  3. Debugging radio coverage...
6 Posts 4 Posters 2.5k Views 4 Watching
  • epierreE
    epierreE
    epierre
    I have a room where z-wave used to work... but not anymore, that is also blind to nrf24l01+ .
    Has anyone some idea how to test reception / signal strength so I can find a way out (so bad it is in the same room as my gas and electricity meter...)
    z-wave - Vera -> Domoticz
      The NRF doesn't provide any RSSI value unfortunately.
      Crazy idea: Maybe you can tune in your wifi network on the same channel as the NRF and place wifi-router at the location of your MySensors gateway. While checking with a laptop or something in the utility room.
      • epierreE
        epierreE
        epierre
        this is what somehow I thought of, is there a possibility to have a mysensors over HTTP ?
        maybe something like this in the next room... or have a pi receiving the data ?
        http://www.tp-link.fr/products/details/TL-WR702N.html
        no idea how to handle that for the Z-wave...
          How about using an ethernet gateway in that room, could that be a solution?
          • epierreE
            epierreE
            epierre
            @mfalkvidd sadly 1960's houses have no floor to cave wiring spaces ;('
            • NeverDieN
              NeverDieN
              Since z-wave is a different frequency band (not sure where you are, but 908.4Mhz in the US), you may have a wideband interference source. The easiest way to troubleshoot and possibly find the source would be with an inexpensive RTL-SDR.
