  3. Sensors stop working after some time
12 Posts 2 Posters 5.6k Views 2 Watching
  • chatainsimC
    chatainsimC
    chatainsim
    I have an issue with my sensors.
    After some time they are stop working.
    The only way I've found is to clear the eeprom then upload my sketch again.
    I'm using Arduino nano with 4.7uF capacitor.
    The gateway use a NRF24L01+PA+LNA Antenna version with capacitor too.
    I've already change all my NRF24 on all node but same thing happen.
    I even change all Arduino nano.
    For the Humidity sensors, sometimes gateway only get temperature or humdity then both are getting again.
    Some sensors closer to the gateway stop working first so I think this is not a distance issue.
    The farthest sensors is at less than 20 meters from the gateway.
    Can you help me with this ?
    Thank you.
    Regards,
    • chatainsimC
      chatainsimC
      chatainsim
      Has you can see, only humidity is reported:
      2016-04-24 00:17:38.627 (MySensors) Humidity (Hum)
      2016-04-24 00:17:47.120 (MySensors) Humidity (Hum)
      2016-04-24 00:17:50.172 (MySensors) Humidity (Hum)
      2016-04-24 00:18:03.057 (MySensors) Humidity (Hum)
      2016-04-24 00:18:11.975 (MySensors) Humidity (Hum)
      2016-04-24 00:18:21.601 (MySensors) Humidity (Hum)
      2016-04-24 00:18:38.708 (MySensors) Humidity (Hum)
      2016-04-24 00:18:45.324 (MySensors) Humidity (Hum)
      2016-04-24 00:18:45.491 (MySensors) Humidity (Hum)
      2016-04-24 00:18:53.029 (MySensors) Humidity (Hum)
      2016-04-24 00:19:14.361 (MySensors) Humidity (Hum)
      2016-04-24 00:19:20.774 (MySensors) Humidity (Hum)
      But they are hum+temp sensors with a DHT22.
      Then it's start working again ... almost:
      2016-04-24 00:21:01.322 (MySensors) Temp + Humidity (Salle de bain)
      2016-04-24 00:21:04.879 (MySensors) Temp + Humidity (Salon)
      2016-04-24 00:21:06.602 (MySensors) Humidity (Hum)
      • TheoLT
        TheoLT
        TheoL
        @chatainsim I have experienced similar problems. Most of them we're solved with adding the capacitor as close to the radio as possible. In some other cases I was able to solve this by rewiring things and power them from the adapter and not the Arduino. Make sure you unplug the power adapter before you do that. I've broken some sensors by not doing it.
        Another interesting thing I found out. I had the power adapter of one node in an outlet that I use to test devices. If for some reason I remove and added a lot of other devices to that same outlet. My Node would stop sending particular sensor values to Domoticz. And after a couple of days it would spontaneously start sending the values again. When I moved the adapter of that node to another outlet, the node became stable.
        But I still see some strange things in Domoticz. But I think it's a Domoticz issue. Because the node id is the same. Domoticz is just not able to see this I guess.
        chatainsimC 1 Reply Last reply
        • TheoLT TheoL
          chatainsimC
          chatainsimC
          chatainsim
          Thanks @TheoL I will look into it.
          Regarding the capacitor, I've mounted them like @petewill did in his videos.
          And for the outlet I use one per rooms for the temp/humidity sensors.
          Same for the power adapter, they are all different, for old iPhone charger or chromecast power adapter but this strange behavior still appear.
          I'll keep you posted !
          Thank you.
          • chatainsimC
            chatainsimC
            chatainsim
            @TheoL So I've tried with different adapter but it's still the same issue.
            It's working fine for 1 or 2 week than sensors stop working.
            I have to clear eeprom then upload the sketch again.
            I will try with mysensors 2.0 to see if something change.
            Do you know if it's possible to maybe only clean eeprom without having to plug arduino to a computer ? Maybe only with the button on the arduino nano ?
            TheoLT 1 Reply Last reply
            • chatainsimC chatainsim
              TheoLT
              TheoLT
              TheoL
              @chatainsim Hello dear friend,
              I have thought about you idea that the EPROM might be the problem. But I don't think it can be. But please post your sketch, so that I can have I peek at it.
              I'd also like to know which type of sensor your are using? Are you using a DHT? Or another one. I have had simular result with some DHT sensors. Make sure you pull up the data line with a 4k7 Ohm resistor (if I remeber correctly). You can do this by adding a 4k7 between the VCC pin and the data pin of the DHT. Out of my head they're pin 1 and 2. But just google for DHT and if yo click on the images you'll probably see an example of the pull-up.
              It might not solve your problem, though. I've switched to an si7021. Which for me is easy to use, because most of my sensors are attached to a pro mini 3.3v
              • TheoLT TheoL
                chatainsimC
                chatainsimC
                chatainsim
                Hello @TheoL
                I'm using DHT-11, DHT-22, BH1750, HC-SR501, Relay and SCT-013-030.
                For all sensors except SCT-013-030, I'm using MySensors sketch.
                And for the SCT-013-030 here is the sketch:
                // EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3  ***/
                #include "EmonLib.h"             // Include Emon Library
                EnergyMonitor emon1;             // Create an instance
                #define CHILD_ID 99
                #define PIN_ANALOG_I A2
                unsigned long lastSend;
                unsigned long lastSend2;
                unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                unsigned long SEND_FREQUENCY2 = SEND_FREQUENCY / 25;
                int index = 0;
                double Irms=0;
                double power;
                boolean pcReceived = false;
                boolean onyva=true;
                boolean debug=false;
                float nrj=0, old_nrj;
                MyMessage IrmsMsg(CHILD_ID,V_WATT);
                MyMessage kWhMsg(CHILD_ID,V_KWH);
                  if (message.type==V_VAR1)
                    nrj = old_nrj = message.getFloat();
                    Serial.print("Received last nrj count from gw:");
                    Serial.println(nrj);
                    pcReceived = true;
                  gw.begin(incomingMessage);
                  gw.sendSketchInfo("Energy Meter", "1.0");  // Send the sketch version information to the gateway and Controller
                  gw.present(CHILD_ID, S_POWER);   // Register this device as power sensor
                  gw.request(CHILD_ID, V_VAR1);
                  emon1.current(PIN_ANALOG_I, 30.0);       // Current: input pin, calibration.
                  if (debug) Serial.println("Starting...");
                  if (onyva) gw.process();
                  onyva = false;
                  unsigned long now = millis();
                  //unsigned long now2 = millis();
                  bool sendTime2 = now - lastSend2 > SEND_FREQUENCY2;
                  if (sendTime2) //calcul Irms moy
                    if (index==0) Irms=emon1.calcIrms(1480);
                    else {
                    index++;
                    Irms = (index*Irms+emon1.calcIrms(1480))/(index+1);
                    lastSend2 = now;
                  bool sendTime = now - lastSend > SEND_FREQUENCY;
                  if (debug) Serial.print("DEBUG: ");
                  if (debug) Serial.println(Irms*232.0);
                  if (sendTime && pcReceived)
                    power = Irms*232.0;
                    if (debug) Serial.println("Sending data ...");
                    gw.send(IrmsMsg.set(power,1));
                    nrj += (power*SEND_FREQUENCY/1000)/3.6E6;
                    gw.send(kWhMsg.set(nrj,5));
                    gw.send(pcMsg.set(nrj,5));
                    lastSend = now;
                    index = 0;
                    old_nrj=nrj;
                    onyva=true;
                 else if (sendTime && !pcReceived)
                  if (debug) Serial.println("DEBUG AGAIN ...");
                  lastSend=now;
                  index=0;
                  onyva=true;
                The Relay never fail and I've setup the BH1750 only one week ago without issue for now.
                For the Relay, I'm using an Arduino Uno and Arduino nano for all other sensors.
                The gateway (serial) is an Arduino Nano with NRF24L01+PA+LNA Antenna version.
                With Domoticz 3.5502 under Linux.
                Thank you !
                  Hello @TheoL
                  #define CHILD_ID 99
                  int index = 0;
                  double Irms=0;
                  double power;
                  boolean onyva=true;
                      pcReceived = true;
                    onyva = false;
                      else {
                      index++;
                      lastSend2 = now;
                      power = Irms*232.0;
                      lastSend = now;
                      index = 0;
                      old_nrj=nrj;
                      onyva=true;
                    lastSend=now;
                    index=0;
                    onyva=true;
                  Thank you !
                  TheoLT
                  TheoLT
                  TheoL
                  wrote on last edited by TheoL
                  @chatainsim It's getting late over here. But there's one thing that's missing in your sketch.
                  You are using MySensors 1.5.x. that mains that you have to use a gw.wait or gw.process in your main loop. Otherwise you won't be able to receive any messages from the gateway. But I doubt if that will solve your problem.
                  What it possible that you post the sketch of your Humidity Temp node? It's easier for me to see if there might be something wrong with that Sketch.
                  However I think that it's possible that the root of your problem might be in the gateway. How is the antenna of you gateway powered?
                  • TheoLT TheoL
                    chatainsimC
                    chatainsimC
                    chatainsim
                    Thank you @TheoL
                    Here is the Humidity Temp node sketch:
                     * Version 1.0 - Henrik EKblad
                     * This sketch provides an example how to implement a humidity/temperature
                     * sensor using DHT11/DHT-22
                    #include <DHT.h>
                    //Sensor  ID1 ID2
                    //Temp Salon  T: 10 H: 11
                    //Temp Balcon T: 12 H: 13
                    //Temp SDB  T: 14 H: 15
                    //Temp Bebe T: 16 H:17
                    //Temp Chambre  T:18  H:19
                    #define CHILD_ID_HUM 15
                    #define CHILD_ID_TEMP 14
                    DHT dht;
                    float lastTemp;
                    float lastHum;
                    boolean metric = true;
                      gw.begin();
                      gw.sendSketchInfo("Humidity", "1.0");
                      if (isnan(temperature)) {
                        lastTemp = temperature;
                        if (!metric) {
                        Serial.print("T: ");
                        Serial.println(temperature);
                      if (isnan(humidity)) {
                          lastHum = humidity;
                          Serial.print("H: ");
                          Serial.println(humidity);
                      gw.sleep(SLEEP_TIME); //sleep a bit
                    The antenna is powered by the Arduino Nano itself.
                    But if the problem is the gateway, so there should be an issue with all sensors at the same time ?
                      Thank you @TheoL
                      #include <DHT.h>
                      //Sensor  ID1 ID2
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                        gw.begin();
                          if (!metric) {
                            lastHum = humidity;
                      TheoLT
                      TheoLT
                      TheoL
                      @chatainsim I try to look at the sketch tomorrow. However I don't think that the problem will occur on all sensors at the same time. Because because the change that they all communicate to the gateway at the same time is very low.
                      When I started with MySensors I had a simular problem. One of my Dupont cables was of poor quality. When I changed that one my problems we're solved. I also use a lower baudrate than the default baudrate (I believe mine is 2mbs but I have to look it up).
                      The reason why I use a lower baudrate, is because I have a mix of NRF24L01+ and NRF24L01 versions. But the baudrate should be the same on the gateways and all of the nodes.
                      What you also could try is to replace the radio with a normal NRF24L01+ radio instead of the NRF24l01+ pa + lna. The normal radio consumes less power. If this solves your problem than it'll narrow down the root cause of the problem.
                      • TheoLT TheoL
                        chatainsimC
                        chatainsimC
                        chatainsim
                        @TheoL I'll try with other Dupont cables.
                        My gateway was at first working with a normal NRF24L01+ radio and there was the same issue so I decided to switch to the + pa +lna instead.
                          TheoLT
                          TheoLT
                          TheoL
                          @chatainsim I couldn't see strange things in your sketch. What I always do when I build a multi sensor node is put a small wait after each message I send to the gateway. I've noticed that the radio cannot always keep up with the speed of the Arduino. So something like gw.wait(15); after each gw.send does the trick for me.
                          These are the though ones to pin point. Because it's 80% for sure a power related issue.
                          If you happen to have a buck converter, you could try to set that to 3.3V. Power it from an adapter and feed the Gateway antenna from the buck converter. Don't forget to connect the grounds of the radio and the Arduino.
                          But it's really hard to help you from a distance. Maybe someone else has some ideas.
