  3. 💬 MySensor Dioder (Ikea)
contest2017diodermysensorshuergbledtrimmerarduinoikea
41 Posts 10 Posters 19.4k Views 10 Watching
    mortommy
    Have you cleaned the folder MySensor within the folder libraries before to copy the 1.5.4 one?
    • pentti12P
      pentti12P
      pentti12
      Hello
      I got lot of errors during the compiling stage. I tried to use older MySensors 1.5.4 library and Arduino 1.5.7 IDE. My question is, how to install correct MySensors library and not use anything else?
        mortommy
        Delete the MySensors folder in libraries and download it again.
        • pentti12P
          pentti12P
          pentti12
          Now I downloaded Arduino IDE 1.6.5.zip, then I extracted it into C:/tools folder. Then I deleted everything from the library folder. Then I started Arduino IDE and I added MySensors-1.5.4.zip library. IDE reported that this file does not contain valid library. I closed IDE. So I unzipped MySensors-1.5.4.zip library directly into library folder. Then I started again IDE and checked that IDE can see MySensors-1.5.4 library. I opened MySensorDioder_133.ino and tried to compile it.
          Still got the following error:
          MySensorDioder_133.ino:38:30: fatal error: MyTransportNRF24.h: No such file or directory
          compilation terminated.
          How to continue?
          • pentti12P
            pentti12P
            pentti12
            Mortommy: Can you change your sketch so that it support MySensors 2.0 library?
              mortommy
              Hi @pentti12 ,
              please find the sketch 2.0.0 in the project. I couldn't test it yet, I have converted it following the guidance and I just verified that it compiles successfully.
              • pentti12P
                pentti12P
                pentti12
                Sorry, but the compiler found a missing library file:
                MyTransportNRF24.h
                MySensors library 2.0 has MyTransportNRF24.cpp only
                • pentti12P
                  pentti12P
                  pentti12
                  Hi
                  I changed my Arduino IDE 1.6.11 using the MySensors development library v2.1.0-beta. Now the compiling went OK. I will continue with that. It will take few days before I have more info about how things went with actual hardware.
                  • pentti12P
                    pentti12P
                    pentti12
                    I tested this latest sketch in my actual hardware (Arduino Mega + Proto shield with additionla components + Ikea Dioder control board). I cannot get system working, nothing happens when I press UP, DOWN buttons. Led-lights stay ON after power up.
                    I also tested to compile your sketch with Arduino IDE and MySensors Library V2.0.0. Compiling went OK, no progress with actual hardware.
                    How can I test step by step what is happening during startup?
                    M 1 Reply Last reply
                    • pentti12P pentti12
                      mortommy
                      @pentti12 ,
                      add the line
                      at the begging of the sketch so via Serial Monitor you'll be able to see the messages pushed by the commands println. You can add other println commands in other point to see the steps covered.
                      • pentti12P
                        pentti12P
                        pentti12
                        OK, I added the line and now I get:
                        TSM:INIT
                        !TSM:RADIO:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        !TSM:RADIO:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        !TSM:RADIO:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        !TSM:RADIO:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        !TSM:RADIO:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        !TSM:RADIO:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        !TSM:RADIO:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        !TSM:RADIO:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        !TSM:RADIO:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        !TSM:RADIO:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        !TSM:RADIO:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        So I have to check my radio-module or replace it with new one. I will continue ...
                          mortommy
                          ok, something is definitely wrong with the radio module. Can you check the connection according to this page?
                          • pentti12P
                            pentti12P
                            pentti12
                            I changed my Radio-module to new one. Does not help. So I have to check my wiring on prototype board.
                            • pentti12P
                              pentti12P
                              pentti12
                              Wiring was OK, but 10uF elko is missing from the 3.3V supply. I have only 440nF capasitor at the moment. This seems to be too small value. I will have 10uF elko on next monday available. So project will take a break.
                              • pentti12P
                                pentti12P
                                pentti12
                                I added 10uF capasitor between VCC and GND pins of the radio module. I also added #define MY_DEBUG_VERBOSE_RF24 line into sketch. I got the following response:
                                TSM:INIT
                                RF24:write register, reg=0, value=14
                                RF24:write register, reg=3, value=3
                                RF24:write register, reg=4, value=95
                                RF24:write register, reg=5, value=76
                                RF24:write register, reg=6, value=39
                                RF24:read register, reg=6, value=255
                                RF24:read register, reg=5, value=255
                                RF24:Sanity check failed: configuration mismatch! Check wiring, replace module or non-P version
                                !TSM:RADIO:FAIL
                                !TSM:FAILURE
                                TSM:PDT
                                RF24:write register, reg=0, value=12
                                RF24:power down
                                I have changed the radio module to new one without success. So there must be some other reason why this sketch does not work in my hardware. Any ideas?
                                  mortommy
                                  Which module are you using? if it is NRF24L01+ be sure it is the "plus" version.
                                  • pentti12P
                                    pentti12P
                                    pentti12
                                    At least I have ordered nRF24L01+ versions. And I use them on other MySensors node and they are working OK.
                                    • pentti12P
                                      pentti12P
                                      pentti12
                                      Update:
                                      I changed Arduino Board from Arduino Mega R3 to Arduino UNO board. I placed my protoshield above UNO-board and now I got following response:
                                      TSM:INIT
                                      RF24:read register, reg=6, value=39
                                      RF24:read register, reg=5, value=76
                                      RF24:write register, reg=16, value=115
                                      RF24:write register, reg=29, value=6
                                      RF24:write register, reg=2, value=2
                                      RF24:write register, reg=1, value=0
                                      RF24:write register, reg=28, value=3
                                      RF24:flushRX
                                      RF24:flushTX
                                      RF24:write register, reg=7, value=112
                                      TSM:RADIO:OK
                                      RF24:write register, reg=2, value=3
                                      RF24:write register, reg=1, value=1
                                      RF24:start listening
                                      RF24:write register, reg=0, value=15
                                      RF24:write register, reg=10, value=9
                                      TSP:ASSIGNID:OK (ID=9)
                                      TSM:FPAR
                                      RF24:stop listening
                                      RF24:open writing pipe, recipient=255
                                      RF24:write register, reg=10, value=255
                                      RF24:write register, reg=16, value=255
                                      RF24:send message to 255, len=7
                                      RF24:flushTX
                                      RF24:write register, reg=7, value=48
                                      RF24:MAX_RT
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                      TSM:FPAR
                                      RF24:stop listening
                                      RF24:flushTX
                                      RF24:MAX_RT
                                      RF24:flushTX
                                      RF24:read message, len=8
                                      RF24:write register, reg=7, value=64
                                      TSP:MSG:READ 0-0-9 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      TSP:MSG:PAR OK (ID=0, dist=1)
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=9)
                                      TSM:UPL
                                      TSP:PING:SEND (dest=0)
                                      RF24:stop listening
                                      RF24:open writing pipe, recipient=0
                                      RF24:write register, reg=10, value=0
                                      RF24:write register, reg=16, value=0
                                      RF24:send message to 0, len=8
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      TSP:MSG:READ 0-0-9 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      TSP:MSG:PONG RECV (hops=1)
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      Setup... end.
                                      RF24:stop listening
                                      RF24:send message to 0, len=9
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                      RF24:stop listening
                                      RF24:send message to 0, len=12
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                      RF24:stop listening
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                      RF24:read message, len=9
                                      TSP:MSG:READ 0-0-9 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      Incoming message: 15
                                      RF24:stop listening
                                      RF24:send message to 0, len=21
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=11,pt=0,l=14,sg=0,ft=0,st=ok:MySensorDioder
                                      RF24:stop listening
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=12,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                      RF24:stop listening
                                      RF24:send message to 0, len=7
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-0-0 s=0,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                                      RF24:stop listening
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-0-0 s=1,c=0,t=26,pt=0,l=0,sg=0,ft=0,st=ok:
                                      Request registration...
                                      RF24:stop listening
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                      TSP:MSG:READ 0-0-9 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      Node registration=1
                                      Init complete, id=9, parent=0, distance=1, registration=1
                                      Wheel position changed.
                                      Wheel position: 0
                                      Hue value of the Wheel position: 0
                                      Send command to lights.
                                      Bright: 0
                                      Red: 0
                                      Green: 0
                                      Blue: 0
                                      RGB in HEX: 000000
                                      RF24:stop listening
                                      RF24:send message to 0, len=11
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-0-0 s=0,c=1,t=3,pt=4,l=4,sg=0,ft=0,st=ok:0
                                      RF24:stop listening
                                      RF24:send message to 0, len=13
                                      RF24:flushTX
                                      TSP:MSG:SEND 9-9-0-0 s=1,c=1,t=40,pt=0,l=6,sg=0,ft=0,st=ok:000000
                                      Now sketch seems to work. I will continue by adding IKEA DIODER Leds. More info later.
                                      • pentti12P
                                        pentti12P
                                        pentti12
                                        Update:
                                        I can control locally the IKEA DIODER now. So the hardware is more or less working as expected, but do you have good instructions how I can get OpenHAB2 and MySensors Ethernet Gateway working together. Today I can see MySensors Ethernet Gateway ONLINE state and I can manually add Custom Sensor as a thing, but I cannot control items via Openhab.
                                        I use the latest OH2 Snapshot ( on Pine64 with Debian Jessie) and latest MySensors GatewayW5100 (library 2.0) on the MySensors Gateway (Arduino UNO based) and I have tried to start/stop/restart OH2 after MySensors Gateway is up and running without success.
                                        OH2 is capable to control for example Philips HUE lights without problems at the moment.
                                          mortommy
                                          wrote on last edited by mortommy
                                          #40
                                          Great news!
                                          Regarding OH, I didn't have the opportunity to play with the v2.0 yet, I'm still on 1.8.1.
                                          I have a serial mysensors gateway and this is my set up:
                                          OH (v1.8.1) <-> OH MQTT binding (as MQTT client) <-> Mosquitto (as MQTT server) <-> mosquitto to serial (python script that reverts messages with topic mysensors to the serial port and vice-versa) <-> serial gateway.
                                          So my items in OH are based on mqtt binding.
                                          I guess OH2 and mysensors openhab binding make everything easier.
