  3. Multimeter recommendation?
43 Posts 21 Posters 17.9k Views 16 Watching
  • m26872M
    m26872M
    m26872
    I have to agree... I think you'll need at least one Fluke.:yellow_heart:
    • mountainmanM
      mountainmanM
      mountainman
      Temped by EEVblog BM235 Multimeter especially given it comes with some nice silicone leads.
      https://www.eevblog.com/product/bm235-multimeter/
      The flukes are very nice though!
      • TheoLT
        TheoLT
        TheoL
        I'm looking for a one that's a bit cheaper. And so a voltcraft VC 130-1. Is that a decent multi meter for a hobbyist?
        AWIA 1 Reply Last reply
        • TheoLT TheoL
          AWIA
          AWIA
          AWI
          @TheoL great meter for that money. Would not hesitate to buy
          • NeverDieN
            NeverDieN
            #25
            This post is deleted!
              marchen
              Anyone reading this post, and thinking of buying Multimeter , I recommend buying a like this one,.
              Because you cannot measure AC current using that traditional multimeter like this one.
              Accuracy of clamp is greater than the traditional one, you can also detect the flux or EMF using clamp meter. It will be very usefull in detecting live wires with current and in the projects related to coils as it can detect EMF.
              Nca78N 1 Reply Last reply
                It depends what your main usage is: the clamp meter is not very handy on a desk for example.
                • M marchen
                  Nca78N
                  Nca78N
                  @marchen how good is that to measure currents below 10uA ? :D
                  M alexsh1A 2 Replies Last reply
                  • Nca78N Nca78
                    marchen
                    @Nca78 Yes it may be a problem to measure currents in micro amperes but normal multimeter can't ever measure the current in milli amps accurately.
                    • alowhumA
                      alowhumA
                      alowhum
                      I have a completely automatic one, and I love it. It doesn't have a dial you have to turn to determine sensitivity.
                      All it basically has is an on button and two leads.
                      This gives me much more assurance that I won't fry the multimeter, so I use it a lot more.
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        OK, my best recommendation is Brymen BM869 (with logging) or there is a model without logging.
                        I have also supported a kickstarter project for a new Dave's multimeter EEVblog 121GW - https://www.kickstarter.com/projects/eevblog/eevblog-121gw-multimeter
                        There is another model EEVblog BM235 which I can highly recommend.
                        I have changed my mind about Vichy VC99 multimeter. Mine failed after a year and the build quality is just poor - you would not want to test even 240V with it. However, it has been very accurate in the beginning and extremely cheap.
                        • Nca78N Nca78
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @nca78 for such a low current the best bet would be EEVblog's uCurrent
                          https://www.adafruit.com/product/882
                          • alexsh1A alexsh1
                            Nca78N
                            Nca78N
                            @alexsh1 yes and no. I measure at 3.3V then run my low power nodes on a button cell so below 3V voltage, so I measure current a bit higher than the real one when node is on battery and I'm sure the battery life I calculate will be met. I don't need an ultra precise measurement I just need to know if I'm in the expected range or if something is wrong.
                            alexsh1A 1 Reply Last reply
                            • Nca78N Nca78
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @nca78 Sometimes I need to measure current as low as 2uA. I do not think I can do that with my multimeter. So uCurrent is a good investment from my perspective.
                              gohanG 1 Reply Last reply
                              • alexsh1A alexsh1
                                @alexsh1 https://www.openhardware.io/view/380/Micro-nano-ampere-meter-double I think it is a good alternative from a cost perspective
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @gohan I have looked at it, but never managed to complete it.
                                    same here, I made the PCB with all headers and resistors but need to prepare che enclosure
                                    • JohnRobJ
                                      JohnRobJ
                                      JohnRob
                                      I already had a Fluke 72 (old one with no current range below 10 Amps).
                                      So for better accuracy, I purchased an HP 3478a digital multimeter on eBay for about $140. It gives me all the accuracy I want (but probably don't need) and has 1 µA resolution (accuracy is somewhat less but for tweaking battery usage stability makes it usable.
                                      Of course it is not as portable as it needs mains power.
                                        #39
                                        I just realized I forgot to report back. I bought a multimeter called pm18c. The temperature sensor is very fragile - broke almost immediately. But the rest works well. I still use my old small multimeter a lot though, the pm18c is a bit bulky.
                                        Big thanks to everyone for the input!
                                        https://www.aliexpress.com/item/33043413742.html
                                          Aneng an8009 or similar is still a really good buy, 9999 counts is not something you get usually from cheap meters
