  3. Freedomotic
  4. Freedomotic
Freedomotic
Scheduled Pinned Locked Moved Freedomotic
automationserialgatewaycontroller
72 Posts 15 Posters 55.5k Views 4 Watching
  • freedomoticF
    freedomoticF
    freedomotic
    Hi @asterisco
    I uploaded a new version with improved log messages. Can you remove the old plugin folder and reinstall it?
    Are you using the last dailybuild?
    Freedomotic Iot & Smart Spaces framework
    http://www.freedomotic.com
      Martin Guttesen
      I get an exception when i try to use mysensor plugin
      Windows 8.1
      INFO <AWT-EventQueue-0> [Plugin] Starting plugin MySensors
      Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: com/freed
      omotic/objects/EnvObjectPersistence
      at com.freedomotic.plugins.devices.mysensors.MySensors.loadConfiguredObj
      ects(MySensors.java:227)
      at com.freedomotic.plugins.devices.mysensors.MySensors.onStart(MySensors
      .java:65)
      at com.freedomotic.api.Protocol$1.run(Protocol.java:133)
      at org.apache.shiro.subject.support.SubjectRunnable.doRun(SubjectRunnabl
      e.java:120)
      at org.apache.shiro.subject.support.SubjectRunnable.run(SubjectRunnable.
      java:108)
      at org.apache.shiro.subject.support.DelegatingSubject.execute(Delegating
      Subject.java:391)
      at com.freedomotic.security.AuthImpl2.executePrivileged(AuthImpl2.java:1
      86)
      at com.freedomotic.security.AuthImpl2.pluginExecutePrivileged(AuthImpl2.
      java:177)
      at com.freedomotic.api.Protocol.start(Protocol.java:151)
      at com.freedomotic.jfrontend.PluginJList$1$1.actionPerformed(PluginJList
      .java:116)
      at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
      at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
      at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
      at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
      at javax.swing.AbstractButton.doClick(Unknown Source)
      at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
      at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown
      Source)
      at java.awt.Component.processMouseEvent(Unknown Source)
      at javax.swing.JComponent.processMouseEvent(Unknown Source)
      at java.awt.Component.processEvent(Unknown Source)
      at java.awt.Container.processEvent(Unknown Source)
      at java.awt.Component.dispatchEventImpl(Unknown Source)
      at java.awt.Container.dispatchEventImpl(Unknown Source)
      at java.awt.Component.dispatchEvent(Unknown Source)
      at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
      at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
      at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
      at java.awt.Window.dispatchEventImpl(Unknown Source)
      at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
      at java.awt.EventQueue.access$200(Unknown Source)
      at java.awt.EventQueue$3.run(Unknown Source)
      at java.security.AccessController.doPrivileged(Native Method)
      at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Sour
      ce)
      ce)
      at java.awt.EventQueue$4.run(Unknown Source)
      ce)
      at java.awt.EventQueue.dispatchEvent(Unknown Source)
      at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
      at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
      at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
      at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
      at java.awt.EventDispatchThread.run(Unknown Source)
      Caused by: java.lang.ClassNotFoundException: com.freedomotic.objects.EnvObjectPe
      rsistence
      at java.net.URLClassLoader$1.run(Unknown Source)
      at java.net.URLClassLoader.findClass(Unknown Source)
      at java.lang.ClassLoader.loadClass(Unknown Source)
      at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
      ... 48 more
      • freedomoticF
        freedomoticF
        freedomotic
        Thanks for your report.
        I'll take a look ASAP.
        • S
          sdndba
          Hi @freedomotic
          I've read over all the posts and would like to get an update on the status of the plugin, also would like to know where to get the latest version. If I can get this installed I can help you test in on a very large system with over 50 nodes with various sensors on a ranch. Thanks,
          • freedomoticF
            freedomoticF
            freedomotic
            Hi @sdndba
            thanks for your offer. We are working on a new version. When it is available I'll post here.
            Happy new year!!!
            • freedomoticF
              freedomoticF
              freedomotic
              Hello
              @sdndba you can try a new version (in attachment)
              Download from http://teamcity.codebetter.com/guestAuth/repository/download/bt1177/.lastSuccessful/freedomotic-5.6.0-{build.number}.zip
              Extract it, then extract the plugin into freedomotic_folder/plugins/devices.
              Let me know
              Thanks for supportmysensors.zip
              BobCB 1 Reply Last reply
              • freedomoticF freedomotic
                Hello
                Let me know
                BobCB
                BobCB
                BobC
                @freedomotic Good morning and thanks to all for the hard work you put in.
                I went to Domotic website - downloaded the zip files , all fine but when trying to load the Mysensors plugin it was unavailable!!
                I'm just starting with win 7 but will upgrade to pi when I get a bit of experience.
                Any idea whrn the plugin will be available?
                thanks
                • freedomoticF
                  freedomoticF
                  freedomotic
                  Hi @BobC
                  we are working on the plugin but we need some testers. Nobody is helping us now. Did you try the post attached zip file? If you want we can collaborate. Thanks
                  • freedomoticF
                    freedomoticF
                    freedomotic
                    We are very glad to announce that Freedomotic is on Canonical Ubuntu Snappy Official Page ("Our Partners" section). A great result for our efforts!
                    http://www.ubuntu.com/things
                    • Roberto BrunialtiR
                      Roberto BrunialtiR
                      Roberto Brunialti
                      Hi, what about the mysensor plugin? I would like to try the freedomotic frontend with raspberrypi as a (serial)gateway. Are there any tutorials about?
                      thanks
                      • freedomoticF
                        freedomoticF
                        freedomotic
                        Hi Roberto
                        thanks for your interest. The plugin is in stand-by because I don't have any hardware for tests. I asked some help on this forum with no success. If you want we can collaborate. I tried a first draft using a fake serial connection on Windows. Let me know your idea with Raspi. Bye
                        • freedomoticF
                          freedomoticF
                          freedomotic
                          Hi @Roberto-Brunialti
                          are you still interested?
                            Roberto BrunialtiR
                            Roberto Brunialti
                            Yes, I' am. Still to understand the needs in terms of sensors, gw and so on...
                            Never used before mysensor, but i've got 4 sensordend boards.
                            I should be able to setup a gw with nrf+ in a raspberry 2.
                            • V
                              V
                              virgus1970
                              Hi, Freedomotic!
                              I'm too interesting in testing hardware (sensors & rellays) with MySensor Plugin on Pi B+. Do You need one more tester?
                              • freedomoticF
                                freedomoticF
                                freedomotic
                                Of course @virgus1970 , I need all possible testers.
                                I'm updating the plugin to start testing. For now you can install Freedomotic on your raspberry and try it. The plugin works with the upcoming version 5.6 you can download from http://teamcity.codebetter.com/guestAuth/repository/download/bt1177/.lastSuccessful/freedomotic-5.6.0-{build.number}.zip
                                • V
                                  V
                                  virgus1970
                                  Ok. I'm going to start next week & will keep You up to date
                                  • freedomoticF
                                    freedomoticF
                                    freedomotic
                                    Hi, in attachment the new development version. You need to download freedomotic from the previous link (teamcity), extract the plugin zip to freedomotic_root/plugins/devices folder and then modify your serial port name in mysensors-manifest.xml.
                                    Start Freedomotic and double click on Mysensors icon.
                                    mysensors.zip
                                    barduinoB 1 Reply Last reply
                                      mysensors.zip
                                      barduinoB
                                      barduinoB
                                      barduino
                                      @freedomotic
                                      When you say you dont have hardware for testing, what do you mean?
                                      Do you have ate least 2 Arduinos?
                                      Im working on a way to simulate sensors, still alpha and not tested (im travelling) but so far it should be capable of simulating 12 sensors.
                                      Would this work for you?
                                      • freedomoticF
                                        freedomoticF
                                        freedomotic
                                        @barduino
                                        Now I have only an Arduino Uno and no radio transceiver and sensors.
                                        I made some tests sending "fake" serial protocol strings via software.
                                        • freedomoticF
                                          freedomoticF
                                          freedomotic
                                          @barduino
                                          any news about your simulator?
