  3. [SOLVED]Arduino nano clone, serial gateway not working
5 Posts 2 Posters 2.8k Views 2 Watching
  • finch666F
    finch666F
    finch666
    wrote on last edited by finch666
    Trying to use a nano clone instead of mij current uno to establish a serial gateway to a raspberry. The nano however, keeps giving me a radio fail.
    Checked the wiring 4 or 5 times, so that should be okay.
    Searched the interweb for problems with these clones, but nothing useful came up, besides known problems with a USB driver, wich don't seem to be relevant, given the fact that uploading a sketch gives no problems.
    Anyone else experienced such problems? Is there a solution? Or would it be much smarter to use a mini with a ftdi232?
    • TheoLT
      TheoLT
      TheoL
      Did you hook up a 4.7 uF cap? Most of the problems relate to power issues.
      • finch666F
        finch666F
        finch666
        Yep, even larger than 4.7 uF.
        Could it be the 5V pin on the nano, not giving enough current?(a 3.3V regulator is connected to this pin). I thought this pin was directly connected to the 5V coming from the usb connection (powered hub attached). But if it isn't........ will be investigating that later this day...
        This topic could be a lead; will try to get 3.3v directly from the nano.........
        • TheoLT
          TheoLT
          TheoL
          The Nano has it's own 3.3V pin. That's the one I sometimes use for powering an Antenna. But the Arduino cannot supply a lot of power. When powering an Nano from an 5V adapter, it's better to power the radio from the adapter (instead of the Arduino itself). Of course you need a regulator
          • finch666F
            finch666F
            finch666
            It appeared my radio module wasn't functioning......:angry:
            The nano gateway works perfect now.......:relieved:
            Thank you, TheoL, for your reactions!
