  3. Cobine working DHT22 and LDR with a RelayWithButtonActuator
dht22 ldr relay
36 Posts 4 Posters 8.0k Views 5 Watching
  • alexsh1A alexsh1
    @Dick With sketches it is like this sometimes - troubleshooting is time consuming.
    I would suggest the following. Try to comment out line by line on the LDR code, upload and see if it works. Try to insert as many Serial.print as you could to print the status of variables to the serial port.
    I do not have the LDR so cannot help you much on this one. I have multiple other sketches combined together working just fine.
    DickD Offline
    DickD Offline
    Dick
    @alexsh1
    That could I do, thanks for the tip and will do that today. Any idea is welcome :smiley:
    B 1 Reply Last reply
    • DickD Dick
      @alexsh1
      B Offline
      B Offline
      BartE
      wrote on last edited by BartE
      #22
      @Dick I think this issue sits here you use Digital port 0 (which is the serial debug port) i.s.o. Analog port 0 (A0).
      Change this line
       #define LIGHT_SENSOR_ANALOG_PIN 0
      to
       #define LIGHT_SENSOR_ANALOG_PIN A0
      And you better also add this line to the setup function
      pinMode(LIGHT_SENSOR_ANALOG_PIN, INPUT);
      DickD 1 Reply Last reply
      • B BartE
        Change this line
        to
        DickD Offline
        DickD Offline
        Dick
        have not tried all the given options but started again with all the previous advises of Bart. Noe I still struggle with an error
        "gw.begin(incomingMessage, AUTO, true);" in mij script. I checkt the "{ }" over and over again but it must be something else.
        can anybody take a look?
         #include <DHT.h>
         #include <Bounce2.h>
        #define CHILD_ID_HUM1 0
         #define CHILD_ID_HUM2 1
         #define CHILD_ID_TEMP1 3
         #define CHILD_ID_TEMP2 4
        #define CHILD_ID_LIGHT 0
        // RelayWithActuator stuff
         #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
         #define BUTTON_PIN 6 // Arduino Digital I/O pin number for button
         #define CHILD_ID 5 // Id of the sensor child
         #define RELAY_ON 1
         #define RELAY_OFF 0
         Bounce debouncer = Bounce();
        int oldValue=0;
         bool state;
        MyMessage msgLight(CHILD_ID,V_LIGHT);
        MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
         int lastLightLevel;
        #define HEARTBEAT 10
         unsigned int timer = 0;
         // Sleep time between reads (in milliseconds)
         #define SLEEP_TIME 3000
        DHT* dht[2];
         byte sensorPin[2] = {3, 4};
         float lastTemp[2] = {0.0, 0.0};
         float lastHum[2] = {0.0, 0.0};
        boolean metric = true;
        //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
        //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
         gw.sendSketchInfo("HumidityAndRelay", "1.0");
         for (int i = 0; i < 2; i++)
         dht[i] = new DHT;
         dht[i]->setup(sensorPin[i]);
        gw.present(CHILD_ID_HUM1, S_HUM);
         gw.present(CHILD_ID_HUM2, S_HUM);
         gw.present(CHILD_ID_TEMP1, S_TEMP);
        // Setup the button and Activate internal pull-up
         pinMode(BUTTON_PIN,INPUT);
        // Activate internal pull-up
         debouncer.attach(BUTTON_PIN);
         debouncer.interval(5);
         gw.present(CHILD_ID, S_LIGHT);
         pinMode(RELAY_PIN, OUTPUT);
         state = gw.loadState(CHILD_ID);
        timer = 0;
         gw.process();
         timer++;
        if (timer > (SLEEP_TIME / HEARTBEAT))
         // Reset timer again and for the next timed loop
         timer = 0;
         delay(dht[i]->getMinimumSamplingPeriod());
         float temperature = dht[i]->getTemperature();
         if (isnan(temperature))
         Serial.print(F("Failed reading temperature from DHT"));
         Serial.println(i);
         else if (temperature != lastTemp[i])
         lastTemp[i] = temperature;
         if (!metric)
         temperature = dht[i]->toFahrenheit(temperature);
        //gw.send(msgTemp.set(temperature, i));
         Serial.print(F("T"));
         Serial.print(i);
         Serial.print(F("= "));
         Serial.println(temperature);
         float humidity = dht[i]->getHumidity();
         if (isnan(humidity))
         Serial.print("Failed reading humidity from DHT");
         Serial.println(i);
         else if (humidity != lastHum[i])
         lastHum[i] = humidity;
        //gw.send(msgHum.set(humidity, 1));
         Serial.print(F("H"));
         Serial.print(i);
         Serial.println(humidity);
        int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
        //Serial.println(lightLevel);
         if (lightLevel != lastLightLevel)
        gw.send(msgLightLevel.set(lightLevel));
          //lastLightLevel = lightLevel;
          Serial.print("L=");
        debouncer.update();
          // Get the update value
          int value = debouncer.read();
          if (value != oldValue && value==0)
              gw.send(msg.set(state?false:true), true); // Send new state and request ack back
          oldValue = value;
        gw.wait(HEARTBEAT); //sleep a bit
         if (message.isAck())
        if (message.type == V_LIGHT)
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID, state);
         // Write some debug info
         Serial.print(message.sensor);
        • mfalkviddM Offline
          #24
          The auto-formatting feature in the Arduino IDE is very useful for makin the code easier to read (both for yourself and for us forum readers) and spot mistakes.
          What is the error message you are getting?
            DickD Offline
            DickD Offline
            Dick
            three errors. hope you can give an advise!
            In function 'void loop()':
            laatste:163: error: 'msg' was not declared in this scope
            At global scope:
            laatste:172: error: expected declaration before '}' token
            In function 'void setup()':
            laatste:47: error: 'incomingMessage' was not declared in this scope
            • DickD Dick
              At global scope:
              B Offline
              B Offline
              BartE
              #26
              @Dick
              msg should become msgLight
              gw.send(msgLight.set(state ? false : true), true); // Send new state and request ack back
              and move one } just below this line
              to the very end of you sketch
              DickD 3 Replies Last reply
              • B BartE
                @Dick
                DickD Offline
                DickD Offline
                Dick
                no errors anymore. I test the script now and will also put the changes you posted befor.
                • B BartE
                  @Dick
                  DickD Offline
                  DickD Offline
                  Dick
                  tested and also add the changes of your message (9hrs ago).
                  What I see on the serial monitor is, temp (2x), hum (2x) and light level but nothing of the relay. it is still clicking but no change in the logging from 1 to 0 etc. I already adjusted the script this morning with the 'RelayWithButtonActuator Example'. so only the relay part is not working and not visible in the serial log. Any idea?
                  • DickD Dick
                    B Offline
                    B Offline
                    BartE
                    @Dick are you sure it's not a hardware (wire) issue?
                    What happens if you load the RelayWithButtonActuator example code (with the correct pinning of course) ?
                    • B BartE
                      @Dick
                      DickD Offline
                      DickD Offline
                      Dick
                      here the latist version but not working
                       #include <DHT.h>
                       #define RELAY_ON 1
                       #define RELAY_OFF 0
                      int oldValue=0;
                       bool state;
                       int lastLightLevel;
                      DHT* dht[2];
                       dht[i] = new DHT;
                      timer = 0;
                       gw.process();
                       timer++;
                       timer = 0;
                       Serial.println(i);
                       if (!metric)
                       Serial.print(i);
                       Serial.println(i);
                       Serial.print(i);
                        Serial.print("L=");
                      debouncer.update();
                        oldValue = value;
                      • DickD Dick
                         #include <DHT.h>
                         #define RELAY_ON 1
                         #define RELAY_OFF 0
                        int oldValue=0;
                         bool state;
                         int lastLightLevel;
                        DHT* dht[2];
                         dht[i] = new DHT;
                        timer = 0;
                         gw.process();
                         timer++;
                         timer = 0;
                         Serial.println(i);
                         if (!metric)
                         Serial.print(i);
                         Serial.println(i);
                         Serial.print(i);
                          Serial.print("L=");
                        debouncer.update();
                          oldValue = value;
                        B Offline
                        B Offline
                        BartE
                        @Dick
                        Change these lines
                            oldValue = value;
                        to
                            oldValue = value;
                        DickD 2 Replies Last reply
                        • B BartE
                          @Dick
                          Change these lines
                              oldValue = value;
                          to
                              oldValue = value;
                          DickD Offline
                          DickD Offline
                          Dick
                          and about the test of the RelayWithButtonActuator Example,
                          it works fine. I adjust the lines now and will test it
                          • B BartE
                            @Dick
                            Change these lines
                                oldValue = value;
                            to
                                oldValue = value;
                            DickD Offline
                            DickD Offline
                            Dick
                            tested but still clicking relay. As you can see that there is nothing to see in the serial log
                            send: 4-4-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                            send: 4-4-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.4
                            send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                            read: 0-0-4 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                            repeater started, id=4, parent=0, distance=1
                            send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:HumidityAndRelay
                            send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                            send: 4-4-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                            send: 4-4-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                            send: 4-4-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                            send: 4-4-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                            T0= 22.20
                            H0= 61.80
                            send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:74
                            L=74
                            T1= 25.00
                            H1= 60.20
                            L=74
                            L=74
                            send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:76
                            L=76
                            • DickD Dick
                              T0= 22.20
                              H0= 61.80
                              L=74
                              T1= 25.00
                              H1= 60.20
                              L=74
                              L=74
                              L=76
                              B Offline
                              B Offline
                              BartE
                              #34
                              @Dick If there is nothing visible in the log, then you can presume there is a hardware issue.
                              Some possible issues:
                              • loose relays wire (bad connection) --> try a different wire
                              • wrong pin is used (if set as input the pin will "float" resulting in unstable relay behaviour) --> double check your pin number in code and actual PCB
                              • pin double used ie the DHT drive poll this pin for some reason. --> use a different pin in both code and conection to relay
                              • B BartE
                                DickD Offline
                                DickD Offline
                                Dick
                                thank you BartE, I received today an new Uno and some other stuff so I can rebuild it al to see if it is an HW failure. I hope I can start tomorrow. I keep you informed but thanks for your support. to be continued.
                                • DickD Dick
                                  B Offline
                                  B Offline
                                  BartE
                                  #36
                                  @Dick Not sure what your approach is but normally i start with prototyping using these wires and when all works fine (software and hardware) i solder everything together on a PCB.
