  3. Sensebender Module Problem
2 Posts 2 Posters 981 Views 2 Watching
  • T
    tcontrada
    I just received my Sensebender today and I am having an issue getting it work correctly.
    When I tie A0 to GND for the self test this is what I get from the Serial Monitor:
    Sensebender Micro FW 1.3 - TestMode
    Testing peripherals!
    -> SI7021 : ok!
    -> Flash : failed!
    -> SHA204 : Ok (serial : 0123753C526A1A06EE)
    Test finished
    ----> Selftest failed!
    Also, in normal mode no data gets transmitted to my Gateway. The only change I made to the sketch was to specify a unique Node ID (4) in this case.
    Any suggestions?
    Thanks,
    Tony
      Did the self-test pass before you re-flashed it?
