  3. gw.sleep on battery powered magnet door switch
42 Posts 13 Posters 17.3k Views 16 Watching
  • AWIA AWI
    @siod If you are using a "standard" Atmega328 (pro-mini, etc.) don't make it hard for yourself. This processor has two external interrupts (0 & 1) connected to pins 2 & 3. Taking your line of code gw.sleep(BUTTON_PIN_Deur - 2, CHANGE, BUTTON_PIN_Post - 2, CHANGE, 86400000); the arguments are respectively:
    1. Use interrupt "0" (connected to pin 2 is BUTTON_PIN_Deur)
    2. Have is fired on change (i.e Rising and Falling)
    3. Use interrupt "1" (connected to pin 3 is BUTTON_PIN_Post)
    4. Have is fired on change (i.e Rising and Falling)
    5. Wake after every 86400000 ms (24 hrs) if no interrupt fired. To be safe you should use 86400000UL (the UL indicating that it is an Unsigned long type)
    siodS
    siodS
    siod
    @AWI
    Ok thx for explanation, but that means he is using 2 reed switches, right (interrupt at pin2 and int pin3)?
    still learning...
    AWIA 1 Reply Last reply
    • siodS siod
      @AWI
      AWIA
      AWIA
      AWI
      @siod I guess so. But don't ask me why. One should be sufficient to detect if the door is open :smile:
      In addition (and for what it is worth). If you use a real low power circuit you can save around a factor 3 on battery lifetime when you get rid of the timed wakeup. The arduino sleeps a lot better when it doesn't have to look at the alarm clock every few ms :zzz:
      siodS ChakkieC 2 Replies Last reply
      • AWIA AWI
        siodS
        siodS
        siod
        @AWI
        yes, makes sense, but how should you do this wihout the wakeup ? I guess this is just the disadvantage one must accept...
        still learning...
        • siodS siod
          @AWI
          AWIA
          AWIA
          AWI
          @siod The wakeup function can be disabled by setting the timer values to 0 (or omitting it). There is no purpose in the sketch above for what I can see. If you want to have a kind of "hey I am still alive"/heartbeat feature you need to do a little more (e.g. sending battery level)
          172pilot1 1 Reply Last reply
          • AWIA AWI
            172pilot1
            172pilot1
            172pilot
            @AWI I was going to ask about that.. I dont see any reason to wake up every 24 hours just to go back to sleep again.. I assume the radio doesn't have any reason to send a keepalive or anything? So, you can omit that number, and it will sleep until interrupted? That's cool..
            -Steve
            • 172pilot1 172pilot
              -Steve
              AWIA
              AWIA
              AWI
              @172pilot yes, no reason to wake up. Especially if there is a regular wake-up from interrupt to let the controller know it it is alive
              • AWIA AWI
                ChakkieC
                ChakkieC
                Chakkie
                wrote on last edited by Chakkie
                #27
                @AWI
                Thanks for the info. I thought you always have to add the sleep time to the gw.sleep. I will disable the a wake timer by removing the 86400000.
                @siod I use one switch for the letterbox and one for the door.
                Raspberry Pi 2
                Domoticz
                RFXCOM
                ZWAVE Aeon stick
                Coming soon Arduino mysensors GW
                • siodS
                  siodS
                  siod
                  well, as you can see, if you don´t know the libraries exactly you accept things as they are or as they seem to be. I wasn´t aware that you can just set the wakeup function to 0. So this said I would like to thank you @AWI for your patience and your willingness of explaining also the most obvious things! :thumbsup:
                  still learning...
                  • T
                    treb0r
                    The sketch works with both reeds switches (2 windows) but how to integreate it with DS18B20 temp sensor? I also power it with battery, so I would like to check the temp eg every 5min and if it is changed then send the new value to the controler. How to wake up arduino only if any window is opened or temp is changed (after 5 min)
                    treb0r
                    dynamiteD 172pilot1 2 Replies Last reply
                    • T treb0r
                      treb0r
                      dynamiteD
                      dynamiteD
                      dynamite
                      @treb0r You can either wake up on the interrupt or on a time period:
                      bool sleep(int interrupt, int mode, unsigned long ms=0);
                      interrupt - Interrupt that should trigger the wakeup.
                      mode - RISING, FALLING, CHANGE
                      ms - Number of milliseconds to sleep (or 0 to sleep forever).
                      The sleep method returns true if wake up was triggered by pin change and false means timer woke it up.
                      • T treb0r
                        treb0r
                        172pilot1
                        172pilot1
                        172pilot
                        @treb0r the problem is, you need to wake up the arduino to tell the temp sensor to take a new reading, so the best you can do is to trigger on the interrupts for the Windows and then use the timer to wake up and take the temperature reading, and then you'll have to compare to your saved value to decide whether it has been 5 degrees or not, so you can't completely sleep until that happens..
                        • siodS
                          siodS
                          siod
                          wrote on last edited by siod
                          #32
                          Hi guys,
                          unfortunately I have to answer again to this topic because I don´t get my nodes work longer then up to two weeks. I guess it is still a sleep function problem and the problem persits though I am usin ver 2.0 now. Please have a look at my code, any hint is very appreciated!!
                          I have attached 2 reed switches which should trigger a wakeup and one Hum/Temp Sensor is attached, too. I would like the device to send temp/hum measurements every 15 minutes, what works, but only for a few days or so. Then I also send battery level, that´s all.
                          I have 3 devices up and running right now, they all fail once in while...
                          // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
                          #define MY_RADIO_NRF24 //MySensor Library auf NRF24 Funkmodul einstellen, muss vor MySensor.h Initialisierung geschehen
                          // Define Node ID
                          #define MY_NODE_ID 200
                          //Batterysensor
                          int oldBatteryPcnt = 0;
                          #define CHILD_ID_BATT 7
                          //Kontaktschalter
                          //#include <Bounce2.h>
                          #define CHILD1_ID 1 // Kontaktschalter 1
                          #define CHILD2_ID 2 // Kontaktschalter 2
                          #define BUTTON1_PIN  2  // Kontaktschalter 1
                          #define BUTTON2_PIN  3  // Kontaktschalter 2
                          int oldValueReed1=-1;
                          int oldValueReed2=-1;
                          //Tempsensor
                          #include <SparkFunHTU21D.h>
                          #include <Wire.h>
                          #define CHILD_ID_HUM 3
                          #define CHILD_ID_TEMP 4
                          unsigned long SLEEP_TIME = 900000; // Sleep time between reads (in milliseconds)
                          //tempsensor
                          HTU21D myHumidity;
                          float lastTemp;
                          float lastHum;
                          //boolean metric = true;
                          //Messages
                          //Battery
                          MyMessage msgbatt(CHILD_ID_BATT,V_VOLTAGE);
                          // Kontaktschalter
                          MyMessage msgReed1(CHILD1_ID,V_TRIPPED); // Kontaktschalter 1
                          MyMessage msgReed2(CHILD2_ID,V_TRIPPED); // Kontaktschalter 2
                          //TempMessage
                          //Presentation; present sensors to gateway!
                          void presentation(){
                            sendSketchInfo("Schlafzimmer Messstation", "2.0");
                            present(CHILD1_ID, S_DOOR);
                            present(CHILD2_ID, S_DOOR);
                            //Tempsensor
                            present(CHILD_ID_HUM, S_HUM);
                            //metric = getConfig().isMetric;
                            //Battery
                            present(CHILD_ID_BATT,V_VOLTAGE);
                          //Setup
                            //Serial.begin(9600);
                            Serial.println("Hello!");
                            //Batterysensor
                             analogReference(INTERNAL1V1);
                          #else
                             analogReference(INTERNAL);
                          //Tempsensor
                            Serial.println("Setting up TempSensor...");
                            myHumidity.begin();
                            Serial.println("...done!");
                          // Setup Kontaktschalter 1
                            pinMode(BUTTON1_PIN,INPUT);
                              // Activate internal pull-up
                            digitalWrite(BUTTON1_PIN,HIGH);
                          // Setup Kontaktschalter 2
                            pinMode(BUTTON2_PIN,INPUT);
                            digitalWrite(BUTTON2_PIN,HIGH);
                          //Starte den Loop
                            //Batterysensor
                            // get the battery Voltage
                            delay(1000);
                             #ifdef DEBUG
                             float batteryV  = sensorValue * 0.003363075;
                             #ifdef DEBUG
                             Serial.print(batteryV);
                             Serial.println(" V");
                             Serial.print(batteryPcnt);
                             Serial.println(" %");
                               // Power up radio after sleep
                               send(msgbatt.set(batteryPcnt));
                               oldBatteryPcnt = batteryPcnt;
                            //Kontakstschalter 1
                            sleep(10);
                            // Get the update value
                            int valueReed1 = digitalRead(BUTTON1_PIN);
                            if (valueReed1 != oldValueReed1) {
                               // Send in the new value
                               send(msgReed1.set(valueReed1==HIGH ? 1 : 0));
                               Serial.println("Button 1 geschaltet");
                               oldValueReed1 = valueReed1;
                            //Kontakstschalter 2
                            int valueReed2 = digitalRead(BUTTON2_PIN);
                            if (valueReed2 != oldValueReed2) {
                               send(msgReed2.set(valueReed2==HIGH ? 1 : 0));
                               Serial.println("Button 2 geschaltet");
                               oldValueReed2 = valueReed2;
                           //Tempsensor
                          Serial.println("Starte Messung...");
                              float temp = myHumidity.readTemperature();
                            if (isnan(temp)) {
                            } else if (temp != lastTemp) {
                              lastTemp = temp;
                              send(msgTemp.set(temp, 1));
                              Serial.print("T: ");
                              Serial.println(temp);
                           float humd = myHumidity.readHumidity();
                            if (isnan(humd)) {
                            } else if (humd != lastHum) {
                                lastHum = humd;
                                send(msgHum.set(humd, 1));
                                Serial.print("H: ");
                                Serial.println(humd);
                           Serial.println("Sleep...");
                           sleep(BUTTON1_PIN - 2, CHANGE, BUTTON2_PIN - 2, CHANGE, SLEEP_TIME); //sleep a bit
                          still learning...
                          • slingS
                            slingS
                            sling
                            @siod
                            I'm assuming your batteries are empty when you say fail ?
                            I built 5 of these last week for my dads place.
                            I set internal pullups to LOW and soldered a 3,3MOhm resistor between VCC and Pin2.
                            I'm seeing around 30µA when sleeping on two fresh AA batteries.
                            With internal pullups that would be around 1ma and that would indeed drain the batteries quite fast.
                            • siodS
                              siodS
                              siod
                              no Sir, batteries are still at around 90% charged.
                              still learning...
                              • N
                                N
                                Nicklas Starkel
                                @siod , I had the same problem.
                                I actually ordered a original NRF 24 mini and this seemed to solve some of my problems.
                                i think another problem I'm having is that my batteries has a huge self discharge (old 3.7v 18650)
                                On a side note.. I'm with @sling .
                                Loose the pullups and set them LOW´.
                                I have a 1MOhm resistor between VCC and PIN 2 and PIN 3 (also 2 switches).
                                Using the pullup HIGH draws around 130uA versus LOW it draws between 7 to 10uA!
                                Nca78N 1 Reply Last reply
                                • siodS
                                  siodS
                                  siod
                                  No gentlemen, I don´t think it is a battery problem, maybe a radio problem, but not a battery problem.
                                  But my sketch seems to be ok?
                                  still learning...
                                  • N Nicklas Starkel
                                    Nca78N
                                    Nca78N
                                    That's the best solution with a normal reed switch.
                                    But the best way is to use a "double" reed switch, with both normally opened and normally closed contacts. I use that connected between GND and pin 2 & 3 and set only the unconnected pin to high (so, with pullup). Current will flow only a very short time through the pullup while the node is waking up from sleep, then first thing I do is set connected input low. So nearly 100% of the time input is not connected and current through the reed switch is 0.
                                    I've put a test node on my entrance door, it's been running for over 3 months on a CR2032 cell and has lost only 0.02V meaning it will last at least 2 years, maybe 3.
                                     * Interrupt driven binary switch example with dual interrupts
                                     * Author: Patrick 'Anticimex' Fallberg
                                     * Connect one button or door/window reed switch between
                                     * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
                                     * one in similar fashion on digital I/O pin 2.
                                     * This example is designed to fit Arduino Nano/Pro Mini
                                     * NCA78: Updated to work with one dual normally open/normally closed reed switch on both interrupt pins.
                                    // Enable debug prints
                                    //#define MY_DEBUG
                                    #include <MyConfig.h>
                                    #include <SystemStatus.h>
                                    #define SKETCH_NAME "NCA Door Sensor"
                                    #define SKETCH_MAJOR_VER "0"
                                    #define SKETCH_MINOR_VER "7"
                                    #define PRIMARY_CHILD_ID 3
                                    #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
                                    #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
                                    #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
                                    #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
                                    #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
                                    #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
                                    #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
                                    #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
                                    #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
                                    #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
                                    #define MY_PARENT_NODE_ID 0
                                    MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
                                    //MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
                                    // Parameters for VCC measurement
                                    const int VccMin        = 2000;  // Minimum expected Vcc level, in Volts. At 2V the cell should be dead
                                    const int VccMax        = 2900;  // Maximum expected Vcc level, in Volts.
                                    SystemStatus vcc();
                                    int LastBatteryPercent = 200; // so we are sure to send the battery level at first check
                                    bool isEven = false; // to check+send battery level only for each open+close cycles
                                    bool revertValue = false;  // to change this put a jumper on D4/D7 and it is tested at startup
                                    // This is the activated pin, on which the interrupt is set
                                    byte connectedPin = PRIMARY_BUTTON_PIN;
                                    byte connectedPinAtLastSending = 0; // Initialized at 0 so we will always send the first time
                                      // First thing to do: change clock prescaling to 8 to change from 8MHz to 1MHz
                                      //  of course not necessary if you already have updated fuses and bootloader...
                                      #ifndef MY_DEBUG           // only if we are not in debug mode, so we can keep the fast baudrate in debug
                                        clock_prescale_set (clock_div_8);
                                    void presentation() {
                                      sleep(250); // sleep to let capacitor recharge a bit
                                      sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
                                      // Register binary input sensor to sensor_node (they will be created as child devices)
                                      present(PRIMARY_CHILD_ID, S_DOOR);
                                      sleep(5);
                                      deActivatePin(PRIMARY_BUTTON_PIN);
                                      deActivatePin(SECONDARY_BUTTON_PIN);
                                      // Check if the previously connected pin is now connected. We do that because it's the most likely to be unconnected now
                                      //  so it's the best way not to lose any current
                                      byte newConnectedPin = GetNonConnectedPin();
                                      if (checkPinIsConnected(connectedPin)) {
                                        // If pin is still connected we set back the value to connected pin
                                        newConnectedPin = connectedPin;
                                        #ifdef MY_DEBUG
                                          Serial.println("Connected pin is connected !");
                                      connectedPin = newConnectedPin;
                                      // If connected pin is different that the one during the last sending of status, we send again
                                      #ifdef MY_DEBUG
                                        Serial.print("Connected pin = ");
                                        Serial.println(connectedPin);
                                        Serial.print("New Connected pin = ");
                                        Serial.println(newConnectedPin);
                                      if (connectedPin != connectedPinAtLastSending) {
                                         // Value has changed from last transmission, send the updated value
                                         send(msg.set(connectedPin==PRIMARY_BUTTON_PIN ? (revertValue ? 0 : 1) : (revertValue ? 1 : 0)));
                                         connectedPinAtLastSending = connectedPin;
                                         isEven = !isEven;
                                      if (isEven) {  // send only every two changes for a full open + close cycle
                                        int currentBatteryPercent = SystemStatus().getVCCPercent(VccMin, VccMax);
                                        if (currentBatteryPercent != LastBatteryPercent) {
                                            sleep(100); // sleep 100ms (+65ms wake up time) to let capacitor recharge a bit
                                            LastBatteryPercent = currentBatteryPercent;
                                            sendBatteryLevel(currentBatteryPercent);
                                      #ifdef MY_DEBUG
                                        Serial.print("Preparing to sleep, pin ");
                                        Serial.println(GetNonConnectedPin());
                                        wait(50);
                                      // Activate the non connected pin before setting up interrupt
                                      activatePin(GetNonConnectedPin());
                                      // Sleep until something happens with the door sensor
                                      sleep(GetNonConnectedPin()-2, CHANGE);
                                    void activatePin(byte pin) {
                                      // Set pin as input
                                      pinMode(pin, INPUT);
                                      // Activate internal pull up
                                      digitalWrite(pin, HIGH);
                                    void deActivatePin(byte pin) {
                                      // Set back pin as output, low
                                      pinMode(pin, OUTPUT);
                                      digitalWrite(pin, LOW);
                                    // Will check if pin is grounded (returns true) or not
                                    boolean checkPinIsConnected(byte pin) {
                                      activatePin(pin);
                                      // Read value
                                      byte valPin = digitalRead(pin);
                                      deActivatePin(pin);
                                      #ifdef MY_DEBUG
                                        Serial.print("checkPinIsConnected pin = ");
                                        Serial.print(pin);
                                        Serial.print(", value = ");
                                        Serial.println(valPin);
                                      return valPin != HIGH;
                                    // Returns the pin that is not connected
                                    byte GetNonConnectedPin() {
                                      return (connectedPin == PRIMARY_BUTTON_PIN) ? SECONDARY_BUTTON_PIN : PRIMARY_BUTTON_PIN;
                                    https://www.aliexpress.com/item/20pcs-lot-3-pin-Reed-Switch-2-5X14MM-GLASS-Green-3-pin-Normally-Open-and-Normally/32507762756.html?spm=2114.13010608.0.0.4LJb9I
                                    • siodS
                                      siodS
                                      siod
                                      #38
                                      Ok guys you convinced me, I will set them LOW instead of HIGH.
                                      So now the reed switches are connected: GND | Reed Switch | PIN 2
                                      Doing it your way I must connect them: VCC | 1M Ohm Resistor | Reed Switch | PIN2
                                      Correct?
                                      I just did it the way described here: https://www.mysensors.org/build/binary
                                      There is nothing abaout any resistor...
                                      But will this solve my problem? I am not sure. I had the feeling that the sensors won´t wake up from sleep or so...
                                      still learning...
                                      • L
                                        L
                                        LastSamurai
                                        wrote on last edited by LastSamurai
                                        #39
                                        I would be interested too as I have some battery problems with my reed switches too. I guess its VCC | Reed Switch | GND and Reed Switch |1M Ohm Resistor | inputpin, right?
                                        • L LastSamurai
                                          N
                                          N
                                          Nicklas Starkel
                                          @siod and @LastSamurai
                                          Connect the REED Switch with one leg to GND and the other leg to PIN2.
                                          And then you put a 1MOhm resistor between VCC and PIN2.
