  3. Can you help spot my sketch mistake? Why's it ignoring the delay?
2 Posts 2 Posters 810 Views 2 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    wrote on last edited by Mark Swift
    Hi guys,
    I'm trying to get a simple node working, it's based on the moisture example. I've basically added another sensor in, which will be a rain sensor. I'm new to Arduino, but thought this would be fairly easy... :-/
    I presume I've made a simple mistake as it seems to avoid the delay between the 2 sensor readings?
    #define MY_NODE_ID 4
    // #define MY_PARENT_NODE_ID 2
    // Enable debug prints
    // #define MY_RADIO_RFM69
    #define MY_RF24_CHANNEL 125
    #define MOISTURE_POWER_PIN 4
    #define DIGITAL_INPUT_MOISTURE 5   // Digital input did you attach your soil sensor.
    #define RAIN_POWER_PIN 6
    #define DIGITAL_INPUT_RAIN 7   // Digital input did you attach your soil sensor.
    unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds) 30000
    #define CHILD_ID0 0  // ID of the sensor child
    #define CHILD_ID1 1  // ID of the sensor child
    MyMessage msg1(CHILD_ID0, V_TRIPPED);
    MyMessage msg2(CHILD_ID1, V_TRIPPED);
    int lastMoistureValue = -1;
    int lastRainValue = -1;
      sendSketchInfo("Rn+M+T+H", "1.0");
      // Set the soil sensor digital pin as input
      pinMode(DIGITAL_INPUT_MOISTURE, INPUT);
      // Set the rain sensor digital pin as input
      pinMode(DIGITAL_INPUT_RAIN, INPUT);
      // Set the soil sensor power pin as output
      pinMode(MOISTURE_POWER_PIN, OUTPUT);
      // Set the rain sensor power pin as output
      pinMode(RAIN_POWER_PIN, OUTPUT);
      // Set to LOW so no power is flowing through the moisture sensor
      digitalWrite(MOISTURE_POWER_PIN, LOW);
      // Set to LOW so no power is flowing through the rain sensor
      digitalWrite(RAIN_POWER_PIN, LOW);
      present(CHILD_ID0, S_MOTION);
      present(CHILD_ID1, S_MOTION);
      // Turn moisture power pin on
      digitalWrite(MOISTURE_POWER_PIN, HIGH);
      // Set a delay to ensure the moisture sensor has taken a good reading
      delay(200);
      // Read digital soil value
      int moistureValue = digitalRead(DIGITAL_INPUT_MOISTURE); // 1 = Not triggered, 0 = In soil with water
      // Turn moisture power pin off
      if (moistureValue != lastMoistureValue)
        #ifdef MY_DEBUG
        Serial.println("Moisture Sensor");
        Serial.println(moistureValue);
        send(msg1.set(moistureValue == 0 ? 1 : 0)); // Send the inverse to gw as tripped should be when no water in soil
        lastMoistureValue = moistureValue;
      // Wait between sensor readings, seems to help reliability of second reading
      delay(5000);
      // Turn rain power pin on
      digitalWrite(RAIN_POWER_PIN, HIGH);
      delay(200);
      // Read digital rain value
      int rainValue = digitalRead(DIGITAL_INPUT_RAIN); // 1 = Not triggered, 0 = In soil with water
      // Turn rain power pin off
      if (rainValue != lastRainValue)
        #ifdef MY_DEBUG
        Serial.println("Rain Sensor");
        Serial.println(rainValue);
        send(msg2.set(rainValue == 0 ? 1 : 0)); // Send the inverse to gw as tripped should be when no water in soil
        lastRainValue = rainValue;
      // Sleep or wait depending on node role
      // sleep(SLEEP_TIME); // Sleep or wait (repeater)
    • Boots33B
      Boots33B
      Boots33
      wrote on last edited by Boots33
      That code looks ok to me. You should get a 5 second delay with that.
      Perhaps add
         Serial.println("start delay");
        delay(5000);
         Serial.println("finish delay");
      and see if you get your delay in the serial monitor```
      Insert Code Here
