  3. Relay turns on when input is LOW?!
5 Posts 4 Posters 3.4k Views 3 Watching
  • dakkyD Offline
    dakkyD Offline
    dakky
    wrote on last edited by dakky
    The title says it all: I have connected a relay to my network and it switches power on (led on the relay lights up), when the input pin goes low and vice versa.
    Thats a little bit confusing, when switching off something in the controller UI and the device is switching on ;) and i don't think, that zwitching the state in the arduino code is the way to go :D
    any idea whats wrong here? Wiring is straight forward (vcc & gnd with corresponding pins on relay + D2 to I1 on the relay).
    The code is the the one from the examples (as far as I remember :D ).
    I inserted some debug statements to prevent stupid errors on my side ;)
        Serial.print("arduino pin: ");
        Serial.println(message.sensor + FIRST_DIGITAL_RELAY_OUTPUT);
        Serial.print("message.bool: ");
        digitalWrite(message.sensor + FIRST_DIGITAL_RELAY_OUTPUT, message.getBool() ? RELAY_ON : RELAY_OFF);
    arduino pin: 2
    message.bool: 1
    results in switched off relay.
    Thanks for helping
    EDIT: maybe "hardware" is the wrong section and "Troubleshooting" a better location ;) If thats the case: please move the thread if possible
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
    • mfalkviddM Offline
      I don't remember why this happens, but the simple solution is to switch the #defines for RELAY_ON and RELAY_OFF in the beginning of the sketch. The reason those are defined is to make it easy to switch them.
      • D Offline
        Not sure what kind of relay setup you are using, but are you using a pull-up or pull-down resistor on your data line? If you are using pull-up resistors, the data line is always high and needs to be pulled low to be active. Check that you are not using the internal pull-up resistors on your data line. For this you should use a pull-down resistor if your relay setup does not already have one.
        • Boots33B Offline
          Boots33B Offline
          Boots33
          wrote on last edited by Boots33
          If you are using a relay module similar to this one
          They often use a PNP transistor to drive the relay. That means you will need to switch the arduino output low to turn on the relay, as you have discovered.
          As @mfalkvidd has said the simple fix may be to reverse the #defines
          Here is what the relay circuit would look like. They would also likely have a resistor from the transistor base to vcc to ensure the transistor turns off
          • dakkyD Offline
            dakkyD Offline
            dakky
            Ah that explains it for me. Thanks for the dettailed answer. I will @mfalkvidd's and switch the defines. thank you all ;)
            Greetings
            12.2k
