  3. Vera
  4. Vera status not updating after 1.4 upgrade
6 Posts 4 Posters 2.5k Views 1 Watching
  • J
    J
    jribera
    After moving to 1.4 my sensors appear to be working correctly however the status on the vera does not change. Ie my blind sensor is closed however the vera always displays an open icon. Same issue with my relay/lights vera always shows them as off.
    Any ideas ? I have restarted everything, re-uploaded all the vera plugins and also recreated the mysensors plugin.
    Thanks,
    Joseph
    RJ_MakeR 1 Reply Last reply
    • J jribera
      Thanks,
      Joseph
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @jribera
      So when you click on the buttons in Vera, it activates/deactivates the device,(works as expected) but the Vera UI does not reflect that change?
      RJ_Make
      J 1 Reply Last reply
      • RJ_MakeR RJ_Make
        @jribera
        J
        J
        jribera
        @ServiceXp
        This is correct. I think the only thing i haven't tried is a factory reset on the vera. This was working on 1.3
        hekH 1 Reply Last reply
        • J jribera
          @ServiceXp
          @jribera
          Factory reset wont help. Can you see if transmissions from your sensor is failing?
          Connect your relay-actuator to your computer and activate debug mode (MyConfig.h) and check the Serial Monitor in Arduino IDE.
          • J
            J
            jribera
            I think the problem was my local Arduino IDE. I deleted everything, re-downloaded the 1.4 sensor libraries and rebuilt a few sensors. The new sensors now update the status on my vera correctly.
              mitekg
              the same problem. transmission from sensor to gateway works. But i can not see any LED blinks when sensor sends a presentation.
