  3. UV Sensor ML8511
UV Sensor ML8511
13 Posts 5 Posters 8.4k Views 4 Watching
  • mrc-coreM
    mrc-coreM
    mrc-core
    Well i have been searching for the code to work with my UV Sensor ML8511 over domoticz using mysensors off corse but i had no luck.
    Tried to use the code over the build section for the UV Sensor but it does not work correctly whit the sensor i have.
    Sow i have tried to make a working code, But i'm not a good programmer...
    At he time i'm posting this i don't now if it's working correctly because it's night at my place...
    #define UV_SENSOR_ANALOG_PIN 0
    #define CHILD_ID_UV 0
    unsigned long SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
    MyMessage uvMsg(CHILD_ID_UV, V_UV);
    float lastUV = -1;
    unsigned long lastSend =0;
      gw.begin(NULL, 9, true);
      gw.sendSketchInfo("UV Sensor", "3.0");
      gw.present(CHILD_ID_UV, S_UV, "ML8511_UV");
      gw.process();
      int uvLevel = averageAnalogRead(UV_SENSOR_ANALOG_PIN);
      unsigned long currentTime = millis();
      float outputVoltage = 5.0 * uvLevel/1024;
      float uvIntensity = mapfloat(outputVoltage, 0.99, 2.9, 0.0, 15.0);
      if ((uvIntensity != lastUV)||(currentTime-lastSend >= 5*60*1000))
          lastSend=currentTime;
          gw.send(uvMsg.set(uvIntensity,2));
          lastUV = uvIntensity;
      //delay(100);
    //Takes an average of readings on a given pin
    //Returns the average
    int averageAnalogRead(int pinToRead)
      byte numberOfReadings = 8;
      unsigned int runningValue = 0;
      for(int x = 0 ; x < numberOfReadings ; x++)
        runningValue += analogRead(pinToRead);
      runningValue /= numberOfReadings;
      return(runningValue);
    //The Arduino Map function but for floats
    //From: http://forum.arduino.cc/index.php?topic=3922.0
    float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
      return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
    Has you can seen i had adapted the code from the build area and other code i had found on the web.
    Well if any one see erros in the code that i do believe it has, i do appreciate the help on fixing it and making this a perfect working code.
    • epierreE
      epierreE
      epierre
      @mrc-core said:
      ML8511
      Have you checked the wiring (from https://github.com/sparkfun/ML8511_Breakout/blob/master/firmware/MP8511_Read_Example/MP8511_Read_Example.ino):
      Connect the following MP8511 breakout board to Arduino:
      3.3V = 3.3V
      OUT = A0
      GND = GND
      EN = 3.3V
      3.3V = A1
      z-wave - Vera -> Domoticz
      • mrc-coreM
        mrc-coreM
        mrc-core
        Looking over the pin connection that you have post i do see one mistake i have done.
        I did not connect de 3.3V to A1 pin.
        I'm gona trie it when i'm at home.
        The sensor is connected to domoticz but the readings are very low... 0.2 UVI
        • mrc-coreM
          mrc-coreM
          mrc-core
          I have done some changings to the code and corrected de 3.3V = A1 Pin that i did not had in the first code.
          Onde day has passed with the changes and the result off this days is what you can see on the image below:
          I dont now if this results are correct. I'm going to let the sensor outiside until the end of the week and see the results.
          Does anyone in the forum have a UV sensor working? Is this chart correct ??
          AWIA 1 Reply Last reply
          • mrc-coreM mrc-core
            AWIA
            AWIA
            AWI
            @mrc-core looks like you are using Domoticz.. Look for the Weather Underground virtual hardware.
            You can have WU report most of the weather related data from a station nearby. This includes UV measurement in a similar graph you have.
            Or my opinion : It looks like a correct graph to me but will depend on your local sun intensity.
            • epierreE
              epierreE
              epierre
              a quick question as I try to revive a node with UV sensor (a UVM-30A) : is there a simple way to simulate the UV after sundown which is the time I can test it ?
              • epierreE epierre
                AWIA
                AWIA
                AWI
                @epierre UV led? :bowtie:
                • mrc-coreM
                  mrc-coreM
                  mrc-core
                  Ok i have now configured the Weather Underground virtual hardware let's see what will happen during the day off tomorrow.
                  For what i can seen the UV sensor is detecting the UV normally between 11h and 17h....
                  I'm going to make one new change on the code to introduce the reading s of the MP8511 voltage.
                  And i'm going to change the location off the prototype in my house.
                  To test the UV sensor at night you can use a UV light.
                  • epierreE
                    epierreE
                    epierre
                    does a halogen lamp does this ?
                    • epierreE epierre
                      AWIA
                      AWIA
                      AWI
                      @epierre The spectrum of UV is between 10 en 400 nanometer. so in relation to the spectrum of UV:
                      0_1463141831569_upload-7c6d41cc-0a2d-4066-8102-63f44f3af6ea
                      and an excerpt from medical study:
                      "Halogen lamps emit significant levels of ultraviolet radiation and should be doped or covered with glass prior to use"
                      0_1463141787908_upload-de6f625b-62b8-4a8e-b3c7-fe996aa277a7
                      But in summary: not much
                      • mrc-coreM
                        mrc-coreM
                        mrc-core
                        This is my new code for this sensor and reajusted to library 2.1.1
                         * Version 1.0 - epierre
                         * Contribution: bulldoglowell, gizmocuz
                         * Connect sensor ML8511 / Arduino:
                         *  3.3V = 3.3V
                         *  OUT = A0
                         *  GND = GND
                         *  EN = 3.3V
                         *  Arduino 3.3V = Arduino A1
                         * License: Attribution-NonCommercial-ShareAlike 3.0 Unported (CC BY-NC-SA 3.0)
                        // Enable debug prints
                        //#define MY_RS485
                        //Hardware pin definitions
                        int REF_3V3 = A1;
                        int UVOUT = A0;
                        float lastUV = -1;
                          //gw.begin(NULL, 9, true);
                          pinMode(UVOUT, INPUT);
                          pinMode(REF_3V3, INPUT);
                          int uvLevel = averageAnalogRead(UVOUT);
                          int refLevel = averageAnalogRead(REF_3V3);
                          //Use the 3.3V power pin as a reference to get a very accurate output value from sensor
                          float outputVoltage = 3.3 / refLevel * uvLevel;
                          //float outputVoltage = 5.0 * uvLevel/1024;
                          float uvIntensity = mapfloat(outputVoltage, 0.99, 2.8, 0.0, 15.0);          //Convert the voltage to a UV intensity level
                          Serial.print("output: ");
                          Serial.print(refLevel);
                          Serial.print("ML8511 output: ");
                          Serial.print(uvLevel);
                          Serial.print(" / ML8511 voltage: ");
                          Serial.print(outputVoltage);
                          Serial.print(" / UV Intensity (mW/cm^2): ");
                          Serial.print(uvIntensity);
                          Serial.println();
                          delay(100);
                        BeniKB 1 Reply Last reply
                           *  3.3V = 3.3V
                           *  OUT = A0
                           *  GND = GND
                           *  EN = 3.3V
                          //#define MY_RS485
                          int REF_3V3 = A1;
                          int UVOUT = A0;
                          float lastUV = -1;
                            Serial.println();
                            delay(100);
                          BeniKB
                          BeniKB
                          BeniK
                          @mrc-core Thanks for the code. The code works fine but I am seing the node reporting direct measurements to the gateway every single second, spamming the gateway.
                          Is there anything I can do to stop this behavior and transmit averages; in example - every minute or every 5 minutes?
                          Thanks in advance!
                          alexsh1A 1 Reply Last reply
                          • BeniKB BeniK
                            Thanks in advance!
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @benik change
                             delay(100);
                            to
                            delay(300000); //5 mins reporting
