  3. How to generate schematic from a mysensor BRD file?
3 Posts 2 Posters 1.7k Views 1 Watching
  • N Offline
    N Offline
    I'm interested in this PCB from OSH Park, which looks like it would make a great mysensors node:
    https://oshpark.com/shared_projects/EO8F3MPe
    Unfortunately, it's just a board file, with no schematic or other documentation, and there's not even much silk screening on the board itself. Aside from that, it looks very nice!
    I'm a day 0 newbie on learning Eagle, but already it's clear that Eagle seems to go from schematic to board layout, not the other way. Nonetheless, is there some way to generate a schematic from the BRD file?
    • S Offline
      @NeverDie I'm not sure but I think you can't. but maybe I'm wrong and there is something, but I think there may be some missing info.
      btw I guess this is the cute board from @Gertsanders you're searching for
      https://www.openhardware.io/view/76/Stamp-size-MySensor-node#tabs-instructions
      • N Offline
        N Offline
        Thanks! I definitely like V1's compact size (0.8in x 0.9in). Are there any mysensor nodes smaller than that, or is it currently the smallest? The Sensebender is also fairly compact (0.69in x 1.18in), although its effective thickness is much greater because of the way a traditional non-SMT NRF24L01+ gets stacked on it using a header.
