  3. Newbie questions
Newbie questions
2 Posts 1 Posters 1.0k Views 2 Watching
  • signal15S
    signal15S
    signal15
    I'm new to this and I'm really not getting anywhere. I have numerous problems, the most significant of which is sensors not showing up in inclusion mode. So, I want to take a step back and ask the questions I should have probably asked before I even got started. First, here's my setup:
    • Latest Arduino IDE, with libraries from GitHub Master branch of Mysensors (appears to be version 1.5)
    • ESP8266 board from amazon for the gateway with the higher output NRF with antenna, also tried with a regular NRF
    • 47uf caps added to all radios, adding shielding on the high power one later tonight.
    • Nano's for the sensors
    • Vera on UI5
    So, here are my questions:
    1. Am I using the version of the libraries I should be? Or, is something in the dev branch considered more stable or reliable?
    2. If I'm NOT using the correct version of the libraries, does that mean I will have to also update the version running on Vera?
    3. I see a lot of issues with the ESP8266 in the forums. Should I be building a W5100 ethernet gateway instead?
    4. I tried clearing the EEPROM in my ESP8266 using the clear EEPROM example code included with MySensors. I'm not sure if it worked, as I get nothing on the serial interface like I do when clearing a Nano. Should I be using a different sketch to clear the ESP?
    5. I see that someone has built a raspberry pi serial gateway. How easy would it be to make it into an ethernet gateway? Would that be a more reliable option?
    6. For the RF24 scanner code, it says to "// Set up nRF24L01 radio on SPI bus plus pins 9 & 10". What does this mean? There are 7 pins that are normally connected, do I only hook up a subset of these? https://maniacbug.github.io/RF24/scanner_8pde-example.html
    I know the high power radio needs an external power supply to work reliably. I get intermittent "radio init fail" if I try to power it from the ESP8266 3v3 pin, but I don't get these failures when I power it externally.
    Initially, I'm trying to do 2 things. I'm trying to do smart control of an attic fan, and monitor the depth in a septic tank which has the predisposition to overflow.
    If anyone has any info that will help me get going, I would be eternally grateful. I'm at the point now where I'm just spinning my wheels and not making any progress.
    signal15S 1 Reply Last reply
    • signal15S signal15
      • Vera on UI5
      signal15S
      signal15S
      signal15
      wrote on last edited by signal15
      Well, it's working now. I put a new power supply on it, and shielded the radio. Before I go dotting my house with sensors, is there anything I should do in MyConfig.h or anywhere else? It looks like debugging is turned on by default. Should I leave it?
      Also, even though I got it working, any insight to the above questions would certainly still be appreciated.
