  3. Wiegand sending codes to domoticz
6 Posts 4 Posters 3.5k Views 5 Watching
  • finch666F
    finch666F
    finch666
    wrote on last edited by finch666
    Trying to get a Wiegand 26 reader to send the tagcode to domoticz.
    Being not a wizard in coding, I think I got something wrong. I need to send the cardCode to domoticz to use in events, but the code appears in domoticz as "lux".
    Does anyone out there knows how to correct the program (much obliged)
    #define ID 0
    MyMessage msg(ID, S_CUSTOM);
    #define MAX_BITS 100                 // max number of bits
    #define WEIGAND_WAIT_TIME  3000      // time to wait for another weigand pulse.
    unsigned char databits[MAX_BITS];    // stores all of the data bits
    unsigned char bitCount;              // number of bits currently captured
    unsigned char flagDone;              // goes low when data is currently being captured
    unsigned int weigand_counter;        // countdown until we assume there are no more bits
    unsigned long facilityCode=0;        // decoded facility code
    unsigned long cardCode=0;            // decoded card code
    // interrupt that happens when INTO goes low (0 bit)
    void ISR_INT0()
      //Serial.print("0");
      bitCount++;
      flagDone = 0;
      weigand_counter = WEIGAND_WAIT_TIME;
    // interrupt that happens when INT1 goes low (1 bit)
    void ISR_INT1()
      //Serial.print("1");
      databits[bitCount] = 1;
      bitCount++;
      flagDone = 0;
      gw.begin();
      gw.sendSketchInfo("Wiegand", "1.0");
      gw.present(ID, S_CUSTOM);
      pinMode(13, OUTPUT);  // LED
      pinMode(2, INPUT);     // DATA0 (INT0)
      pinMode(3, INPUT);     // DATA1 (INT1)
      Serial.begin(9600);
      Serial.println("RFID Readers");
      // binds the ISR functions to the falling edge of INTO and INT1
      attachInterrupt(0, ISR_INT0, FALLING);
      attachInterrupt(1, ISR_INT1, FALLING);
      // This waits to make sure that there have been no more data pulses before processing data
      if (!flagDone) {
        if (--weigand_counter == 0)
          flagDone = 1;
      // if we have bits and we the weigand counter went out
      if (bitCount > 0 && flagDone) {
        unsigned char i;
        Serial.print("Read ");
        Serial.print(bitCount);
        Serial.print(" bits. ");
        if (bitCount == 26)
                // facility code = bits 2 to 9
          for (i=1; i<9; i++)
             facilityCode <<=1;
             facilityCode |= databits[i];
          // card code = bits 10 to 23
          for (i=9; i<25; i++)
             cardCode <<=1;
             cardCode |= databits[i];
          printBits();
        else {
              Serial.println("Unable to decode.");
         // cleanup and get ready for the next card
         bitCount = 0;
         facilityCode = 0;
         cardCode = 0;
         for (i=0; i<MAX_BITS; i++)
           databits[i] = 0;
    void printBits()
          // I really hope you can figure out what this function does
          Serial.print("FC = ");
          Serial.print(facilityCode);
          Serial.print(", CC = ");
          Serial.println(cardCode);
          gw.send(msg.set(cardCode));
    mscoryM 1 Reply Last reply
    • finch666F finch666
      #define ID 0
      void ISR_INT0()
        bitCount++;
        flagDone = 0;
      void ISR_INT1()
        bitCount++;
        flagDone = 0;
        gw.begin();
        Serial.begin(9600);
        if (!flagDone) {
            flagDone = 1;
          unsigned char i;
          if (bitCount == 26)
            for (i=1; i<9; i++)
               facilityCode <<=1;
               cardCode <<=1;
            printBits();
          else {
           bitCount = 0;
           facilityCode = 0;
           cardCode = 0;
             databits[i] = 0;
      void printBits()
      mscoryM
      mscoryM
      mscory
      @finch666
      Helllo,
      I'm trying to do the same. Did you succeed ?
      Kind regards
      Michel
      • finch666F
        finch666F
        finch666
        Hi mscory,
        It's been a while, but as far as I remember I was able to see the values as text in domoticz, but was not able to use those in events.
        AWIA 1 Reply Last reply
          Hi mscory,
          AWIA
          AWIA
          AWI
          @finch666 domoticz does not support S_Custom in the way you use it. Try V_TEXT. (similar is discussed in a recent thread, I'm on a phone right now, hard to include the link.)
          • mscoryM
            mscoryM
            mscory
            I believe I understood what you mean but I didn't find the message you referred to.
            My goal is to replace my old wired alarm with Domoticz and PiFace2 keeping my wired sensor (safer). I still have to find a way to arm/disarm the system. Up to now I didn't find such a device. If I can decypher Wiegand message I'll probably be able to use an access control device used for magnetic lock.
            Thank you to both of you
            Kind regards
            Michel
              I think the post @AWI was referring to is https://forum.mysensors.org/topic/1957/lcd-clock-and-text-sensor-node-with-new-v_text/11
