  3. Home Assistant
  4. Home Assistant v 0.11.1 with switch support
switchserial gatewayhome assistant
53 Posts 5 Posters 28.5k Views 5 Watching
  • martinhjelmareM
    martinhjelmareM
    martinhjelmare
    #21
    I'm not sure that the library provided with mysensors supports DHT21 (AM2301). The readme for DHT library only mentions "DHT11 and DHT22, AM2302, RHT03".
    But I found this post, where the adafruit library is used together with mysensors:
    http://forum.mysensors.org/topic/841/solar-powered-mini-weather-station/53
    As long as you get your temp/hum sensors going with the correct library there shouldn't be a problem of presenting them as mysensors sensors to home assistant.
      mirko314
      wrote on last edited by mirko314
      #22
      Well I will look into, thank you!
      I do not know if this is the right place for further problems, if not tell me.
      I tried to remote control a relay today
      I used the official sketch of MYS at https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/RelayActuator/RelayActuator.ino
      Even though it Looks like they are properly connected, there is no switch appearing on HA-Dashboard.
      Log of the Sensor-Arduino Running RelayActuator.ino:
      send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
      send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
      read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
      repeater started, id=1, parent=0, distance=1
      send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
      send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
      send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
      Log of HA:
      INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
      INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
      INFO:homeassistant.components.sensor:Updating sensor entities
      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.1
      INFO:homeassistant.components.mysensors:update sensor_update: node 1
      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
      INFO:homeassistant.components.device_tracker.nmap_tracker:Scanning
      INFO:homeassistant.components.device_tracker.nmap_tracker:No MAC address found for 192.168.2.111
      INFO:homeassistant.components.device_tracker.nmap_tracker:nmap scan successful
      INFO:homeassistant.components.mysensors:update sensor_update: node 1```
        mirko314
        #23
        Sorry, I forgot to ask, is it implemented yet? :D
        I just scrambled through the code at HA
        https://github.com/balloob/home-assistant/blob/dev/homeassistant/components/switch/mysensors.py
        and I could not detect the RELAY type. But than again I do not know alot of both of the systems, just guessing.
        • M mirko314
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @mirko314
          You should send a value from the node child to set initial state also. I think that's what's missing.
          Read my post here:
          http://forum.mysensors.org/topic/2388/home-assistant-how-to-recognize-mysensors-nodes/27
            mirko314
            #25
            @martinhjelmare
            Would you mind to elaborate a bit more?
            I am not sure how to alter the script.
            • M mirko314
              @martinhjelmare
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              #26
              @mirko314
              For example:
              MyMessage msgArray[NUMBER_OF_RELAYS];
              for (int sensor=1; sensor<=NUMBER_OF_RELAYS;sensor++) {
                  msgArray[sensor-1] = msg(sensor, V_STATUS);
                  gw.begin();
                      gw.present(sensor, S_BINARY);
                      gw.send(msgArray[sensor-1].set(0));
              If you don't need to send any more messages after the setup funtion, ie access the message variables in the array anywhere else, you can move the assigning of the array in the first for loop to the second for loop in the setup function, to avoid code duplication.
              You need to send at least one value per child to populate all data structures in home assistant.
              Edit: You can actually move the assigning of the array and only have one for loop, inside the setup funtion, anyhow, since the array is initialized separately outside the functions.
              • D
                D
                drock1985
                Hi @martinhjelmare
                I have installed 0.11.1 and added the lines to configuration.yaml, but my sensors are bit showing in ha itself. The ID of the nodes is being passed to ha in the log, but nothing else. Trying to set to a pir, temp/humid, and relay switches.
                My Projects
                2 Door Chime Sensor
                Washing Machine Monitor
                • D drock1985
                  Hi @martinhjelmare
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @drock1985
                  Please show me the home assistant log. I can't really say anything useful without it.
                  • D
                    D
                    drock1985
                    Hi @martinhjelmare
                    here is the output from /home/pi/.homeassistant/home-assistant.log:
                    6-01-24 15:08:16 netdisco.ssdp: Found malformed XML at http://192.168.86.142:9080: status=ok
                    This is my configuration.yaml
                    homeassistant:
                      # Name of the location where Home Assistant is running
                      # Location required to calculate the time the sun rises and sets
                      latitude:
                      longitude:
                      # C for Celcius, F for Fahrenheit
                      temperature_unit: C
                      # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
                      time_zone: America/Halifax
                    # Enables the frontend
                    frontend:
                    # Checks for available updates
                    updater:
                    # View all events in a logbook
                    logbook:
                    # Track the sun
                    sun:
                    # Enables support for tracking state changes over time.
                    history:
                    # Show links to resources in log and frontend
                    #introduction:
                    # Allows you to issue voice commands from the frontend
                    conversation:
                    # Discover some devices automatically
                    discovery:
                    # Webcams
                    camera 1:
                      platform: mjpeg
                      mjpeg_url: http://192.168.86.117:10012/videofeed
                      username: root
                      password: groot
                    # Squeezebox Server
                    media_player 1:
                      platform: squeezebox
                      host: 192.168.86.113
                      port: 9090
                    # MySensors Serial Gateway
                    mysensors:
                      gateways:
                        - port: '/dev/ttyUSB0'
                          persistence_file: '/home/pi/.homeassistant/mysensors.json'
                    #  debug: true
                      persistence: true
                      version: '1.5'
                    Would it be because my nodes are set for manual ID and not auto?
                    My Projects
                    2 Door Chime Sensor
                    • D drock1985
                      Hi @martinhjelmare
                      homeassistant:
                        latitude:
                        longitude:
                        temperature_unit: C
                      frontend:
                      updater:
                      logbook:
                      # Track the sun
                      sun:
                      history:
                      #introduction:
                      conversation:
                      discovery:
                      # Webcams
                      camera 1:
                        platform: mjpeg
                        username: root
                        password: groot
                      # Squeezebox Server
                      media_player 1:
                        port: 9090
                      mysensors:
                        gateways:
                      #  debug: true
                        persistence: true
                        version: '1.5'
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @drock1985
                      The log file only outputs errors as default. Try starting home assistant from the command line with hass and then copy the output. It should be a lot more than one line.
                      You should shut down home assistant first if you have it running as a service.
                      Activate debug first for mysensors though.
                      • D
                        D
                        drock1985
                        @martinhjelmare
                        Here is the .log file
                        16-01-24 15:25:28 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
                        And from the SSH console after running hass as instructed
                        INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.111
                        INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
                        INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.108
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; supported_media_commands=1021, friendly_name=Master Bedroom @ 15:25:41 24-01-2016>, entity_id=media_player.master_bedroom>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; supported_media_commands=1021, friendly_name=Man Cave @ 15:25:41 24-01-2016>, entity_id=media_player.man_cave>
                        INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "CatFan">
                        INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "LivingRoomLamp">
                        INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "CatFan">
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.living_room=off; supported_media_commands=1021, friendly_name=Living Room @ 15:25:41 24-01-2016>, entity_id=media_player.living_room>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.catfan=off; friendly_name=CatFan @ 15:25:41 24-01-2016>, entity_id=switch.catfan>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=unknown; auto=True, entity_id=[], friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan',), friendly_name=all switches @ 15:25:41 24-01-2016>, entity_id=group.all_switches>
                        INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "LivingRoomLamp">
                        INFO:pywemo.subscribe:Received event from <WeMo Switch "CatFan">(192.168.86.108)
                        INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "CatFan">
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.livingroomlamp=off; friendly_name=LivingRoomLamp @ 15:25:42 24-01-2016>, entity_id=switch.livingroomlamp>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
                        INFO:pywemo.subscribe:Received event from <WeMo Switch "LivingRoomLamp">(192.168.86.163)
                        INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "LivingRoomLamp">
                        INFO:pywemo.subscribe:Subscribing to events from <WeMo Insight "Christmas Tree Lights">
                        INFO:pywemo.subscribe:Resubscribe for <WeMo Insight "Christmas Tree Lights">
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.christmas_tree_lights=off; friendly_name=Christmas Tree Lights @ 15:25:42 24-01-2016>, entity_id=switch.christmas_tree_lights>
                        INFO:pywemo.subscribe:Received event from <WeMo Insight "Christmas Tree Lights">(192.168.86.111)
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; auto=True, entity_id=('switch.christmas_tree_lights', 'switch.catfan', 'switch.livingroomlamp'), friendly_name=all switches @ 15:25:42 24-01-2016>, entity_id=group.all_switches>
                        INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Insight "Christmas Tree Lights">
                        INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.117
                        INFO:homeassistant.components.http:"GET /states HTTP/1.1" 200 -
                        INFO:homeassistant.components.http:"GET /static/frontend-1003c31441ec44b3db84b49980f736a7.html HTTP/1.1" 200 -
                        INFO:homeassistant.components.http:"GET /static/favicon-192x192.png HTTP/1.1" 200 -
                        INFO:homeassistant.components.http:"GET /static/favicon.ico HTTP/1.1" 200 -
                        INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
                        INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                        INFO:homeassistant.components.media_player:Updating media_player entities
                        INFO:homeassistant.components.http:"GET /api/error_log HTTP/1.1" 200 -
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=2,c=1,t=16,pt=0,l=1,sg=0:1
                        INFO:homeassistant.components.light:Updating light entities
                        INFO:homeassistant.components.camera:Updating camera entities
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663530.5116684, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
                        INFO:homeassistant.components.mysensors:update sensor_update: node 3
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-3-3 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=11,pt=0,l=25,sg=0:2 Door bell/chime
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=0,c=0,t=1,pt=0,l=0,sg=0:
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=3,c=0,t=3,pt=0,l=0,sg=0:
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-3-0 s=2,c=0,t=1,pt=0,l=0,sg=0:
                        INFO:homeassistant.components.api:Found broken event stream to 192.168.86.162, cleaning up
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663560.5128732, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.88, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.5
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.6
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663590.5271018, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663650.5204854, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453663620.51471, friendly_name=LivingRoom Camera @ 15:25:24 24-01-2016>, entity_id=camera.livingroom_camera>
                        INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.63, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=11:43:05 25-01-2016, elevation=14.76, next_setting=21:15:13 24-01-2016, friendly_name=Sun @ 15:25:24 24-01-2016>, entity_id=sun.sun>
                        My Projects
                        2 Door Chime Sensor
                        • D drock1985
                          @martinhjelmare
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @drock1985
                          Is it node 3 that is missing for you? It seems you're presenting it fine but never send the needed value for the four sensors, 0-3, on the node.
                          Then you also have node 1 with two sensors 0 and 2 that seems to update, but you haven't posted the beginning of the log where those are presented or loaded from persistence. I'm also missing the gateway started confirmation in the log.
                          • D
                            D
                            drock1985
                            Hi @martinhjelmare
                            the file /home/pi/.homeassistant/home-assistant.log has no errors in it, and it's all of my nodes that are missing (1 through 4 and 6), Node 5 isn't online right now.
                            Is that what you are looking for at the top?
                            INFO:homeassistant.components.recorder:Closing database
                            pi@home-assistant:~/.homeassistant $ clear
                            pi@home-assistant:~/.homeassistant $ hass
                            Config directory: /home/pi/.homeassistant
                            WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                            INFO:homeassistant.bootstrap:Home Assistant core initialized
                            INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                            INFO:homeassistant.loader:Loaded media_player from homeassistant.components.media_player
                            INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                            INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                            INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                            INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                            INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                            INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                            INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                            INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                            INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                            INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                            INFO:homeassistant.loader:Loaded camera from homeassistant.components.camera
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                            INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, discovered=>
                            INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                            INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, discovered=>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                            INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                            INFO:homeassistant.loader:Loaded media_player.squeezebox from homeassistant.components.media_player.squeezebox
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.airspeaker=off; friendly_name=AirSpeaker, supported_media_commands=447 @ 17:05:03 24-01-2016>, entity_id=media_player.airspeaker>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_fireplace>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_epic_sax>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_youtube_video>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=media_player>
                            INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>, entity_id=sun.sun>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                            INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                            /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
                              warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                            INFO:homeassistant.loader:Loaded camera.mjpeg from homeassistant.components.camera.mjpeg
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camera>
                            INFO:homeassistant.core:Starting Home Assistant (17 threads)
                            INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                            INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
                            INFO:homeassistant.core:Timer:starting
                            INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                            INFO:homeassistant.components.mysensors:update persistence: node 2
                            INFO:homeassistant.components.mysensors:No sketch_name: node 2
                            INFO:homeassistant.components.mysensors:update persistence: node 3
                            INFO:netdisco.service:Scanning
                            WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
                            INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.4
                            INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.113
                            INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.101
                            INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.142
                            INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.199
                            INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.102
                            INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.4:32469/DeviceDescription.xml
                            INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.113:9000/plugins/UPnP/MediaServer.xml
                            INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.101', 8009)
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.101', 8009)>
                            INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.102', 8009)
                            INFO:homeassistant.loader:Loaded media_player.cast from homeassistant.components.media_player.cast
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.102', 8009)>
                            INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')>
                            INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')>
                            INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')
                            INFO:homeassistant.loader:Loaded switch.wemo from homeassistant.components.switch.wemo
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')>
                            ERROR:homeassistant.components.switch:Error while setting up platform wemo
                            Traceback (most recent call last):
                              File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 145, in _setup_platform
                                self.hass, platform_config, self.add_entities, discovery_info)
                              File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/wemo.py", line 25, in setup_platform
                                import pywemo.discovery as discovery
                            AttributeError: 'module' object has no attribute 'discovery'
                            INFO:pychromecast:Querying device status
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.man_cave=off; friendly_name=Man Cave, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.man_cave>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.master_bedroom=off; friendly_name=Master Bedroom, supported_media_commands=1021 @ 17:05:19 24-01-2016>, entity_id=media_player.master_bedroom>
                            INFO:homeassistant.components.discovery:Found new service: plex_mediaserver ('Rocknet Server', 'https://192.168.86.4:32400')
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=plex_mediaserver, discovered=('Rocknet Server', 'https://192.168.86.4:32400')>
                            INFO:homeassistant.components.discovery:Found new service: philips_hue ('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')
                            INFO:homeassistant.loader:Loaded media_player.plex from homeassistant.components.media_player.plex
                            INFO:homeassistant.loader:Loaded light from homeassistant.components.light
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_on>
                            INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_off>
                            INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light>
                            INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=philips_hue, discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')>
                            INFO:homeassistant.loader:Loaded light.hue from homeassistant.components.light.hue
                            INFO:phue:Attempting to connect to the bridge...
                            INFO:phue:Using ip: 192.168.86.199
                            INFO:phue:Using username from config: 30f609e6210320e41f0dfc32220a525f
                            Exception in thread Thread-25:
                              File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
                                self.run()
                              File "/home/pi/.homeassistant/lib/zeroconf.py", line 1063, in run
                                handler(self.zc)
                              File "/home/pi/.homeassistant/lib/zeroconf.py", line 1014, in <lambda>
                                state_change=state_change,
                              File "/home/pi/.homeassistant/lib/zeroconf.py", line 931, in fire
                                h(**kwargs)
                              File "/home/pi/.homeassistant/lib/zeroconf.py", line 989, in on_change
                                listener.add_service(*args)
                              File "/home/pi/.homeassistant/lib/netdisco/discoverables/__init__.py", line 84, in add_service
                                service = zconf.get_service_info(typ, name)
                              File "/home/pi/.homeassistant/lib/zeroconf.py", line 1404, in get_service_info
                                if info.request(self, timeout):
                              File "/home/pi/.homeassistant/lib/zeroconf.py", line 1221, in request
                                zc.send(out)
                              File "/home/pi/.homeassistant/lib/zeroconf.py", line 1663, in send
                                bytes_sent = s.sendto(packet, 0, (addr, port))
                            OSError: [Errno 9] Bad file descriptor
                            INFO:plexapi:GET http://192.168.86.4:32400/
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_1>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_2>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.aprils_lamp=off; friendly_name=April's lamp @ 17:05:20 24-01-2016>, entity_id=light.aprils_lamp>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_1>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_light_strip>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>, entity_id=light.living_room_light_2>
                            INFO:homeassistant.components.media_player.plex:Connected to: htts://192.168.86.4:32400
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 17:05:20 24-01-2016>, entity_id=light.master_bedroom_3>
                            INFO:plexapi:GET http://192.168.86.4:32400/clients
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=unknown; entity_id=[], friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>, entity_id=group.all_lights>
                            INFO:plexapi:GET http://192.168.86.4:32400/status/sessions
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669504.2007444 @ 17:05:04 24-01-2016>>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.1 @ 17:05:03 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_setting=21:15:13 24-01-2016, next_rising=11:43:05 25-01-2016, friendly_name=Sun, elevation=1.17 @ 17:05:03 24-01-2016>>
                            INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_1, service_call_id=1981876976-1, service=turn_on>
                            INFO:homeassistant.loader:Loaded group from homeassistant.components.group
                            INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_1'], service_call_id=1981876976-2, service=turn_on>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=on; brightness=254, friendly_name=Living room light 1 @ 17:05:47 24-01-2016>, entity_id=light.living_room_light_1, old_state=<state light.living_room_light_1=off; friendly_name=Living room light 1 @ 17:05:20 24-01-2016>>
                            INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-2>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=on; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:47 24-01-2016>, entity_id=group.all_lights, old_state=<state group.all_lights=off; entity_id=('light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_3', 'light.master_bedroom_2', 'light.master_bedroom_1', 'light.master_bedroom_light_strip', 'light.aprils_lamp'), friendly_name=all lights, auto=True @ 17:05:20 24-01-2016>>
                            INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-1>
                            INFO:homeassistant.components.http:"POST /api/services/homeassistant/turn_on HTTP/1.1" 200 -
                            INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_2 HTTP/1.1" 200 -
                            INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=homeassistant, entity_id=light.living_room_light_2, service_call_id=1981876976-3, service=turn_on>
                            INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=light, entity_id=['light.living_room_light_2'], service_call_id=1981876976-4, service=turn_on>
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=on; brightness=254, friendly_name=Living room light 2 @ 17:05:49 24-01-2016>, entity_id=light.living_room_light_2, old_state=<state light.living_room_light_2=off; friendly_name=Living room light 2 @ 17:05:20 24-01-2016>>
                            INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-4>
                            INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=1981876976-3>
                            INFO:homeassistant.components.http:"GET /api/history/period?filter_entity_id=light.living_room_light_1 HTTP/1.1" 200 -
                            INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669560.5092123 @ 17:05:04 24-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453669530.5242217 @ 17:05:04 24-01-2016>>
                            INFO:homeassistant.components.http:"GET /devInfo HTTP/1.1" 200 -
                            ^CINFO:homeassistant.core:Stopping
                            INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
                            INFO:mysensors.mysensors:Disconnecting from /dev/ttyUSB0
                            INFO:mysensors.mysensors:Stopping thread
                            My Projects
                            2 Door Chime Sensor
                            • D
                              D
                              drock1985
                              I'm still trying to get this to work, with mixed results. Noticed on startup sometimes that HA was starting before my Serial port was initialized. Added a .timer file to delay the start of HA until the Pi is fully booted. Still having problems, but now i'm getting this in the HA logs:
                              16-01-24 18:37:40 homeassistant.core: BusHandler:Exception doing job
                                File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 829, in job_handler
                                  func(arg)
                                File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 302, in onetime_listener
                                  listener(event)
                                File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 104, in gw_start
                                  gateway.event_callback('persistence', node_id)
                                File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 226, in node_update
                                  callback(self, node_id)
                                File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 165, in mysensors_callback
                                  add_devices(devices[node_id])
                                File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 81, in add_entities
                                  entity.update_ha_state()
                                File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 108, in update_ha_state
                                  self.unit_of_measurement is not None:
                                File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/mysensors.py", line 137, in unit_of_measurement
                                  self.value_type == self.gateway.const.SetReq.V_PERCENTAGE or \
                                File "/usr/lib/python3.4/enum.py", line 255, in __getattr__
                                  raise AttributeError(name) from None
                              AttributeError: V_PERCENTAGE
                              16-01-24 18:37:43 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
                              My Projects
                              2 Door Chime Sensor
                              • D drock1985
                                    func(arg)
                                    listener(event)
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @drock1985
                                I think you need to delete the persistence file and start over and present your sensors. You should do this while looking at the output from hass so you get feedback if it's working or not.
                                From the top of your log output there was a warning about bad byte from the gateway. The gateway started confirmation was never logged. You should see this before you start your sensors. If you don't get the gateway confirmation, try restarting home assistant.
                                Also in the log, the persistence file loaded sensor 2 and 3, but some data was missing, probably. There was a note about missing sketch name for one of the sensors.
                                You need to present the sensors properly, including sketch name and then send one value per sensor before they show up in the gui.
                                • asmA
                                  asmA
                                  asm
                                  Hey @drock1985 , would you please update the thread if you are able to work around this ? I am experiencing something similar after my latest upgrade: None of the sensors appear in the UI. I have disabled persistence and removed the json files, and presented the nodes again, but still nothing appears. In debug mode I can see the messages from the Humidity sensor, for instance, but that's all.
                                  D 1 Reply Last reply
                                  • asmA asm
                                    D
                                    D
                                    drock1985
                                    Hi @asm and @martinhjelmare
                                    Still having issues after multiple restarts and two different nano's and NRF radios. I am like you, can see the messages but whatever I try I can't get rid of the bad byte error in the beginning.
                                    Going to try a uno next and see if that changes anything.
                                    My Projects
                                    2 Door Chime Sensor
                                    • D drock1985
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @drock1985
                                      What version of pyserial do you have installed?
                                      pip show pyserial
                                      Try version 2.5, which has been the least buggy for me.
                                      pip3 install pyserial==2.5
                                      pip show will not output anything if you have version 2.5 of pyserial installed.
                                      • D
                                        D
                                        drock1985
                                        I have 2.7 installed right now; installing 2.5 and i'll reboot and see what happens.
                                        My Projects
                                        2 Door Chime Sensor
                                        • D
                                          D
                                          drock1985
                                          Hi @martinhjelmare
                                          I have installed pyserial2.5, but I still get errors. This is the latest when using an Arduino Uno (not genuine, but pretty close) and I do not see the unexpected byte messages anymore. Still not getting anything to show though.
                                           hass
                                          WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring dis                                                             abled
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas                                                             sistant, service=turn_off>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas                                                             sistant, service=turn_on>
                                          INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discove                                                             ry
                                          INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysenso                                                             rs
                                          INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conv                                                             ersation
                                          INFO:homeassistant.loader:Loaded media_player from homeassistant.components.medi                                                             a_player
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recor                                                             der>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbo                                                             ok>
                                          INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.co                                                             m
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state s                                                             un.sun=below_horizon; elevation=-12.86, next_setting=21:17:57 26-01-2016, friend                                                             ly_name=Sun, next_rising=11:42:09 26-01-2016 @ 18:28:34 25-01-2016>, entity_id=s                                                             un.sun>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updat                                                             er>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=disco                                                             very>
                                          INFO:homeassistant.loader:Loaded camera.mjpeg from homeassistant.components.came                                                             ra.mjpeg
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state c                                                             amera.livingroom_camera=idle; friendly_name=LivingRoom Camera, entity_picture=/a                                                             pi/camera_proxy/camera.livingroom_camera?time=1453760914.813284 @ 18:28:34 25-01                                                             -2016>, entity_id=camera.livingroom_camera>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camer                                                             a>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=front                                                             end>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=histo                                                             ry>
                                          INFO:mysensors.mysensors:File does not exist or is not readable: /home/pi/.homea                                                             ssistant/mysensors1.pickle
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=senso                                                             r>
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=myse                                                             nsors.sensors, discovered=>
                                          INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.                                                             sensor.mysensors
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch                                                             , service=turn_off>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch                                                             , service=turn_on>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switc                                                             h>
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=myse                                                             nsors.switches, discovered=>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysen                                                             sors>
                                          INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.                                                             switch.mysensors
                                          /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-                                                             python SequenceMatcher. Install python-Levenshtein to remove this warning
                                            warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levensht                                                             ein to remove this warning')
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conver                                                             sation, service=process>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conve                                                             rsation>
                                          INFO:homeassistant.loader:Loaded media_player.squeezebox from homeassistant.comp                                                             onents.media_player.squeezebox
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state m                                                             edia_player.airspeaker=off; friendly_name=AirSpeaker, supported_media_commands=4                                                             47 @ 18:28:35 25-01-2016>, entity_id=media_player.airspeaker>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_next_track>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_play>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=volume_up>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_pause>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=turn_on>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=turn_off>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=volume_down>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_play_pause>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=play_media>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_previous_track>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=volume_set>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=volume_mute>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=media_seek>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=start_fireplace>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=start_epic_sax>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_                                                             player, service=play_youtube_video>
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=media                                                             _player>
                                          INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas                                                             sistant, service=stop>
                                          INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set                                                             &restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                                          Exception in thread Thread-14:
                                              self.run()
                                            File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 312, in run
                                              response = self.handle_queue()
                                            File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 222, in handle                                                             _queue
                                              reply = func(*args, **kwargs)
                                            File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 105, in logic
                                              msg = Message(data)
                                            File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 397, in __init                                                             __
                                              self.decode(data)
                                            File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 417, in decode
                                              self.sub_type) = [int(f) for f in data]
                                            File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 417, in <listc                                                             omp>
                                          ValueError: invalid literal for int() with base 10: '\x00\x00\x00\x00\x00\x00\x0                                                             0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x0                                                             0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x0                                                             0\x00\x00\x0
                                          INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light                                                             >
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=phil                                                             ips_hue, discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/'                                                             )>
                                          INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('CatFan'                                                             , 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belk                                                             in_wemo, discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml'                                                             , '94103E30CDBC')>
                                          INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('LivingR                                                             oomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belk                                                             in_wemo, discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/se                                                             tup.xml', '94103E30C688')>
                                          INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.8                                                             6.113:9000/plugins/UPnP/MediaServer.xml
                                          INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.8                                                             6.4:32469/DeviceDescription.xml
                                          INFO:homeassistant.loader:Loaded light.hue from homeassistant.components.light.h                                                             ue
                                          INFO:homeassistant.loader:Loaded switch.wemo from homeassistant.components.switc                                                             h.wemo
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.aprils_lamp=off; friendly_name=April's lamp @ 18:28:50 25-01-2016>, entity_                                                             id=light.aprils_lamp>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 18:28:50 25-01-2016>                                                             , entity_id=light.master_bedroom_3>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 18:28:50 25-01-2016>                                                             , entity_id=light.master_bedroom_2>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.living_room_light_2=on; brightness=254, friendly_name=Living room light 2 @                                                              18:28:50 25-01-2016>, entity_id=light.living_room_light_2>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 18:28:50 25-01-2016>                                                             , entity_id=light.master_bedroom_1>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.living_room_light_1=on; brightness=254, friendly_name=Living room light 1 @                                                              18:28:50 25-01-2016>, entity_id=light.living_room_light_1>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state l                                                             ight.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @                                                              18:28:50 25-01-2016>, entity_id=light.master_bedroom_light_strip>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state g                                                             roup.all_lights=unknown; friendly_name=all lights, entity_id=[], auto=True @ 18:                                                             28:50 25-01-2016>, entity_id=group.all_lights>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state g                                                             roup.all_lights=on; friendly_name=all lights, entity_id=('light.living_room_ligh                                                             t_1', 'light.aprils_lamp', 'light.master_bedroom_light_strip', 'light.living_roo                                                             m_light_2', 'light.master_bedroom_1', 'light.master_bedroom_2', 'light.master_be                                                             droom_3'), auto=True @ 18:28:50 25-01-2016>, entity_id=group.all_lights>
                                          INFO:pywemo.subscribe:Listening on port 8989
                                          INFO:homeassistant.components.discovery:Found new service: plex_mediaserver ('Ro                                                             cknet Server', 'https://192.168.86.4:32400')
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=plex                                                             _mediaserver, discovered=('Rocknet Server', 'https://192.168.86.4:32400')>
                                          INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168                                                             .86.101', 8009)
                                          INFO:homeassistant.loader:Loaded media_player.plex from homeassistant.components                                                             .media_player.plex
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=goog                                                             le_cast, discovered=('192.168.86.101', 8009)>
                                          INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168                                                             .86.142', 8009)
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=goog                                                             le_cast, discovered=('192.168.86.142', 8009)>
                                          INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168                                                             .86.102', 8009)
                                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=goog                                                             le_cast, discovered=('192.168.86.102', 8009)>
                                          INFO:homeassistant.loader:Loaded media_player.cast from homeassistant.components                                                             .media_player.cast
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state s                                                             witch.catfan=off; friendly_name=CatFan @ 18:28:51 25-01-2016>, entity_id=switch.                                                             catfan>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state g                                                             roup.all_switches=unknown; friendly_name=all switches, entity_id=[], auto=True @                                                              18:28:51 25-01-2016>, entity_id=group.all_switches>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state g                                                             roup.all_switches=off; friendly_name=all switches, entity_id=('switch.catfan',),                                                              auto=True @ 18:28:52 25-01-2016>, entity_id=group.all_switches>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state s                                                             witch.livingroomlamp=on; friendly_name=LivingRoomLamp @ 18:28:52 25-01-2016>, en                                                             tity_id=switch.livingroomlamp>
                                          INFO:pywemo.subscribe:Received event from <WeMo Switch "LivingRoomLamp">(192.168                                                             .86.163)
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state g                                                             roup.all_switches=on; friendly_name=all switches, entity_id=('switch.catfan', 's                                                             witch.livingroomlamp'), auto=True @ 18:28:52 25-01-2016>, entity_id=group.all_sw                                                             itches>
                                          INFO:homeassistant.components.media_player.plex:Connected to: htts://192.168.86.                                                             4:32400
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state m                                                             edia_player.man_cave=off; friendly_name=Man Cave, supported_media_commands=1021                                                              @ 18:28:52 25-01-2016>, entity_id=media_player.man_cave>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state m                                                             edia_player.master_bedroom=off; friendly_name=Master Bedroom, supported_media_co                                                             mmands=1021 @ 18:28:52 25-01-2016>, entity_id=media_player.master_bedroom>
                                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state m                                                             edia_player.living_room=off; friendly_name=Living Room, supported_media_commands                                                             =1021 @ 18:28:53 25-01-2016>, entity_id=media_player.living_room>
                                          INFO:homeassistant.components.switch.wemo:Shutting down subscriptions.
                                          pi@home-assistant:~ $
                                          My Projects
                                          2 Door Chime Sensor
