  3. MySensor Node for latching Relays
2 Posts 2 Posters 1.1k Views 3 Watching
  • R Offline
    R Offline
    rspecht
    Hello Guys,
    i try to do some Controldevices for Homeautomation. My purpose is an self-sufficient system which is controlable from a mysensor.
    So i use some Relays from Eltako - the ES12Z-200-UC Type.
    Here is the Datasheet: http://www.eltako.com/fileadmin/downloads/en/_datasheets/Datasheet_ES12Z-200-UC.pdf
    The big benefit is the standalone working and the simple controlability. So now i have done a MySensor Box and atached it on the control on and off connection and also a senseloop over the second switch contact to detect the State.
    I adapt the Relay Sketch and include the Sensor in my FHEM Network. Now my Problem: When i detect a one, i send it to FHEM and FHEM reply it to me and so i switch again.. how can i interlock this?
    #include <Bounce2.h>
    #define PIN_LEDRD  8
    #define PIN_LEDGN  7
    #define PIN_SWON   5
    #define PIN_SWOFF  6
    #define PIN_STATE  4
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool state;
    MyMessage msg(CHILD_ID, V_LIGHT);
      gw.sendSketchInfo("Relay & Button", "1.0");
      // Setup the button
      pinMode(PIN_STATE, INPUT);
      // Activate internal pull-up
      digitalWrite(PIN_STATE, HIGH);
      debouncer.attach(PIN_STATE);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_LIGHT);
      digitalWrite(PIN_SWON, 0);
      digitalWrite(PIN_SWOFF, 0);
      digitalWrite(PIN_LEDGN, 1);
      digitalWrite(PIN_LEDRD, 1);
      pinMode(PIN_SWOFF, OUTPUT);
      pinMode(PIN_SWON, OUTPUT);
      pinMode(PIN_LEDGN, OUTPUT);
      pinMode(PIN_LEDRD, OUTPUT);
      state = gw.loadState(CHILD_ID);
      //digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF);
       Example on how to asynchronously check for new messages from gw
      gw.process();
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue ) {
        Serial.print("Incoming change for value:");
        Serial.println(value);
        if (value == 1) {
          digitalWrite(PIN_LEDRD, 0);
        } else {
          digitalWrite(PIN_LEDGN, 0);
       // gw.send(msg.set(value), true); // Send new state and request ack back
      oldValue = value;
      if (message.isAck()) {
        // Change relay state
        state = message.getBool();
        if (state == 1) {
          digitalWrite(PIN_SWON, 1);
          //digitalWrite(PIN_LEDRD, 1);
          delay(100);
          // digitalWrite(PIN_LEDGN, 0);
        } else {
          digitalWrite(PIN_SWOFF, 1);
          delay(100);
          // digitalWrite(PIN_LEDRD, 0);
          // digitalWrite(PIN_LEDGN, 1);
        // Store state in eeprom
        gw.saveState(CHILD_ID, state);
        // Write some debug info
        Serial.print(message.sensor);
    Can you help me a little bit? :)
    • hekH Offline
      hekH Offline
      You could perhaps save the time when the GPIO input changes... and wait to do the DigitalWrite until some timeout (a second?).
      If you receive the ack from gateway, just reset the timeout and do exactly like you do today.
