  3. ESP8266 MySensors Gateway stop working after sometime !!!
9 Posts 3 Posters 3.2k Views 3 Watching
  • R
    R
    Reza
    wrote on last edited by Reza
    I built a wifi gateway with ESP8266 and connected to my vera edge . then added mysensors and all of devices is correct and working true . but sometime the gateway is failure (without reason!) and I should be to reboot my vera...
    after reboot will work again.
    but I dont know why my gateway failure sometime !
    failure means that my relays and my sensors are on , but there is not any connect to my vera and no report from sensors and no reactions for relays....
    I use a static IP for my vera and a static IP for my gateway , also I use a 1A power supply for my gateway.
    • R
      R
      Reza
      Who has my same problem? with ethernet gateway or wifi gateway ?!
      TheoLT 1 Reply Last reply
      • R Reza
        TheoLT
        TheoLT
        TheoL
        @Reza Hi my friend.
        I had the same problem. For me adding the capacitor closer to the radio solved it.
        R 1 Reply Last reply
        • TheoLT TheoL
          @Reza Hi my friend.
          R
          R
          Reza
          hi my dear theol
          I used a 4.7µF capacitor for radio from the beginning but there is this problem...
          • R
            R
            Reza
            also I used a NRF24L01+PA+LNA for gateway and used NRF24L01+ for other devices.
            for all I used 4.7µF capacitor
            • R
              R
              Reza
              oh
              in site said use a 47µF capacitor ! but I wrong and use 4.7µF . is that my problem ? if I use 47µF will be solve my problem ?
              • R Reza
                oh
                TheoLT
                TheoLT
                TheoL
                @Reza I use 4.4 uF works like a charm. Do you power the radio with the large antenna from the Arduino??? Might be worth powering it not directly from the Arduino
                • TheoLT TheoL
                  R
                  R
                  Reza
                  @TheoL
                  I use a NRF24L01+PA+LNA without anntena. and i use a 5V 1A power for nodemcu and radio is connect to nodemcu module.
                  But i think problem is related to wifi communication .
                  look at pics ! NRF networks dont have problem , problem related to wifi network !
                  is my setting correct ?
                  :( pics can not upload now !
                  so in vera dashborad and devices my gateway is "Can't Detect Device(red)"
                  so i think related to wifi network . do i change gateway setting?
                  • AffordableTechA
                    AffordableTechA
                    AffordableTech
                    One solution - refer to: [https://forum.mysensors.org/topic/3894/esp8266-unexpected-crash-or-reset](link url)
