  3. Dual Gateway's
Dual Gateway's
2 Posts 2 Posters 1.2k Views 2 Watching
  • AffordableTechA
    AffordableTechA
    AffordableTech
    wrote on last edited by AffordableTech
    Hi all,
    I'm currently running Ver 1.6.5 with an ESP8266 gateway {ethernet} to OpenHab 2. What I'd like to do is ADD an MQTT gateway so that I can transmit all my sensor data to OpenHab via ethernet and simultaneously to a remote MQTT monitoring app.
    The obvious answer is to simply convert to an MQTT gateway only, but would mean many hours (and headaches) fiddling around with OpenHab conversion scripts etc. I never want to do that again!!!
    Many thanks,
    Paul
    • T
      thehawkes
      wrote on last edited by thehawkes
      You don't need 2 gw to build such a Setup.
      Simply use the
      Mqtt persistence addon and set up a persistence rule for everything you want/need in your monitoring.
      Openhab will push every change of your items to your mqtt broker
