  3. Established Sensors Losing Connection When Remove/Adding New (1.4b)
4 Posts 3 Posters 2.1k Views 1 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    So here lately I've had to remove and re-add sensors to Vera/Gateway many times because of my 'Lockup' Problem.
    After performing a removal/re-add to Vera/Gateway I lose communication on an existing and established sensor node. This last time I lost communication with my attic Temp/Humid sensor based on the DHT22 (which has been running perfectly for at least 1 month)
    A Power Cycle or Reset would not restart communication, when I plugged the programmer in, this is the serial msg I get.
    As soon as the item in red pops up (new parent-0, d=1), the sensor starts works perfectly.
    Question:
    Shouldn't this happen without having to connect the programmer in?
    RJ_Make
    YveauxY 1 Reply Last reply
      wrote on last edited by hek
      It looks like you turned off or move the repeater-node "1" which sensor "2" was communication through.
      After a few missed messages it asked for a new parent and found the gateway node.
      And yes it should happen without the "programmer".
      • RJ_MakeR RJ_Make
        Question:
        YveauxY
        YveauxY
        @ServiceXp there is a known issue with finding a new parent in 1.4 which could cause it to take a long time to find a new parent. This is solved in development branch.
        • RJ_MakeR
          RJ_MakeR
          RJ_Make
          Thanks Guys
          RJ_Make
