2,State);
          break;
